Question about GE RM94906 Remote Control
Code tv: sansei tvr 2011 and code tv: sanyo ctp 6737
Code sansei tvr 2011
Will a sansei urc-501a remote have a code for a bauhn tv model actios fullhd/led/lcd atv40-014
One way to find out is to use the code search function in your Sansui (?) remote to find something that will handle your Bauhn TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Sep 16, 2016 | Televison & Video
Size of screws for sanyo 55 inch LCD to mount base to tv
After repeated trips to the hardware store and more calls to Sanyo and conversations with supervisors...depending on the year of the TV....2011 requires M5x16. The next year model requires the same size that bolt to the back of the TV. I had to elevate my request for the size of the base screw of the 2011 model all the way to engineering before I got the answer. They changed the configuration in the 2012 and later models.
Jan 02, 2014 | Sanyo Dp55441 TV
Download honestech tvr saa713x pci tv card
could not initialize the cupture device ats hai tv chalta nahi hai
Aug 26, 2012 | Philips SAA7130 TV Tuner/FM Radio/Video...
Need a manual for an old sanyo tv,model number ctp 3104 .Do not know how to tune it in .thanks sue.
The silver around the knob on the right handside is for tuning and the knob in the middle is for fine tuning the signal in,
Hope this helps :-)
Aug 10, 2011 | Televison & Video
Where is the mode button so I can sync the remote and the tv? what is the 3 digit code
Hello
Three digit universal remote codes for Sanyo are:-
004/ 013/ 049/ 108/ 110/ 180/ 209
Four digit universal remote codes for Sanyo are:-
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON the tv by its front panel power control switch [Not by remote control handset] each time before an other code.
OK
Wish you Happy Peacefull 2011.
Dec 30, 2010 | Sanyo DS32224 TV
I have a rca 311 w to program into a sanyo tv
Code For Model RCR311W
Code 1004 for Sanyo TV Code 1048 for Sanyo TV Code 1049 for Sanyo TV Code 1073 for Sanyo TV Code 1080 for Sanyo TV Code 1162 for Sanyo TV Code 1169 for Sanyo TV Code 1180 for Sanyo TV
Jun 05, 2009 | RCA RCR311B Remote Control
Code search for Panasonic Tv on Universal remote
i need code for panasonic tv with zenith remote control
Jun 28, 2008 | Televison & Video
Problems with LifeView TVR
try installing it in different pci slot ,also you can try other drivers,
try chrislite tv instead of tvr, also make sure you ahve no yellow marks in device manager.
Nov 05, 2007 | LifeView FlyVideo 2000 / FM (701013821030)...
GE RM94906 Remote Control Logo
189 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
