Question about JVC GR-D271 Camcorder
Eject does not work, can't hear motor working
Push button, can't even hear the motor working.  Took battery off and started again like suggested with eject button on, didn't work.  How can I get the tape out, and also is the motor broken?
5 Suggested Answers
SOURCE: unit in safeguard mode
I have a DVL520U,
I may be lucky from what I have read, but this is what I did.  I took out the tape, released the tension on it by pressing the small tab between the wheels (I observed a slight wheel movement).  I took the eraser end of a pencil, and while holding the tab, rotated the spindles of the tape 10-15 rotations back and forth (this from the vcr days and tracking problems).  I put the tape back in and the problem went away.  I thought of this after reading post after post and then finding the definitions of the error codes on a french website.  Codes 4-6 seemed to be with the mechanical aspects of the drive, codes 1-3 with the sensors etc.  All in all it was a guess on my part.  If any of this works for you, pass it along.
Posted on Oct 12, 2007
SOURCE: video camera error
your tape transport is bad
Posted on Feb 23, 2008
  • 11 Answers
SOURCE: Canon ZR-800 Mini DV Camcorder tape stuck
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined.
Posted on Sep 09, 2009
  • 157 Answers
Your capstan motor has a problem, could be stucked-up or sensor fails. No capstan pulse detected.You may check capstan supply and drive as well. Good Luck
Posted on Mar 13, 2010
  • 13 Answers
SOURCE: When I push the eject button, the motor does NOT
Sorry this needs professional repair
Posted on Jul 04, 2011
0 characters
1 Points
Canon GL1 message to eject tape... I want to transfer it to puter. any suggestions?
Canon GL1 was working fine last night,now it want do ANYTHING today,want power up or anything,want even eject tape when I push eject button. Any suggestions?
Jun 25, 2010 | Canon GL1 Mini DV Digital Camcorder
Flashing code C:32:11
Remove the battery. Re-attach the battery, and power up the camera. Should retutrn to normal.
Jun 03, 2008 | Sony Handycam DCR-TRV140E Digital...
Eject mechanisam will no work
This indicates a problem with the part called the capstan motor in this Sony camcorder. Either the tape will not takeup or the tape spills out when the drive runs. You need a technician to remove the tape if you want it saved.
Apr 24, 2010 | Video Cameras
Cassette jammed after camera dropped
I think your ejecter motor is not working.temporarily open with any tool.
Dec 10, 2008 | Sony Handycam CCD-TRV107E Camcorder
Sony DCR-PC101E tape will not eject
Paid for someone to fix it! They said the motor wasn't working
May 19, 2008 | Video Cameras
Error code on DCR-TRV530 - C:32:10
Try taking out the battery and plugging in the charger with no battery. That did it for me.
Jan 26, 2008 | Sony Handycam DCR-TRV530 Digital Camcorder
FG fault when starting capstan.
Make sure battery is fully charged or a/c cord is used. Turn power on, and push reset button, try to eject tape again. Your capstan motor may be dead.
Jan 03, 2008 | Sony Handycam CCD-TRV318 Camcorder
Not play tape
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Dec 18, 2007 | Sony Handycam DCR-PC101E Mini DV Digital...
Did you eject the disc when you had it plugged into the wall and not running on the battery source?  If you did, take out the battery and plug it back in.  Hopefully that will work.
Oct 27, 2007 | Hitachi DZ-MV550 DVD Camcorder
Panasonic pv-gs12 reset
Take the battery and/or any power sources. When it is turned off with no power, press the reset button momenterily. I hope this helps.
Sep 24, 2007 | Panasonic Palmcorder PV-GS12 Mini DV...
JVC GR-D271 Camcorder Logo
13 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Shekar Avadhani
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
