Question about Water Heaters
Water softner dirty water
I have a ''Kinetico'' water softener, model 60 (about 19 years old). I am on well water. The well water outside in the the yard faucet and the hot water in the house are crystal clear. The cold water in the house started to turn browish. Any suggestions what the problem is and how to fix it?
Thanks
jimmorg
  • 2 more comments
  • jimmorg May 28, 2009
    My system consists of two cylinders (twin filter tanks which are sealed and contain resin beads) and a salt drum (brine tank). The water comes in from the well into the salt drum where it gets processed, then it goes into one of the cylinders where it gets filtered. The clean water comes into the house and the brine gets discarded. The two cylinders are connected with each other with double pipes and the salt drum is connected to the filter valve, which sets on top of one of the cylinders, timer, with a hose.
    I hope this gives you abetter description.
    Thanks
  • Samuel Charles Spriggs May 11, 2010
    That's not a simple system to diagnose. Sounds like iron in the water softening system. It's settling out in the hot water tank which is why hot water is not brown.
    One data point would be to shut down the backwash system for a day or two and see if the water clears up.
    Have you been doing the maintenance on the system yourself?
  • jimmorg May 11, 2010
    I haven't fixed it yet.
    I thought that I asked for a free advice. Isn't that available?
    jimmorg
    Do you have a sediment filter? If so, when was it last replaced?
  • 332 Answers
You might also want to check into the piping in your house is it gavinized, cpvc or copper, this could also make a diffrence, you could also be pulling mud from the bottom of your well, the anoid rod in the water heater will keep you from seeing this in the hot side lines,suggest to have a test done on the water take a jar with a lid and take it to your local plumbing supply house and see if they can't have it tested then you will have all your answers, the test i'm in md. it cost us aprox 40.00 to have the complete water test,
Posted on May 30, 2009
What could be the problem causing the rotten egg smell in the water? We have changed the anode rod.shocked the well.no sulfur. We have kinetico softener. Use iron out salt. Water heater 2 yrs old.
Some water softeners you can increase the back wash time on the unit to clear out a smell or bad taste , rotten egg smell can be sulfur. You may need a well flush but seek a well company on that for there advice as its not cheap .
May 16, 2017 | Water Water Heaters
The waster Softner does not regenerate on its own?
Hi Pam,
Did you just install this ? If not, how old is it ? This is a metered water softener, and if it is not counting gallons, it will never regenerate. To check this, press and hold the SELECT button for 3 seconds, and turn on a faucet. This will show the counting of the water. If it is not counting, there may be debris in the meter turbine, or it is plumbed in backwards.
May 27, 2015 | Kenmore 420 Series Water Softener
I have water in the junction box on top of my hot water heater and into the electrical conduit leading to the hot water heater.
I do not see your earlier post with photo.
The problem could be the conduit.....
-disconnect the conduit and wires from water heater
-run wire into a junction box set lower than top of water heater... -then run another #10 wire from the junction box up to water heater...
-So if water is coming from conduit, it will accumulate into junction box and not in the water heater wiring cavity.
Next thing....
... a water softener can cause rusted tank.
-Softened water adversely affects anode rod...
-causing anode rod to deplete faster...
-once anode rod is gone, then tank begins to rust.
-Here are details for checking anode rod each 2-3 years:
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Gene
Water Heater Timers Save Money
Mar 05, 2015 | Rheem 82v52-2 Tall Electric Water Heater...
Where can I get a Rheem water heater repair manual
I would first look at the owners manual and or the schematics. You can probably find it on line if you have the model and serial number. I would then call a Rheem dealer or contact the company to see what that error code is. Personally I wouldn't try to fix it myself because it's gas and if you screw up you could blow youself up or burn the house down. That's why I buy electric water heaters and a water softener. I may pay a little more in electric but with the softner to remove the lime, I never have to change an element, only add salt about every 3 months.
Oct 16, 2014 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
We have a one year old home with PEX pipe and one year old hot water heater fed by a water softener. In one of the bathroom sinks, and only there it seems, there is a sulfur smell when we first open the...
i would check the softener before the water heater, when was the last time you did a back flush of the system? water sitting at the bottom of a water softener tank can get moldy and begin to rot, which causes H2S gas which smells like sulfur , its a breakdown of decay,, this will also happen if your home is using well water,, so check that first , empty the tank and clean it our ,, then back flush the system
Jul 03, 2011 | Water Heaters
A very old rheem fury water heater i assume it's just worn out but because of a space problem i can't go wider than the 15 inch diameter it has.
16" diameter water heaters could work if you cut away the metal and insulation off of 1 side of the water heater. The actual tank inside the shell is smaller than outside diameter.
American gas water heaters shows a 30gal 16"
model BFG61-30T30-3NOV
http://www.americanwaterheater.com/products/pdf/NRGSS00107.pdf
AO Smith has 16" Promax 30 gallon gas
Model GCV30
http://www.hotwater.com/lit/spec/res_gas/ARGSS01406.pdf
ELECTRIC 6 gallon point of use
http://www.hotwater.com/lit/spec/res_elec/AOSRE50400.pdf
You can get a tankless water heater if you have the additional money and a water filtration and softener system and don't mind expensive repairs if you install it yourself.
Oct 22, 2010 | Rheem Water Heaters
I have a Servi-star 40 Gal. electric SN# SS 0496B15258, How old is this unit? Thanks, Jim
http://www.buyerschoiceinspections.com/water-heater-ages
There seem to be 2 possible answers: Servi-star vs Servistar
Answer #1: Servi-star by American
1st 2 digits are year, 2nd 2 digits are week
This means water heater was made year 2004, 96th week ....it seems wrong.
Answer #2: Servistar by Craftmaster
1st 2 digits are month, 2nd 2 digits are year
This would mean your water heater was made 4th month of 1996
Which answer is true? 6 years old or 14 years old
If tank had 12 year warranty and came with 2 anode rods, and you have good water, and no stray current on pipes, then tank can last 14 years.
If tank had 6 year warranty and came with one anode rod, and you have hard water and a water softener, and you never changed anode rod or drained tank, then 6 years is a long life for the tank.
Oct 07, 2010 | Rheem Water Heaters
We have a water softner AO Smith and we did the release valve on it and now it wont stop dripping.
Do you mean a water heater? Not sure why a RELIEF valve would be on a water softener.
Many times if a relief valve is not tested regularly it can gat minerals and deposits in it that can prevent it from sealing back up when tripped.
Sometimes tripping it quickly with the lever can make it work again. It is a realativly easy and inexpensive part to change.
Turn off water and relieve pressure on tank. Have the new one doped up and ready. Remove the old one and put the new one right in. Test the new one and you're done.
This valve should be tested monthly and a gallon or so of water drawn from the bottom of the heater as minerals and sedimet build up in the bottom. The water heater will last longer and be more effecient if seviced reguarly.
Jun 09, 2010 | Water Heaters
I just had a mouse surface in my holding tank how do I clean that out? do I add bleach and cycle the water softener?
The mouse must have been in one of your product bags...depending on the deterioration of the carcus; you may have already injested some of the decomposing material.
1. Turn off the water supply and remove the top cover
2. Make sure you have rubber glvoes. Drain the holding tank and remove and dispose of the remaining salt tablets/product left in the tank.
3. Yes, clean the tank with a disinfectant (bleach) and rinse thoughly. Be sure to rinse the tank...you don't want high levels of bleach in your supply lines.
4. Fill with new/clean softner tablets and return unit to service.
Nov 02, 2009 | General Electric GE SmartWater Household...
Water Heaters Logo
556 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
