Question about Dell OptiPlex 170L PC Desktop
Can't access hard drive getting IDE master hard drive SMS mess
Getting the following
notice:The primary IDE master hard drive SELF MONITORING SYSTEM has reported that a parameter has exeeded its normal operating range
dell recommends that you back up your data regularly.
A parameter out of range may or may not indicate a potential hard drive problem.
Strike F1 key to continue, F2 to run setup utility.
  • mrninja
    mrninja May 11, 2010
    have you defragmented lately?
  • 3,940 Answers
You are getting a SMART error indicating that the hard disk drive is/has failing/failed. Likely, the only way to get data off the drive is to send it to a data recovery center, then install a new hard drive. Data recovery is generally expensive, but if you are interested you can contact places like DRIVESAVERS 800.440.1904
Posted on May 28, 2009
How do I fix a problem were a tower computer won't see the slave hard drive.
It sounds like both drives are trying to be the master on the cable. Have you tried setting both drives jumpers to the CABLE SELECT setting. This allows the BIOS to individually identify them and you specify in the BIOS which is the primary boot drive.
Mar 22, 2016 | Dell Computers & Internet
Primary master wdc
Primary Master .
This is where the hard disk parameters are entered for the primary master IDE/ATA device, the first drive in a modern IDE system. See the hard disk section for details on what these terms mean and how these devices are set up. The various settings for the drive are discussed in detail in the IDE Setup / Autodetection section. The default setting for this on a system with IDE autodetection, is usually "Auto"
WDC That Mean Western Digital Company.This's Logo HDD.
First Time If you have Problem With Bios You can Select Load Default Bios to clear any fault setting before.and select Save&exit.
To verify problem again.
Jun 22, 2015 | Computers & Internet
Unable to make SATA dive as primary master .
Remove the IDE hard drive, and connect the SATA drive to SATA0 (zero) port. Install the OS on SATA drive. You may have to check BIOS. F2 on boot should get you there.
Oct 09, 2012 | Dell Precision Computers & Internet
I formatted my hd making it slave in other system: now i m placing it back on my system then it is saying Primary IDE masterNONE; Primary IDE Slave SP0822N Then comes NTLDR MISSING
> formatted my HD
This deleted 99% of the files on the disk-drive.
> Primary IDE Master: NONE
> Primary IDE Slave: SP0822N
Good. Your motherboard has detected ONE disk-drive.
Do you have just one connected disk-drive on your PRIMARY channel, or do you have two connected disk-drives (via the 2 connectors on the one ribbon-cable on the PRIMARY channel) ?
If you have two drives connected via one ribbon-cable, you MUST set the 'master/slave/cable-select' jumpers on BOTH disk-drives, to identify which of the two will be the 'master' and which will be the 'slave'.
Also, check that the 'second' disk-drive is getting electrical power.
> NTLDR MISSING
Like I said, you deleted 99% of the files, including the 'NTLDR' file.
Your computer is trying to "boot" from the 1% of the files that still exist on the disk-drive, but cannot find the now-deleted file.
Perfectly normal, given that you have formatted the disk.
Oct 06, 2010 | Samsung (SP0822N) 80 GB Hard Drive
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Start by simplifying the configuration. Disconnect the second IDE cable from the motherboard and disconnect the power to the DVD drive. Disconnect the SATA device. On the #1 IDE cable, connect the master drive to the connection on the end of the cable. Connect the Slave drive to the middle connection on the cable. Start the computer and press the key indicated to enter setup. Verify that drives are properly indentified as master and slave. If they are, shutdown the computer. Now add the IDE DVD drive to the end connection on IDE cable #2. It should be set as a Master drive. Start the PC again and go into setupand verify that the DVD is IDE #2 Master. Shut down the PC. Add the SATA device and start eh PC again. Go into Setup to verify that all of the drives are properly identifed. Restart the computer and let it boot into Windows. Open Windows Explorer to view the drive settings. If the drives are all present, but the letters are not what you want, click on START and then right click on MY COMPUTER and then left click on MANAGE. Under Storage click on DISK MANAGEMEN. The drives will all be displayed with their assisgned letters. If you need to change a drive letter, right click on the drive you want to change and select 'Change drive letter . . .'. Change it to a hight letter in the alphabet, then change the dive you want in the original postion to the now vacant letter. Finally change the original drive to the first available letter. Example: C:=IDE M1 D: E:=IDE S1 Change D: to H: then E: to D: and finally H: to E: they drives would then be: C:=IDE M1 D:=IDE S1 E:=IDE M2(DVD). Restart the PC and the drive should come up as you want them to be labled.
