Question about Cyberhome CH-DVR1500 DVD Recorder
DVD won't play with Direct TV
We are trying to make our Go Video DVD work with our new Direct TV. Would you please advise? We have used Go video before this with no problem, but don't know what isn't working, and Direct TV said to contact you. All the wires are hooked up, and the DVD player goes on and off....... just won't play on the Direct TV screen, even when moving our bar to AV1, as was advised.Please help us
Finally............. monkeying around with the remotes, we discovered the basic little remote that turns on our TV was the source of connection. We now hit AV twice, and Go Video works. Voila. It took quite a bit of time to try every possible angle, finally realising we needed to leave Direct TV Remote out of the equation. Just the Go Video remote and our basic little simple remote. Go figure!!!!!
For now, we are good. (knock on whatever:)
Posted on May 28, 2009
#dhb300b DVD player plays only black and white my TV is a JVC HD TV with HDMI cable from driver TV box hook up DVD to TV audivo to audivo video to video set TV to component program DVD to TV but plats
The yellow/red/white cables are COMPOSITE cables. COMPONENT cables are RED/BLUE/GREEN. You can buy those at any electronics store. Your best bet, though, is to stick with HDMI if you can.
Jan 21, 2015 | JVC Televison & Video
Can't change to channel 3 to use the dvd player
Your Vizio TV should have provisions on the rear panel for direct connection of your DVD player. Use those connections and select your DVD player as a video input.
Mar 08, 2018 | Vizio 42 in. LCD TV
Can't change channel 3 to video for dvd playing - video won't come on to use with dvd player
I SUGGEST YOU USE AV CABLES( RCA ) AN CONNECT TO THE AV INPUT OF THE TV
Jun 20, 2013 | Panasonic CT-36D32 36" TV
My color TV has turned black and white however my DVD that is plugged into the receiver plays in color. What's going on?
When one asks questions involving two components it is always necessary to know the identity of both. "Color TV" is kind of generic.
Please define the TV and which direct video input on IT produces B/W and exactly how it is connected and from what specific source unit. Then try swapping something that works, say, the DVD, into the "B/W" input to see if that helps.
If you're using component video cables you could have one loose or defective.
Mar 25, 2010 | Sony STR-DE675 Receiver
How to set my DVD/VHS Govideo player...
If you used to put the TV on channel 3 to watch the videos that means you had this hooked up with the RF RG6 COAX cable. You most likely had this passing thru the cable box and then to the TV, but with the new digital format that may not work any more. A quick fix for this is to take the coax wire from the player and hook it up directly to the TV Cable port then flip your tv to 3 and it should work. If you have an older tv without the newer connections you may have this port already in use with the cable box - if that is the case you may need to get an RF switch or splitter. hope this helps
May 01, 2017 | GoVideo DV2150 DVD VCR
Lightning mcqueen tv and dvd set-up, won't play, have direct tv hook-up
i guess there a built in dvd player on the set and it could play most DVD format.
but if you wish to use another dvd player
hook up the dvd on the tv
video output (DVD) to video input (TV)
audio output to audio input
the find the auxiliary button from either the tv or dvd
Oct 30, 2008 | Disney DTD1363-CAR 13" TV/DVD
DVD Player won't show recordings on my TV screen
put the dvd player on the same channel as you set your Tv when wathing direct tv. and try recording
if you are using rca push on cable yellow,red ,white set to your A,V audio,video channel
when recordining you will be changing channels on the direct tv box
do you have a manual for dvd player read that really good that might help.
Sep 28, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
DVD plays in black and white
Which type of cable are you using to connect the DVD to the TV?
Composite video - yellow RCA?
Component video - red / green / blue RCA?
S-video?
This problem could occur if you are using composite video and have it plugged into one of the component video inputs.
Alternatively it could be that you are trying to play a PAL (European DVD) source into the NTSC input.
Mar 16, 2008 | Philips Magnavox 42MF521D/37 Television
Component Video Problem
The problem is not with your tv it's with your dvd player. You have to go into the setup on the dvd player and change your output setting to component.
Jan 18, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Open Questions:
See all Cyberhome CH-DVR1500 DVD Recorder Questions
Cyberhome CH-DVR1500 DVD Recorder Logo
198 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
