Question about HP Photosmart C4280 All-in-One InkJet Printer
Replacing ink cartridge(s) in my HP Photosmart C4280 All-in-One
I have replaced ink cartridges in this printer before, but this time... . I bought for the first time a large (hp 74XL) black ink cartridge, and did insert it to "clicking" point in the right-hand slot. I also bought a regular size color cartridge (hp 75), and inserted it in the color cartridge slot. The screen message was "Print cartridge missing or not detected". Thinking that the pairing of different sized cartridges could be the problem, I removed the color cartridge, leaving only the black ink one. The same message came up. I turned the printer off, and also the computer. Tried the next day. Removed and reinserted the (single) cartridge - same message.
    Problem Solver:
  • 7 Answers
Had the same problem
I just kept putting it in and taking it out until the msg stopped.
also sometimes when you see this msg you can push the ok button and the printer will go to correct mode.
Posted on May 27, 2009
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
These types of the more severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem", etc.), along with the blinking power lights, etc., typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged (or is performing marginally if issues are intermittent). NOTE: The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings: http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart C4200-C4500 and C5200-C5500a Printers - Diagnostic Tap 41 Test: (verifies electrical health of ink cartridges): http://www.youtube.com/watch?v=8fE-IM4AVMc
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
Posted on Apr 14, 2013
New black very faint
1. hope you have not touched the contacts or head those protected by pink tape.
2. or the ink is dried up
Replacing Cartridge HP Photosmart C4280 All in One Printer
Apr 06, 2016 | HP Photosmart C4280 Aio Printer
My HP photosmart c4280 keeps aligning the cartridge when on!
probably the alignment its not succeed
be cause on of color is missing
check if you see and the 4 colors on paper (yellow cyan magenta black)
if one color is try cleaning , refilling or replacing the cartridge
if you need instructions for refilling check here
http://www.youtube.com/watch?v=Ybj4awp_1ic
May 01, 2010 | HP Photosmart C4240 All-In-One InkJet...
Printer will not recognize new blk ink cartridge.
I think either the printer's scanner(or film as some call it) and/or the carriage is faulty. The signal cable that connects the carriage to the logic board could also be a suspect. Try replacing these items one after another and the culprit will be isolated. Good luck.
Jun 03, 2009 | HP PhotoSmart C4280 Laser Printer
Printer says 'cartridges missing or not detected'
Did you run the print sample page used to align the print cartridges by scanning the test page?
gary.schaut@gmail.com
Jan 05, 2009 | HP Photosmart C4280 Aio Printer
HP PHOTOSMART C4280 PRINTER WONT READ INK CARTRIDGE.
The cartridge is not seated properly and/or the contacts are dirty. Use a cotton swab with rubbing alcohol and gently clean both the copper contacts on the cartridge and inside the cartridge socket. Allow several minutes to dry and then try again.
Nov 12, 2008 | HP PhotoSmart C4280 Laser Printer
Page misalignment (tilt)
delete the drivers of the printer from the pc and again reload it.the new settings will be made automatically.and the misallignment problem will get solved.
Sep 09, 2008 | HP Photosmart C4280 Aio Printer
Hp c4280 printer/print cartridges
Have you checked to make sure that you have the correct replacement cartridge?
In general if it simply will not go into position and you know you have the correct cartridge, then you need to take it back to where you bought it and request a replacement - because it is defective.
Apr 14, 2008 | HP PhotoSmart C4280 Laser Printer
C4280 printer photo cartridge instalation help
The extra cartridge you bought was probably the number 99 cartridge, if I'm not mistaken.
The cartridge actually replaces your black cartridge. Inside of the cartridge has black ink as well as the special photo ink.
I hope this helps
-Ernest
Mar 07, 2008 | HP PhotoSmart C4280 Laser Printer
HP Photosmart C4280 All-in-One InkJet Printer Logo
544 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
