Question about Kitchen Ranges
I AM GETTING AN F-1 CODE FLASHING. i ASK THE SAME QUESTION AND WAS TOLD I NEEDED TO REPLACE PART #WB12K19 WHICH I DID AND AM NOW GETTING THE SAME CODE WITH THE NEW TIMER.
  • 44 Answers
F1 codes have to do with either the main control or the sensor thats inside the oven or both. Its a reading each other error for temperature
Posted on May 28, 2009
2003 kia sorento check engine light no symptoms
Scannign the PCM in order to know exactly what is the fault code that cause turn on "check engine light"; just with this fault code could send other details; ask your dealer about this.
Hope helps.
Feb 20, 2013 | 2003 Kia Sorento
Code 16518 on mk4 golf
Can't by pass as oxygen sensors control your fuel
I suspect your exhaust converter has failed & the car has
been running rich for years & ruined it
Wouldn't your repair guy be able to solve all your issues,
after all you were at a shop for some work
Sounds like they sold some service instead of diagnosing
the reason you were there
Feb 10, 2013 | 2001 Volkswagen Golf 2.0
After a brown out, the front panel shows 88 and 08 (flashing). Nothing happens when i press any of the buttons. The refrigerator seems to still be cooling.
Wow, Grumpit...your solution worked perfectly (Press the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 seconds--it will beep and reset the panel.) What a racket both GE and local repair places have going...they both told me I needed to replace the entire contol panel!! GE needs to start telling people this along with unplugging the fridge when you call in and ask about the error code.
Jan 04, 2011 | Samsung RF267AEBP (258 cu ft) Bottom...
I get a flashing E-1 error code
I keep getting the flashing E-1 error code...
In the manuel for trouble shoot I do what it ask and there's no change. It will run for 2 or 3 minutes then just start flashing " E - 1" code. Need help Please.
Jun 08, 2010 | Whirlpool GEW9200L Electric Dryer
ACURA TL 2000 check engine light is flashing
Instead of the auto-zone trip , take it to the dealer !
Mar 07, 2017 | 2000 Acura TL
Maytag Gemini Electric Kitchen Range
Codes are correct .The back needs to be removed and your sensor is a 2 wire part ,The easiest way to make sure you change the right one is by turning oven to on and run a voltage test at each end of the thermostat.Rule follows : If oven is on you should have 115 -120 volts present and make sure you have the same at the other end of thermostat ,if you have the volts at one side and not the other than that is the bad thermostat. Please rate this !
Aug 15, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
67 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