Good luck and please let me know how it works ouot for you.
Feb 26, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Feb 26, 2009 | Computers & Internet
IDE MASTER DRIVE ERROR
Sure sound like you hard drive is starting to have a problem. I would clean and defrag it after backing it up. start- my computer- right click on hard drive-properties-disk cleanup/  After that then 'tools defrag hard drive. then run scan disk
Jul 14, 2008 | Dell OptiPlex 170L PC Desktop
I need Help
Hi Banyar, lets check the main menu & the boot order in you're bios. Start up the PC, as soon as you see any display on the monitor press the delete key every 2 seconds until the bios main menu loads. This is also where you can see the time & date. List on the left is;
Primary IDE Master
Primary IDE Slave
Secondary IDE Master
Secondary IDE Slave
Across from these on the right is the matching device. If you have one hard drive the bios will show its model number on the right.
Ex: ST150322A. (You're drive will be different). If you have more than one hard drive the second drive, (Should be listed as Primary IDE Slave). CD-ROM drives would be listed as, Secondary IDE Master & Secondary IDE Slave. Write down the model name of the Primary IDE Master on paper. Now go to the title, "Boot" in the bios. Use you're manual & go to page 2-25. High-light, Boot Device Priority & press enter. Set the order as shown in the manual. Make sure the 3rd boot device is set to the correct hard drive listed from the main menu. The model you wrote down. Once set save & exit the bios. The PC will restart. You should no longer receive the error message & windows should boot normally. If windows does not load normally than it is possible that the Primary IDE master drive is not the drive with windows installed on it. You must find the correct drive with windows loaded on it. Connect that drive to the Primary IDE master port.
You may need to reset the drive’s pin settings so it is seen as the primary drive.
Than change the 3rd device in the bios boot priority list with the correct drive. Windows demands that the operating system be located on the, Primary IDE master port. Please read pages 2-12 & the top of 2-13 in you're manual.
More questions? Post them here.
Good Luck!
Mike
Jun 21, 2008 | ASUS P5VD2-MX SE Motherboard
Power up problems
To enter setup (Refering to the bios/cmos), press the Delete key very two seconds untill the bios main menu loads. You need to go to the menu heading - Boot.
If you added another hard drive to you're system the IDE (hard drive) it's jumper settings may not be correctly set. If there are now two IDE drives both the primary master & secondary drive's jumpers must be set correctly. You will ned to look at the white sticker on the drive for the correct jumper settings. Many primary IDE drives pin jumper is set as a single master drive with out a secondayr drive attached in the system. When you add a second drive the pin jumper one the master drive will most likely need to be changed to master with a slave. The second drive will also need it's jumper set as a slave drive. Once this has been adjusted you need to enter the bios & make sure you're primary master drive is set in the boot order. Most PC's boot order is as follows.
1st Boot device, floppy drive. (If one is connected to the system).
2nd boot device, CD-ROM drive.
3rd boot device, master IDE drive.
Please use the help of you're manual to guide you for these settings.
AOpen MX46L web site. http://download.aopen.com.tw/Default.aspx
You must set the three drop down menu's to get you're board's drivers & manual. In the first menu choose motherboard, in the second menu choose MX46L & in the last menu choose manual. For drivers, the third menu choose drivers.
Still heave more questions? Just ask.
Mike
May 18, 2008 | AOpen MX46L Motherboard
Dell OptiPlex 170L PC Desktop Logo
588 people viewed this question
Alun Cox
