Question about Dishwashers
Dishwasher wont turn on or drain water
My dish washer just quit and the water wont drain from the bottom the light for the wash cycle just flashes
  • 1 more comment
  • hartwigt May 28, 2009
    To clairify the dishwasher is a Kenmore and it is two years old. The breaker is fine, but the light on the cycle board just flashes and it wont even pump out the water from the bottom of the dishwasher. I can't get it to do anything.
  • Collegeless May 11, 2010
    Is it the clean light button thats flashing? If it is then you have a heating circuit problem the button will flash like 7 times in a row then pause. 98% of the time the element is the problem. Write back and I will tell you how to unlock it from the flashing. If only the clean light is flashing
    What kind? How old? Probably the electronic fuse but info is poor
The problem is that you are having an overfill issue. You can fix this by extracting the water from the over fill pan. you will have to take the toe kick off and then take that panel off which should have 3 screws on each side and requires a 20 tork screwdriver to get it off. after that is taking off there is a wiring harness that you will see put your hand right under the wiring harness and feel in the over fill pan if there is water you will have to extract it with a sponge or a turkey baster. when you get the unit put back together then reset your unit by holding the start/stop button for 7 secs and that should fix your issue
Posted on May 29, 2009
  • traceyhall3 May 30, 2009
    when i submitted a solution i was unaware of the unit being a kenmore sorry my solution will not help you...
    so so sorry.
    this solution is only for an asko dishwasher
Why do dishes stink when they come out of dishwasher?
try running the dish washer on the heated cycle and use a quality wash detergent not ordinary washing up liquid
Apr 14, 2017 | Maytag Dishwasher
My Dishwasher has a rapid flashing light
I get the same problem with a pepeating beep warning. Only solution I've found is to switch it off using off button then switch it back on. It waits a few seconds then finishes the program and drains. The dishes still seem to be quite damp after. Hope this helps
Jul 12, 2010 | Hoover Dishwashers
We discovered broken glass dish in bottom of dishwasher with some pieces below the bottom pump area. Shortly after the washer is making a louder noise during operation time. The water pump is quite when...
sounds like you have broken glass in the wash pump you will have to remove pump from sump and clear also check the drain pump.good luck let me know how it goes
Jun 22, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Hotpoint dish washer aquarius
I had the same problem with my Hotpoint Aquarius the eco and fast light flashing, it would go through the pre wash cycle and stop.
I cleaned the filters etc; and it still didn’t work.
I turned the machine off and unplugged it at the mains,
I drained all the water, turned the machine on the side and took the bottom off, I removed the drain pump off the bottom (this was held on with a single screw after taking the screw out slightly turn it to one side as its like a bayonet fit on a light bulb also remove the wire connection and a rubber drain pipe)
Once the pump was removed I could clearly see the impellor it was very tight and I couldn’t spin it after a closer examination I could see a foreign object jamming it I removed this with a pair of tweezers, replaced the pump and put it all back together and it now works perfectly.
I hope this can be of some help.
Peter.
Aug 26, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Indesit D167. When cycle selected no water pumping or filling but 1 & 2 green indicators on.
Tilt your dishwasher forwards. Be aware that water will come out ouf the bottom. Once this is clear your washer should be Ok.
Good Luck
Sep 23, 2007 | Indesit 24 in. DI67 Free-standing...
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Dishwashers Logo
278 people viewed this question
Top Dishwashers Experts
Owen Barnes
