Adjusting thermostat temperature
I have 3 m ceiling and the air conditioner is about 20cm from the ceiling and the max temperature is reached quickly and the thermostat turns unit off or it blows cool air. while at the lower level it is still cool and warmth in room never reached.I want to lower just the thermostat so temp doesent reach max before room temperature is comfortable. can this be done?
  • 44 Answers
Nope. Try bouncing the air off the ceiling instead of pointing it towards the floor. You know the vent grille should be adjustable. The air is just recirculating back into unit and short cycling stat. Create a barrier between supply and return!
Posted on May 28, 2009
I have a rooftop ac unit on my popup that was replaced two years ago. The unit works fine but I would like the fan to shut off when the compressor isn't running. Is there a switch for putting the fan...
Please describe your controls. Does it not have low fan, high fan, low cool, high cool on the dial at ceiling? If yes, low cool or high cool setting should shut it down when temperature is reached via thermostat dial.
Aug 29, 2011 | Dometic Rooftop RV Air Conditioner
Air conditioner will not stay on a selected temperature in cool mode for more than 3 seconds. For example, you can change the temperature to 70 degrees and it will blink for 3 seconds and move back to 88...
Don't you just hate electronics? The control might be sensing a bad thermostat. Especially considering that the manual says that the max temp is 86 (not 88).
Jun 03, 2011 | LG LP0711WNR Portable Air Conditioner
I have Marquis hot tub, Leisure Series, The Spirit, Model ESLS30X, serial # 0890608. My in-laws gave it to us. It's about ten years old but still works reasonably well. The one issue is water...
If you found a solution to this problem, can you tell me what it was? I have the same thing. Its a Marquis Spririt and it just doesn't get hot enough. There must be a way to "trick" the thermostat into letting the heater run longer
Dec 10, 2010 | Heating & Cooling
We have a Goodman Furnace and Air Conditioner approx 7 years old. When I put the Cool on thermostat and lowered the temperature for the air conditioner to come on the furnace fan started but the outside...
You are right. The outside unit starts quickly. The humming will either be the evaporator fan or the AC compressor itself. If you can reach into the evaporater fan with something narrow and stiff you may be able to see if the fan turns. Sorry for the trouble you are having.
One or the other is trying but unable to start, hence the humming.
Wayne
Jun 11, 2010 | Heating & Cooling
Compressorruns fora short time
the thermostat controlling your unit likely has a window type of programming for digital or mechanical adjustment for older style thermostat that sets a minimum off temp and a maximum on temp, there may be an adjustment to set the range it operates at, otherwise you may have a defective thermostat controller unit and it needs replacing also insure that the temperature sensing element is clean and free of dust build-up and your filter is clean
Apr 28, 2010 | Dometic Rooftop RV Air Conditioner
I have a 2005 Pilgram 27 foot 5th wheel. My Duo Therm AC unit makes a ticking sound from the ac unit itself when it's not running. Shutting off the Duo Therm analog thermostat does not stop the ticking...
It's obviously on the 12voltDC circuit of the AC unit. Sounds like thermostat, or a relay in control box is faulty or bad connection. If you remove cover on ceiling assy., you should be able to hear it in the control box. There should be a model number on the ceiling assy., get back to me with that number and I can better pinpoint which relay. Also, try moving all thermostat buttons and temperature controls back and forth quickly to see if it may clean off a dirty circuit in thermostat as well. Make sure your AC hydro breaker is off when working with ceiling assy. just to be safe.
Mar 26, 2010 | Dometic Rooftop RV Air Conditioner
Compressor won't cut when temperature is reached
Change out thermostat. It may not be properly adjusted for cutoff. The best type of thermostat would be a digital programable. They are expensive but well worth the money.
Good Luck
Dave
Aug 26, 2009 | Heating & Cooling
Electric furnace won't shut off
It sounds like a bad or badly miswired T-stat
Jan 20, 2009 | Goodman CLQ36AR49 Air Conditioner
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Heating & Cooling Logo
96 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
