2003 Ford F150 Regular Cab Logo
Posted on May 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tempature/compus wont turn on or show up
Electical I think? Tempature/compus console will not light up anymore ?
steve titus
Level 3:
President:
  • Master 277 Answers
  • Posted on Aug 18, 2010
steve titus
Master
Level 3:
President:
Answers
277
Questions
0
Helped
209669
Points
1409
The overhead console is quite prone to internal failure. We offer a reasonable repair service with a lifetime guarantee. Check it out: www.autoclockrepair.com
Tempature guage only going up a quarter of the way.Engine light on.It happened all the sudden when it got 20degrees in florida
I was going to say it should be covered under the factory warranty, but not if its a 2000 Ford. I would check the thermostat.
Tempature sensor for outside not working
Car should still be under new car warranty so take it back to the dealer for replacement of the faulty part
Engine starts when cold wont restart after operating tempature
Check the coolant temperature switch. Maybe faulty
1helpful
My 2006 ford explorer 4.6 v8 has a red warning light for high tempature come on and the tempature gauge shows that car is running hot.when this happens the a/c then blows hot air.if I turn off the a/c then...
Check for a broken belt. If your water pump is not turning, it will cause the engine to get hot and the radiator wont steam. If a belt is broken it would also explain the no A/C condition.
2answers
I had my 2006 grand prix fix 3 times for the tempature gage and stilss the gage goes over the 3 line
I think you should start thinking it might not be the gage itself but >Problem with the wires in the circuit itself Also warm car up take a thermometer & check coolant tempature cross referance with temp gauge in the car
2helpful
2001 Alero- heat gage does not show heat tempature. Blows warm air.Engine felt cold after a 50 mile trip. Out side tempature 20 degrees fernaheight.
with winter being here you might want to consider having a new thermostat put in to increase the heat in side,but make sure your radiator is full when engine is cold
My 2000 VW Cabrio tempature light is flashing. I
you will probably need to replace the tempurature sensor it's self the car is not actually getting hot.
Temputure and oil change
either you have a bad wiring prolem or you need new gadges
Car tempature goes up only on hills.
I think your cooling system has air in it, Try and find a place around the thermosat that can be opened a small valve it may just look like a nut, with your car running and radiator cap off, turn the heater on and fill with coolant till it runs out the valve with out air, then top off the radiator to full. also top of the coolant overflow tank. I think this may solve your problem. Merry Christmas!
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
