Question about Acer Computers & Internet
All pictures are stretched as well as web pages can't adjust
Acer Mode X203H Everything appears stretched.Aspect is off using a Dell 8250.
    Scholar:
  • 72 Answers
Make sure to use the native resolution of your screen in your video settings (desktop-properties-), I believe it is 1600 x 900. Then it should look ok.
Posted on May 27, 2009
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Picture is stretched on wide screen a circle looks egg shape
Hello
This is an issue because most television programming is produced in a 4:3 aspect ratio. The minority of programming is high definition, which is produced in a 16:9 aspect ratio. Because televisions are made in either a standard (4:3) or widescreen (16:9) format, there is always a conflict with an image being stretched vertically or horizontally. In the case of widescreen televisions, the stretching is horizontal.
Picture Modes
Luckily, most if not all widescreen televisions have a picture mode that allows the user to toggle between a wide (16:9) and standard (4:3) mode. This means that a person can watch non-HD programming in the 4:3 picture mode, and then go to widescreen when watching HD programming. Some TVs have a picture mode that will automatically adjust to the correct aspect ratio. Other people will watch all programming in the wide picture mode, and learn to adjust to watching a stretched picture.
A stretched picture is when a 4:3 image is pulled on the sides to fill the entire screen. People and images end up looking fatter/wider and shorter.
So, what's the big deal?
Some people don't like a 4:3 picture stretched or distorted because it does reduce the overall visual and picture quality. Some people don't like the bars on the side of the screen when a widescreen is in a standard (4:3) picture mode because it looks different.
Solution
There is no fix-all solution for this issue, unless you own a TV that will automatically adjust to the intended aspect ratio. The stretching of the picture is a side-effect, the price we are paying for the better resolution that is digital and high definition. This is definitely something to consider when buying a television, but keep in mind that there is no right or wrong within this issue. It is just the way it is, and there is no way around it unless you buy a 4:3 aspect ratio television.
Hope these lines will clear the issue, if so do rate the solution
Jan 04, 2011 | Televison & Video
How can I adjust the aspect ratio on an acer monitor x203h,so a circle looks like a circle and not an ellipse ? qtom@bellsouth.net
Usually under the menu function there is an aspect ratio adjustment. At that point you're going to end up with an 18.5" monitor with black letter box on each side.
May 22, 2010 | Acer AL2016W 20" LCD Monitor
I have a new Acer X203H 20" wide computer monitor. All of my photos are streched wide, and everyone looks fat. Can I adjust this ?
You need to set the PC video resolution to 1600 x 900 for proper 16:9 wide screen format. But if your pictures that you taken with your camera were not 16:9, IE 4 X 5 then it will be stretched side way to fill the screen.
Jan 07, 2010 | Acer X203H bd Monitor
Everything on the screen appears stretched
If you can, set the Screen resolution to the maximum native resolution your monitor supports by adjusting the slider. to 1680x1050, if you can set it to that, then Windows will automatically display at the proper aspect ratio, and the monitor will not have to stretch anything. Setting your screen resolution to match your monitor's native resolution is, by far, the preferred solution to get you the best looking display.
If that specific resolution is not available, then you'll need to try resolutions that are smaller than that, but ideally with the same aspect ratio. 1512x945, for example, would maintain the same aspect ratio. Not all monitors handle running at less than their optimal resolution well, and it may result in a slightly fuzzy display, but it won't be horizontally stretched. If this fails to fix the problem it could be a problem with your video card
Jan 03, 2010 | Computers & Internet
How do I get a normal image on an Acer X203H monitor?
right click on your desktop and select "properties" (xp)  or "personalization" (vista/7).  In xp, select the "settings" tab, and in vista/7, select "display settings". then adjust your screen resolution to a wider aspect ratio to compensate for the wide screen.
Dec 26, 2009 | Computers & Internet
Just bought Acer X203H. Hooked it up to windows Xp 2003.I make greeting cards with Print Shop 12 The cards or out of shape. They are to long horizonally and to short vertically when I am trying to design...
This is because your screen is widescreen and it is hard to get the dimensions right because when you look at the monitor, the aspect ratio is unusual. You would have to manually adjust your monitor settings (using the buttons on the side of the monitor) to make it look like a normal screen.
Nov 06, 2009 | Acer X203H bd Monitor
Files appear too large on Acer monitor
If you just want to change the size of the font of the web pages you are visiting...all you have to do is hold down the CTRL key while tapping the + or the - key the will increase and decrease the font size.
To check the resolution just right click in an empty area of the desktop and scroll down to properties....you can play around with the resolution there....don't worry, you get 15 seconds to decide if you like the setting before it reverts back to the previous setting.
Sep 11, 2009 | Acer X203H bd Monitor
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
How can I change aspect ratio on acer 19"monitor. The picture is not real ..it is stretched Thank You
In the display properties you can adjust your resolution (aspect ratio).
1. Right click in an open area on your desktop and go to properties.
2. The display properties window will appear. Click on the "SETTINGS" tab.
3. You can adjust the resolution one notch at a time to find the aspect you're looking for. NOTE: by clicking on "APPLY" instead of "OK" you can see the affects of your change without closing the window down. This will allow you to easily change it again without having to reopen the display properties windows over and over again.
Hope this helps.
MO
Jul 13, 2008 | Acer Computers & Internet
Computers & Internet Logo
420 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
