Question about Sony Handycam DCR-IP7E Micro Digital Camcorder
Dub a tape that is playing through my camcorder on TV
I hav Sony DCRIP55 camcorder that uses Micromv tapes. If I playback the tape through the tv, am I able to dub the tape to a DVD or VHS Tape using another device. I understand these Micromv tapes are hard to do anything with. I'm thinking if I'm playing through the tv and use some DVD or VCR recorder it should work. Any suggestions or ideas.
    Sniper:
  • 69 Answers
A vcr or dvd-recorder only reads the input signal. It does not care where it is coming from, only that it is there. You would have to run it through the vcr or dvdr for it to read the signal, or copy it to your computer and burn it to dvd.
Posted on May 27, 2009
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: http://www.lg.com/us/tv-audio-video/video/LG-dvd-recorder-RC897T.jsp . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
OUr Samsung SCL 810 Hi-8 Camcorder is flashing Lemg-Eject in yellow, but won't eject a tape. We know it is old, but we're trying to transfer all the tapes to other media so we won't lose them and now the...
I had a similar problem with a Cannon Optura PI and had to send it in. It was better, but I still have problems on occasion. If your intent is to transfer all the tapes to media, I would suggest purchasing Toshiba's DVD Video Recorder/Video Cassette Recorder. Model: DVR620KU. I use a VHS-C Cassette Adapter to play my VHS-C tapes in and the dubbed them to a DVD. Works great. Unfortunately, there is no 8mm/VHS Adapters, since 8mm, Hi8, miniDV are different formats with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with past or current VHS technology. Your best bet would to borrow a HI-8 Camcorder and then dub your tapes to DVD's using the Toshiba machine. Here is a link to the Toshiba machine. http://www.testfreaks.com/dvd-players-recorders/toshiba-dvr620/
Good luck
Dec 28, 2010 | Samsung SC-L810 Camcorder
Copy from vhs to dvd- want to speed process ???
I'm afraid, VHS tape have to be playback on standard speed for good picture and sound and dvd would also burn accordingly.
Noo way for fast dubbing because VHS tape video is analog signal that changed into digital signal in circuits to write on dvd disc.
I hope you understand how this dubbing works.
Nov 08, 2009 | Emerson EWR20V4 DVD Recorder/VCR
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Playback *stops* on tapes where I used Aux input to record
It could be that.. you generally want a timebase corrector to properly record from analog tape to some other medium. But maybe not. Most tape-based devices also include a tension sensor, to detect the end-of-tape. If you're using tapes that are too old, cheap, etc. it could be that you're seeing this triggered.
I recommend trying the same VHS recording with a good quality, fresh tape. If it's still kicking off, you at least know it's due to the camcorder having issues with sync or something on the tape. If it works, blame the old tapes.
It's probably camcorder dependent, but I have done tape restorations using Digital8 and DV equipment, and have never known a camcorder to cut itself off due to dropouts or other problems on the tape -- mine just play through. So I think it's at least possible that it's just the tape.
Jan 20, 2008 | Sony Handycam DCR-TRV103 Digital Camcorder
Creating a DVD from digital tape
i took my unit back to electronic express a chain here in tennessee
the guy was baffled at first
then he got a firewire and plugged it into the ilink place on the front of the unit and it copies my old canon recorded tapes just fine
what happened??? who the heck knows --- somehow the chip that prevents the movie copying was reading my old canon recorded tape as copyright -- this somehow bypasses that
if i am not mistaken you can buy attachments to make sure they fit your type of camcorder - my new sony hi def camera came with one - so i had no problem
here is the other kicker --- WHEN I CALLED SONY AND ASKED IF THE ILINK HOOK UP WOULD MAKE THE DUBBING WORK -- THE IDIOT SAID NO he was dead wrong
i will never buy another sony in my life
i stil have not tried to tape movies to dvd and or vhs --- but i already have the machine so i'm stuck with it
what i'd like to know is which combo units do NOT have the blocking chip
could somebody update on the law about this
thanks
i hope this helps
please let me know
Sep 29, 2007 | Sony RDR-VX555
Can an adaptor be used to play my 8mm tape in my VHS VCR?
With the Sharp Viewcam ®, there's no need to use an adaptor to play 8 mm tape. Simply connect the Viewcam ® to the TV or VCR for playback. You can even use your VCR to make a copy onto VHS tape.
Sep 07, 2005 | Sharp Viewcam VL-A10U Camcorder
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony Handycam DCR-IP7E Micro Digital Camcorder Logo
125 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
