Question about HP Office Equipment & Supplies
Samsung ML4551n printing blank pages
Have changed cartridge and fuser and all the printer will print is blank pages.
    Scholar:
  • 89 Answers
This is according to the support section of the Samsung website for this printer
Dark or Blank Image P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} If your printer prints a dark or blank page, your printer requires service. Click on the create service request below to fill out an online service request form so that we can further diagnose and correct the problem.
You can request servicer for this printer here.
http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Posted on May 27, 2009
How do I fix my Samsung Multi-function laser printer which has started to print smudged pages.
try to stop the sheet just before it enters the fuser and see if the marks are on the paper already. if not then it has to be the fuser if they are them you have another issue.
Jan 15, 2015 | Samsung CLX-3175FN Color Laser All-in-One...
Cannot print 4521f
cartridge inserted poriton ( fuser unit bottom portion ) you can see a small "L" shadped liver fixed with a screw, removed that from there and try with new cartridge.
Jan 15, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Printer Page Prints out but Blank
Hi
Re-check the cartridge installations.
Try disconnecting the printer from power and then connecting it again.
Solved?
Try cleaning the 'printhead'.
Mar 02, 2012 | Samsung ML 2010 Laser Printer
Cp3525dn prints only blank pages new black
Page is blank.
The high-voltage powersupply lower is defective (no developing bias output).
Replace the high-voltage powersupply lower.
Jul 12, 2011 | HP CP3525N Color LaserJet Printer
We understand that your problem is: Sir, iam jithesh from india,kerala.I have one printer samsung ml1210 printer .give the one print blank page coming automaticaly picking second papper blank page coming...
hello ,
first check your toner cartridge. some time your toner cartridge is damage then black print out is coming.
then check your machine printer and faxes ,check print pages status.sometime their have early print outs.
didnt solve your problem you have to replace main board
Jan 18, 2011 | Samsung ML 1210 Laser Printer
Why does my samsung scx5530fn printer constantly prints blank sheets of paper...we have turned it off/on; changed toner and it just decides to starting printing blank pages..anybody can help me i thank...
Please clean the drum and the fuser, also check the toner cartridges if there's any overflown toner powder spilled. The problem is caused when the toner waste tank in the drum is full or overflowing.
Good luck.
Thanks for using FixYa.
Jun 25, 2010 | Office Equipment & Supplies
Black spots lined up on page - cleaning sheet didn't help
To tell if it's the fuser you can do a half way test, what you have to do is print a document, and open the front door of the printer to stop the print job half way through, you should see that half of the toner is fused to the paper and half is just applied to the paper, if you see the black lines on the fused side of the page its the fuser if you see it on the entire page it could be the etb or the cartridge.
possible fix:
This is a common issue with laser jet printer,
Try running cleaning modes under the service menu on the printer, run 5 back to back. if the issue is still showing, try using a different cartridge and run the cleaning mode again. If you have an old cartridge even if its close to being empty you can do an override on the printer to test the cartridge:
1.press ok
2.use the arrows and navigate to the system set up menu
3. press ok
4. print quality
5. press ok
6. override out
7.press ok and again ok to set
This could also be a build up of toner in the fuser assembly, and you may have to adjust the fuser temperatures in the embedded web server. You can print a blank word document (20 pages) and see if you still see black dots, if you do it is likely to be the fuser, set the driver and printer settings to card stock or heavy in order to heat the fuser more than the usual temp and print 30 blank pages this should resolve the issue. if this does not there could be damage to the ETB or the fuser assembly and servicing of the printer would be required.
take care,
Al
eliteprintersolutions@gmail.com
Dec 11, 2009 | HP Laserjet Cp2025n Printer
Printer prints blank on paper
Open the door half way through a page print and pull out toner cartridge. The page should be in the toner cartridige. If you can see the printed image then the fuser is the problem if you see nothing then the toner is bad or has a protective sleeve inside that needs to be pulled out from one of the ends.
Jan 08, 2009 | Canon LBP 800 Laser Printer
167 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
