Question about Netopia 2247NWG-VGx Wireless Router (2247NWGVGX)
Explanation needed on how to open ports
Please explain how i open ports on my netopia router needed for xbox live
  • CompuFirm
    CompuFirm May 11, 2010
    What is the model and make of your router?
    President:
  • 623 Answers
Here you go:
http://portforward.com/english/routers/port_forwarding/Netopia/2247NWG-VGx/Xbox_Live_360.htm
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on May 31, 2009
Xbox360 live setup
You need to forward these ports on both your router, and computer aswell as firewall you got one of those.
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
You might aswell need to open 1863 (UDP and TCP) if you want to use video chat for the kinect.
Listed ports need to be forwarded when connecting to XBOX Live
A more detailed guide to setting it up is available here: http://support.xbox.com/en-us/xbox-360/networking/network-ports-used-xbox-live
Nov 15, 2013 | Netopia 2247NWG-VGx Wireless Router...
I play call of duty and my NAT type is strict how can i change it to open?
you need to open the following ports up on your router
Xbox Live 360 requires you to forward the following ports: 53,80,88,1863,3074.
either open the ports for all devices or give your xbox a static ip and open the ports above for it.
Mar 14, 2011 | Netopia ADSL2+ 11G WIIRELESS ROUTER 400MW...
I need to make sure port 3074 is open for xbox live but dont know how to do it.
You can use the netstat -a command to find out which ports are open on a local Linux/Unix or Windows system (Figure 1), but netstat can't be used remotely across a network. netstat.gif
FIGURE 1: The netstat command can be used from the Linux or Windows command line to check on
open ports on the local computer.
If 3074(TCP & UDP) port is not opened on the router, refer: http://www.netopia.com/support/hardware/technotes/CQG_025.html for further step-by-step assistance.
For any further help/support, revert!
Thanks for asking..
Arvind S Iyer
Sep 26, 2010 | Netopia 2247NWG-VGx Wireless Router...
I am trying to get xbox live working on my xbox 360 console but I need to open some ports and I dont know how , how do I open the ports ? I need to open the port 3074 and I need yo use (UPnP) because I...
Okay so Here is the very simple solution. Go to your router page (192.168.1.254) and select Custom Services. Delete every port opening service you have made. Then Define a Custom Service lets just call it Xbox A and Open ports 80 - 65535 for TCP with the base host port 80 Do tthis twice for both TCP and UDP options. Enable the services on your Xbox (It needs to be Connected and have a static IP adress) It can take about 15 minutes to open all the ports to be patient. Your Xbox also needs to have a static IP adress. Lastly set the routers firewall on low and give it a shot. It worked for me!
Jun 26, 2009 | Netopia 2247NWG-VGx Wireless Router...
Cant connect to xbox live
make sure that your xbox is acctually getting an ip address, by default it should be a 192.168.0.xx number and the gateway should be 192.168.0.254
If however your xbox tells you that its ip address is 168.xx.xx.xx (a private ip address) or if it is simply 0.0.0.0 it would sugest a cabling problem.
However if the network troubleshooter finds no faults and you are still unable to get into xbox live try setting up a PPPoE connection using the username eircom and broadband1.
Alternatively,If you click on Firewall in the Netopia admin page, and set the security level to Low, xbox live would suddenly start to work.
******Also add UDP ports 88 and 3074 if nothing works.On a netopia 3347 you can get this option in the NAT option.U have to enter the port numbers and the service name(xbox).
Hope it works for you.
Apr 05, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Opening nat
You just need to enable port forwarding for the ports that the xbox live is using, specifically these ports:
UDP 88
UDP 3074
TCP 3074
You then assign a the static IP you have set on your router, subnet, gateway and dns on your xbox and that should allow your xbox live to work properly with your router.
Aug 21, 2008 | Computers & Internet
Xbox live
Hello!
Yes, the netopia router will work with xbox live. you just have to configure some settings on your router.
To configure your router for Xbox Live try the following steps below:
step 1: Open an Internet Explorer page. in address bar type your router ip address, That should take you to the Netopia's settings page
Step 2: On the menu to left click Firewall, set it to Low and Save Changes
Step 3: On the menu to left click Expert Mode, then Yes, enter Expert Mode
Step 4: On the menu to left click Configure, then Advanced, then NAT
Step 5: Where it says Service Name, scroll the list down to Xbox Live Games, click Enable and then Enable again
Step 6: On the menu to left click Configure, then Connection.
Step 7: In main page scroll down to the UPnP and put a check in the box. then Save
It should then restart the Netopia, and when it comes back on in a few seconds your XBOX LIVE should be good to go. If you are still experiencing problems accessing Xbox Live your Netopia may require a firmware upgrade.
May 10, 2008 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
Xboxlive on netopia 2247nwg
Have you tried http://portforward.com/ i've had alot of problems with this router fixed my xboxlive issues with portfoward but am having problems with my blueface voip
Feb 26, 2008 | Netopia 2247NWG-VGx Wireless Router...
Still my xbox live update test fails...
Netopia's Modem my also act as a Router protecting your system from internet traffic! You need to check your model to insure what you have. If it is a Router you will have to Contact Netopia in regards to configuring Pin Hole on the Router to open the gaming ports on the Router.
Coach "J"
Have a great 2008!
Jan 07, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Xbox live test fails and so does update
you need to open the port that the update is trying to go through. the easiest way is to turn your firewall off, but this opens up your security. another way is to forward the correct port through port forwarding on your router. findout which port xbox live uses and put in the information to the router
Jan 06, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Netopia 2247NWG-VGx Wireless Router (2247NWGVGX) Logo
270 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Elise Lacoursiere
Elise Lacoursiere
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
