Question about Frigidaire ATF6000ES Front Load Washer
Door lock bad
How do you remove and replace
  • 530 Answers
All you have to do is take the front of the door seal off..remove screws of door lock and wires attached and replace with new.
Posted on May 28, 2009
L door dose not lock all door locks
This may be due to a bad lock actuator, i will need to ask a few questions first.Can you lock the door by hand using the button? or is the lever stuck?Is the problem that it does not work with the power locks only?
Let me try to answer these, first if the door lock does not work with the power locks then the door lock actuator may be bad, the door panel will need to be removed and test for power at actuator. While inside the door check lock linkage.If the door lock lever wont move then that may also be related to a frozen lock actuator, that is the same as above. a bad or frozen lock actuator will not allow door to lock or unlock but sometimes a bad actuator will not work with the power button but will allow you to lock and unlock with lock lever or door key, the door panel needs to be removed to check . good day.
Apr 29, 2012 | 2000 Hyundai Sonata
Back driver door won't lock or unloc without manualy doing . 2008 chevy impala
Hello, this is caused by a bad door lock actuator. the door lock actuator is part of the door latch. the door latch will need to be replaced to correct this problem.
  • Remove the rear door outside handle. .
  • Remove the interior trim panel.
  • Remove the water deflector
    May 29, 2011 | 2008 Chevrolet Impala
    I have a 2005 Toyota Tacoma. The fob key works but locks only 3 doors (passenger and 2 back doors) but not the driver side door. Any idea on the problem?
    it could be the power door lock motor on that door or the lock motor is not getting the signal from the module.some times the wires that run between the car body and the door break and need repairing.these are covered by a rubber tube that is fastened one end to the body the other to the door,you can see it with the door open.
    Apr 10, 2011 | 2005 Toyota Tacoma
    Replaced door lock on front load wash still hav Fdl code and door wont lock
    I had the same problem you have and did the same thing, replaced the lock. Whirlpool must be making a million on all the door locks people are replacing. The problem is on the CCU circuit board, not the door lock. There are bad solder joints, also called cold solder joints, on the circuit board where the spade connectors and relays (5 of them) are supposed to be soldered tightly to the board. Do you remember the PINK wires going to a plug on the door lock? Those wires go directly to the spade connectors then pass the door lock info on to the relays. The cure is to remove the CCU case with circuit board, it's easier that way. Then remove the board and touch-up those joints I mentioned. The CCU case is located in the machine at the top in the back. You will break off some of the plastic tabs on the case, it seems whirlpool used the same bad quality control in their plastics division as they did in the manufacture of their circuit boards. If you're not up on your soldering techniques, you can remove the CCU case, with board, and take it along with this response to a good appliance repair shop and they should be able to help you out. Good luck.
    Mar 02, 2011 | Whirlpool Washing Machines
    What are some common symptoms of a bad driver's side door lock actuator?
    the symptoms wont lock or did not unlock or flactuating.u need to replace the actuator.remove the door trim of the door remove the metalscrew,remove the linkages of the lutch
    Feb 24, 2011 | 2003 GMC Yukon
    98 Chev Blazer. power lock problem. driver's door would not unlock doors, now it will not lock doors. passenger side works fine
    you may just have a bad connection under the lock button under switch panel on your drivers door. check electrical plug in at door lock switch by removing that panel from driver door.it may be that you have to replace that door lock switch .thers only one fuse for door locks and if pass side works, it's not blown.
    Aug 19, 2010 | 2001 Chevrolet Blazer
    Driver side doors will not lock. Loud,sick noise when button is pushed to lock or unlock.
    loud buzzing noise but locks not working equals bad door lock actuator. remove door panel, locate and replace actuator.
    Mar 23, 2010 | 2000 Jeep Grand Cherokee
    The cargo door and glass is locked, and the actuator will not unlock.
    how do you removed the interior cover? for the rear door actuator?
    Oct 12, 2008 | 2006 GMC Yukon Xl Denali
    Instructions to replace door lock
    remove spring around door seal on front pull seal off and push inward to inner basket remove 2 screws in lock assembly and pull lock toward opening remove wiring connections reinstall in reverse..spring can be a dog but not a bad job
    Aug 19, 2008 | Whirlpool GHW9200L Front Load Washer
    Door lock whirlpool front loader
    remove bad around door seal roll seal back at lock location remove the torx screws holding lock in pull lock out through front and remove wires reinstall in reverse..good luck with retaing band can be fun
    Jun 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Frigidaire ATF6000ES Front Load Washer Logo
    113 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
