RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Posted on May 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RCA light comes on and then goes off. Tv doesn't turn on
I have an RCA d52w20 and a few weeks ago I noticed it took a few times to get the TV to turn on. I will turn it on and the screen stays black but I will here a click and the green light will come on then go off and then another click and light and then they both go off again. The TV never actually shows a picture or sound. I can try it over and over and over and over and eventually 20-50 tries it will actually come on. My wife actually refuses to turn it off now. I work with computers for a living and am pretty good at hardware but have never worked on a TV. What does this issue sound like? I will turn it on and the screen stays black but I will here a click and the green light will come on then go off and then another click and light and then they both go off again. The TV never actually shows a picture or sound. I can try it over and over and over and over and eventually 20-50 tries it will actually come on. Plus does anyone have a service manual with diagrams fot this series D52W20BYX1
Sonny Berry
Level 3:
  • RCA Master 8,617 Answers
  • Posted on May 28, 2009
Sonny Berry
RCA Master
Level 3:
Answers
8617
Questions
Helped
1721644
Points
23750
Replace CP150 and CP114 you can get them at the following link they also have the ITC222 service manual which is listed under Thomson as Thomson makes your TV for RCA. The Capacitors are listed under the RCA parts and they do send instructions with pictures of where the capacitors are located as well as how to remove the board.
http://servicemanuals.vstore.ca/
1helpful
2answers
Tv tries to turn on 3 times
Thats usually caused by bad capacitors or a bad flyback. www.tvrepairworld.com has the capacitor kits and the flyback kits available for your model.
D52w20 RCA Projection wont turn on
On the Deflection board CK 3 fuses they will be in a roll on right side of Flyback Transfomer FL231 they look like small rectangler brown caps they are fuses Then Check 3 capacitors cp150 2200uf 16v if puffed up on top it is bad replace cp114 and cp120 220uf 35v.
I have rca d52w20 rear projection hdtv moniter-does not come on
i just changed the 3 capacitors cp150 2200 16v and cp114 35v and cp120 35v. the set seems to working good now. not to hard to do if you know how to solder. take the back off the tv and they are on the board that is on the bottom left.
Rca d52w20 52 IN
Bad capacitors on Power/deflection board cp150,cp114,cp120 capacitor cp 150 2200uf 16v, cp114&cp120 220uf 35v
RCA 52" D52w20 problem
My goes off a few seconds after turning it on. It does make a funny sound, like static on the tv.
2answers
Won't turn on
those tvs will try 3 times before completely shutting down. you can try and take the back off and check CP150 it is a large capactior located near the middle of the board on the left hand side(looking from back) if it looks and feels like the top is vented or puffed out then that could be the problem. if not i suggest having a qualified service tech take a look because there are too many things that could be the root cause.
1helpful
3answers
RCA D52W20 cold start issue?
i am looking for an owners manual for the d52w20, can anyone help me out here.
[email protected]
Is this your set?http://tv.rca.com/NR/rdonlyres/A2ED8EB5-A0AF-401F-A380-3CB61D5EBEB1/0/D52W20_222Chassis.pdf If it is, there could be a bad solder connection in the start up power supply or there is a resistor that will get loose or change value. It gives the power supply the start up pulse from the flyback transformer. there are no user replaceable parts inside this set, and the longer you wait to get it serviced, the more its going to cost. Unless you have a service manual and understand how the SMPS works, please play it safe and call in a pro to assist you in this repair. Good Luck Please do not forget to rate this thread.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
