Question about Dell U0636 Mouse
Frozen touch mouse
I have a dell vostro a360 laptop and the mouse on it has been frozen for a few days. I have rebooted and tried all sorts of troubleshoots on the machine. I have tried the function buttons too. All to no avail. Any help much appreciated. Thanks
    Scholar:
  • 174 Answers
Get your laptop utility CD/driver. Borrow a USB mouse and then you access the laptop driver so you can reinstall the touch pad. That should work (it worked for me).
Then before ejecting your utility disc/driver, you copy the touch pad folder and then paste it to your desktop so the next time you'll need to reinstall your touch pad, you can readily access it.
Posted on May 27, 2009
How to perform scroll function in laptop without mouse in Dell vostro
Your touch pad should do the trick.
They are called "Gestures". They are set to active by default. If it's not. Go to "Control panel > click "mouse" and find "touch pad". There you will find "Gestures". Activate it.
1. Put two fingers on the touch pad and try to move both fingers up or down. Learn how to scroll up and down.
2. Move those fingers side ways. This should do the "Horizontal" scroll.
There are others, like:
Put one finger stationary and rotate the other. This rotates the orientation of the object.
Try it and good luck.
May 23, 2014 | Dell Vostro 1510 Laptop
Mouse Pointer of Dell vostro 1014 laptop touchpad is working in reverse i.e. while moving finger on touchpad towards right the pointer move in left direction & vice versa
Hi, the laptop touch pads have an icon near the clock or u can find it on the control panel, there is a check mark that said" mouse reverse"or "mouse look up" or something like that,uncheck it to work properly and download the latest driver,
kind regards
Apr 17, 2013 | Dell Vostro 1014 Laptop Computer
Touch pad turn off
Hey Harvery,
To turn off the touch pad on your system you can right click on the touchpad properties and choose touchpad properties located on your taskbar to the right. Once you have it open you will see where to turn the touchpad off.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Apr 02, 2013 | Dell Vostro 1015 Laptop
My Dell Vostro 1014 laptop's touch pad does not work!! The buttons work fine but I'm having problems with the pad. The drivers are up to date and the application used to control the touchpad c
If you have a external mouse, or you can borrow, go into device manager to see if the pad is enabled, if okay! try a system restore bringing the computer back in time before this happened, if still no luck the sensor pad maybe defective, the last option a complete recovery of the operational system to factory setting, this will prove if the sensor pad is defective, or wire ribbon might have come loose from the motherboard.
Apr 01, 2012 | Dell Vostro 1014 Laptop Computer
My dell vostro 1520 laptop touch pad not working
Hi augusmana,
Follow the steps:
1. Go into Control Panel, click on Mouse. Mouse properties should pop up with Dell Touchpad on top.
2. Click to change the properties. Look to make sure touchpad is enabled and all settings are as you want them.
Hopefully that will take care of your problem
Hope it helps.
Thank You for using Fixya.
Sep 07, 2011 | Dell Vostro 1510 Laptop
I have a Dell Vostro 1510 and I want to disable the touchpad.
Right click on the open space of the desk top > Personalize > Mouse Pointers (yes, mouse Pointers ) > click the red pointer to change touchpad settings > Button settings > disable both Touchpad and Touchpad buttons > OK
Jul 29, 2011 | Dell Vostro 1015 Laptop
I have a dell vostro A860 laptop.not working to Touchpad. How to Fix Touchpad Not Working in Laptop
What you can initially do is to update the driver.
  1. Press on the windows key + R. A run box will appear.
  2. Type devmgmt.msc then click on ok. The device manage will appear.
  1. Click on the plus sign besides mice and other pointing devices.
  2. Right click on the item that will be pertaining to your touch pad.
  3. Choose update driver and let the internet work for you.
If this does not work, you will need to totally reinstall the driver.
  1. On the same screen (device manager) right click on the touch pad driver again, the choose uninstall.
  2. follow the prompts for uninstallation. You might wanna uninstall any mouse related drivers as well (these application can also cause conflicts thus causing your touch pad not to work)
  3. download the touch pad driver available from the link I provided below.
  4. follow the prompts for installation.
  5. restart
Dell Vostro Driver list (click here to view all available drivers for your portable system)
Dell Vostro Touch Pad Driver (click here to download the touch pad driver)
It this does not work, you will need to call Dell Technical Support to have the laptop serviced. That is if the portable still has warranty. If not, then you will need to buy a USB mouse as a replacement.
for additional information visit Dell support website: support.dell.com
Jul 18, 2011 | Dell Vostro A860 Notebook
Touchpad and mouse Vostro 1720
No any software problem but fist you tray USB mouse and that's mouse Is working minis no problem in sotward so after you Chang your laptop touch pad .....
Mar 01, 2011 | Dell Vostro 1720 (bqcwd1z3) PC Notebook
Dell U0636 Mouse Logo
157 people viewed this question
Alun Cox
