Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Gas stove ignator makes
Even though i put off my GE GAs stove top, the ignitor makes tik tik noise and ignition spark appears continuously all the dials are off and it still clicks a single click, and sparks, every 5 to 8 seconds.
    Problem Solver:
  • 13 Answers
Sounds like you got the electronic ignitor valves wet try blowing them out with air or don't use for a few hours
Posted on May 27, 2009
Kitchenaid superba oven
It is very possible that moisture from the cleaning has caused the ignition switches to make enough resistance to cause the burners to spark. It usually goes away after the stove has dried out. If it continues after a day or so one or more of the ignitor switches may need replacing.
Nov 20, 2013 | Ovens
When I on my gas stove it's on properly bt the button gone sounds regularly like tik tik tik
Sounds like, the automatic ignitor may be stuck in the ON position... It may be continually trying to Light an already lit burner...
Raise the top, and listen and watch the Ignitor {s} to see, or hear if it is continually sending a spark... If so, and you can't see a way to fix it, then Replace it...
Nov 28, 2012 | Kitchen Ranges
Stove top burner ignitors will not turn off
This tip I wrote to help people with the problem of the spark not shutting off...the clicking non-stop is a common problem.
Gas Range2_bing.gif Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 30, 2010 | KitchenAid KGST307 Gas Kitchen Range
Stove Ignitor makes tik tik sound and the sparks continuously
may be a loose wire on the spark ignitor ceramic or if you run via main electic it may be your spark generator
May 14, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile igniter sparking continuously after water spill
The continuous sparking stopped after few hours. Looks like the water dry up and that fixed the issue.
Mar 19, 2009 | Jenn-Air JGC8536 Gas Cooktop
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE ZGU650 EM1BG Gas Cooktop
On any range I've seen with electronic ignitors, the valves have a position that closes a contact to turn on the ignitor and manually moving the dial to the 'Hi' setting opens the contact again and the ignitor ceases to spark.
You don't mean the ignitors run even when the burners are off, do you?
I'm surprised to read that this has been happening for 'years,' the transformer for the ignitors must be really tough to withstand that and it doesn't sound like an electrode or transformer problem but rather a contact not opening as it should or you not advancing the control past the ignite point.
Oct 18, 2008 | GE 30 in. JGP336 Gas Cooktop
Igniter continuously clicks
I had this problem. It was caused by the burner "thinking" the flame had turned off--it was clicking because it was sparking to re-start the flame from the gas. I was able to fix it by tightening a flat, thin nut at the top of the burner.
Apr 13, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Igniter
Does the knob control both the gas and spark, try turning on the knob only, if it starts to spark right away then it is possible that the switch is bad. because most of these units are designed where you turn on the gas then push in and hold the knob to ignite then release and spark should stop.
Dec 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
My GE Xl44 gas burners will not ignite
If there is no spark at all then the circut is not being completed. The main problem that I had was that there was no ignition even though there WAS a spark and gas. I cleaned out the small pin hole sized inlet on the gas valve with a needle. This allowed the gas to enter the feeder and distribute the gas towards the ignition spark properly.
Also it is very important that the range be level. If there is a pitch to the range the gas may be exiting the distribution cap improperly resulting in improper distribution!
Oct 18, 2007 | GE JGRP17 Gas Single Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
459 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
