Question about HP OfficeJet K7100 Photo inkJet Printer
K7100 black cartrage error (unrecognized)
I have 4 used black cartrages, and recently just puchases a brand new colored and new black cartrages, but somehow only the black cartrage does not recognized, but somehow i manage to insert some of the used cartrages to another printer using the same cartrage different printer model, the cartrage works just well. what should i do so that the cartrage can be recognized again. please email me at thurax2k1_418@yahoo.com thanx alot in advance
  • thurax2k1_41 May 28, 2009
    nothing happend, after i inserted the color & black cartrage the power lite is blinking together with the right cartrage lite.
  • Anonymous Mar 21, 2014
    the printer doesn't work
    Sergeant:
  • 145 Answers
Push and hold the reset button for several minutes until it works again
Posted on May 27, 2009
Cartrage replacement
From the user guide:
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges and close the cartridge carrier lids.
7 Close the scanner unit.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
6 Reinsert the black (or photo) print cartridge and close the cartridge carrier lid.
8 If the error:
• Reappears, replace the black (or photo) print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit.
• Does not reappear, reinsert the color print cartridge, close the cartridge carrier lid, and close the scanner unit.
9 If the error reappears, replace the color print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit
Aug 19, 2012 | Lexmark X9575 InkJet Printer
Can not get the color to work in my lexmark x1240 printer to work? we tried to refill the old cartrage first but it leaked after a couple uses than we bought a new cartrage but it won't work.
Make sure that you are using genuine Lexmark cartridges and not refilled, re-manufactured or clone cartridges from the 3rd parties. Lexmark products work best with original supplies. If you are using genuine cartridges yet the problem persists, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Dec 01, 2011 | Lexmark X1240 All-In-One InkJet Printer
Hp laserjet 2600n printer creates 1/2" wide band that you can almost see the print...like it is not getting toner in black color.
This often happens when cartrage has run past changing point. remove cartrages starting at top and CK for ink. Run cleaning page until clear
Jul 04, 2010 | HP Color LaserJet 2600n Printer
EPSON CX 7800 HOW DO I MAKE IT PRINT BLACK & WHITE ONLY? IT IS A COLOR INK HOG.
take yourink cartrige to staples and get in black an white only and then purshase it and put it whre the color ink cartrage was........................how the the hell do you spell cartrage?
Nov 29, 2009 | Computers & Internet
Empty Ink Cartrage message when cartrage still has a lot of ink.
I'm going to provide you a solution worth many dollars now you can use your left over half filled cartidges and in future also use the cartridges to the extreme.
1. Go to menu and select manual override for toner cartridges and then only replace toner when the print quality starts to suffer. This can save you thousands of dollars over the life of this fine printer.
2. download and read this
http://74.125.153.132/search?q=cache:9mwf_bY_x-AJ:www.refill4.com/refillinstructons/pdf_downloads/Full-RefillInstructions.pdf+brother+mfc+5840+override+cartridge+empty&cd=6&hl=en&ct=clnk&gl=in
Jul 26, 2009 | Brother MFC-5840CN All-In-One InkJet...
Color ink cartridge says empty i just filled it
When you put in a "new" cartrage the printer sens an electrical charge to the cartrage to set it up properly. So I would treat this as a new cartrage, rather than a refilled one. Go to the printer menu and re install the ink cartrage in question, it should recognise it and start the function as a new one, good luck
Mar 24, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Color cartrage
hi
if you have a spare cartridge try with it..if it works fine..then its a defective colour cartridge...try cleaning the cartridge with a damp paper towel..if that does not fix the issue..contact tech support...your cartridge would be replaced if in warranty
goodluck
Jan 25, 2009 | Lexmark X75 All-In-One InkJet Printer
Canon MP145 printer can not recognise replaced Black cartridge
When you got Error 4 on your printer canon MP145 It’s means one of your cartridge color/black has detected no ink. It happened maybe the printer MP145 is not used for long time. Don’t thinking your Cartridge is damaged. We can not do resetting procedure MP145 to resolve this I have tried it and failed.
When it happened to me I don’ want to go to the service center. We can guest what they say about that “your printer cartridge need to be changed” don’t believe. I go to Search Engine, browse and browse again finally today I found the guide for resolving the canon MP145 Error 4.
how to resolving error 4 on printer canon MP145 Press Reset/Stop Button about 5 second or more until the error 4 disapper. It worked! Save your money for newcartridges.
Jan 18, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Hp color laserjet 2600n giving "10.0000 suply error"
10.00 error is for the black cartridge. Check the cartridge locker for the black toner cartridge on the right side, is it different from the other? does it moves correctly? check properly. If the locker seems correct, try clean the contacts on toner and opposite HV pins in printer
Nov 27, 2008 | HP Color LaserJet 2600n Printer
HP OfficeJet K7100 Photo inkJet Printer Logo
684 people viewed this question
Seeker5211
Seeker5211
