Question about AEG Lavamat 72640 Front Load Washer
Indesit WG1235T O
WASHER WAS WORKING PERFECT. ALL OF A SUDDEN ON A NEW CYCLE IT STARTED FILLING UP WITH WATER WHEN IT BLEW THE HOUSE FUSE. AFTER REPLACING THE FUSE IT BLEW IT AGAIN 5 TIMES BY ONLY SWITCHING IT ON. FOUND THE THERMOSTAT CONNECTERS BLACK, LIKE THERE WAS A SHORT CIRCUIT, CLEAN IT UP AND CHECK IT WITH COLD AND HOT WATER AND IT WAS WORKING GOOD. REINSTALL IT AND TRY AGAIN AND MACHINE DID NOTHING. IN NONE OF THE CYCLES, DOOR DIDN'T LOCK, NO WATER FILLING, NO SPINNING, ONLY THING WORKING WAS DRAIN PUMP ACCORDING WITH CYCLE. DISCONNECT THE HEATER RESTART AND THE SAME THING. IT'S NOT BLOWING THE FUSE, BUT IT'S NOT DOING NOTHING. WHAT MAY BE THE PROBLEM?
    Champion:
  • 249 Answers
I would say the doorlock switch is faulty
Posted on Dec 21, 2007
Why doesn't it fill and perform any wash cycles?
If you are saying that a house fuse blew out then the question is why did that happen? If the washer shorted out and blew the house fuse then you have to work on the washer to see why. It might have been the transformer in the washer power supply. If the fuse blew during a storm then it might be lightning damage and that would mean replacing the power unit and the computer in the machine.
May 24, 2015 | Washing Machines
Indesit washer not draining
Check filter not blocked and pump turning freely
May 09, 2012 | Indesit Washing Machines
Indesit washer dryer starts cycle, waters then
If the heater element is not working, then the cycle will not progress.
You need to test the element to see if it is o/k.
Hope this helps.
Jan 05, 2010 | Indesit Washing Machines
Indesit WIXL85 water level
On a normal wash cycle, you will see very little if any water sloshing around, this is quite normal on todays washers.
You shuold see a lot more on the rinse cycle, as it is a higher fill.
It is usual to more less fill the compartment with powder, unless you are only washing a few items, then half fill it.
Hope this helps.
Dec 19, 2009 | Indesit W 123 Front Load Washer
No rinsing water coming in
There are 2 versions of this washer dryer, a cold fill only one and a hot and cold fill version.
If it is the cold fill version, it could be the water level switch that is malfunctioning, cutting off before the correct level is reached, or a sticking water inlet valve.
If it is the other version, then the same thing applys, plus the coil on the valve that controls the rinse cycle could be open circuit.
You need a meter to test the valve coils for continuity..
Make sure that there is actually cold water to the valve, if it is a hot and cold fill model.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Indesit W 123 Front Load Washer
Indesit wd125 drum wont turn
check your pump it may not be working
Dec 18, 2008 | Indesit W 123 Front Load Washer
Indesit WI 101
Check the fuse in your washer's plug.
Sep 30, 2007 | Indesit W 123 Front Load Washer
AEG Lavamat 72640 Front Load Washer Logo
411 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
