Question about Simplicity Fashion Pro SW2145 Mechanical Sewing Machine
Bobbin?` Hello! First time working with a Simplicity and the manual is not helping; how to thread a bobbin? Please Help! Tania
  • Anonymous Feb 17, 2009
    janome RX18S bobin thread will not pickup
    gary
Dear Guest,
you can find the manual on this link:
http://www.simplicityhomecare.com/ftp/whitepapers/SW2145.pdf
Posted on Sep 05, 2008
  • fibrofogger May 24, 2011
    That link is no longer available.
Tania,
I'm trying to find a manual for a Simplicity SW2145. If you have any suggestions I greatly appreciate some help.
Thank You,
J. Eise
Posted on Aug 19, 2008
Singer Tradition - my bobbin winder has stopped winding so I have to wind thread on manually.
Check on a standalone bobbin winder called "Sidewinder." Make sure it is compatible with your bobbins--some bobbins won't work on the Sidewinder. If it is compatible, then for ~$30 you can wind all your bobbins. (I have one that is powered by battery or by electricity.)
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Simplicity SideWinder Bobbin Winder Walmart com
Jul 16, 2017 | Singer Sewing Machines
How do i thread the bobbin on simplicity fashion pro sw 2145
normally counter clock wise for bobbin, usually the first thread holder is used and the 2nd is used for double needles. here is a link for parts
Simplicity SW2145 Parts
Dec 06, 2014 | Simplicity Fashion Pro SW2145 Mechanical...
Hello I'm having a problem with the top thread connecting with the bottom after I thread both and turn the wheel for them to connect nothing is happening
Try changing the needle
Try rethreading the machine top and bobbin
Make sure the bobbin is turned the correct way In the bobbin case
It's possible that the machine needs to be checked for a timing problem
Aug 18, 2013 | Simplicity Performer S110 Mechanical...
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
I have a Simplicity Embrodery Machine, and the needle keeps breaking. I have checked the bobbin, changed the bobbin, changed the thread, changed the pattern. It sews for about 5 seconds and then breaks.
It could be the thread is hanging up and breaking the needle.
Check the thread spool for nicks - turn the spool so the thread is feeding from the bottom of the spool.
Watch the thread as the machine stitches, if the thread is pooling at the base of the spool, use a thread net on the spool.
Open the needle plate and remove the bobbin and bobbin case - clean out any lint or thread snips that may have accumulated there - do this often to help the machine work as it should.
Feb 19, 2010 | Simplicity Sewing Machines
I have a Simplicity Fashion Plus
Possibly your thread tension is too loose--or your machine may need cleaning in the bobbin area.
Apr 11, 2009 | Simplicity Fashion Pro SW2145 Mechanical...
Raising the bobbin
Use a SA 156 metal bobbin (ebay, 20 of them for $8.99 free shipping) and make sure the bobbin thread is turning the right direction, read you manual or call singer at 1-800-4singer
Aug 23, 2008 | Singer 3116 Simple
How do you thread the machine, top and bottom, please.
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin.
NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  1. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  2. Slide bobbin cover back into position.
Upper threading:
  1. Turn the handwheel toward you to raise the take-up lever to its highest position.
  2. Lower the presser foot.
  3. Place a spool of thread and spool cap on the spool pin.
  4. Place the thread into the first thread guide at the top of the machine.
  5. Bring the thread down the right slot of the threading path, then around the tension dial. Push the thread tension release lever and pull the thread up so the thread is secure in the thread tension dial.
  6. Bring the thread up the left slot of the threading path and through the take-up lever from right to left.
  7. Bring the thread back down the left slot of the threading path and into the needle eye from front to back. (Clip the thread end with sharp scissors fro easier needle threading.)
Raising the bobbin thread
  1. Make sure the presser foot lever is raised.
  2. Hold the end of the needle thread with your left hand. Turn the hand wheel toward you with your right hand until the needle goes down once and comes back up, stopping when the needle is at its highest position.
  3. Gently pull up on the needle thread. The bobbin thread, looped around the needle thread, will be drawn up through the needle hole.
  4. Push the thread tension release lever and pull about six inches of both the upper and lower threads toward the back of the machine, placing them under the presser foot.
You can obtain a copy in pdf format for free at:
http://www.simplicityhomecare.com/ftp/whitepapers/SWSP2-english.pdf
Dec 10, 2007 | Simplicity Sew Precious SWSP2 Mechanical...
How to properly thread the bobbin
  2. Pull about 6 inches of thread out from the bobbin. NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  3. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  4. Slide bobbin cover back into position.
Sep 21, 2007 | Simplicity Sew Precious SWSP2 Mechanical...
Simplicity Fashion Pro SW2145 Mechanical Sewing Machine Logo
578 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
