Question about Bernina Bernette 75
Threading a Bernette 90e
I have a Bernette 90e, given to me as a Christmas present. I have not used it a lot, mainly because I can't get seem to get things threaded properly! Just today, I threaded a bobbin, inserted a new needle, and rethreaded the upper thread. I'm not certain that I'm getting the bobbin thread pulled up correctly. The direction state to insert the bobbin with the thread running counter clockwise; then pull it to the left. When I stitch, the top thread doesn't seem to be catching the bobbin thread. Can anyone help me?
  • jnp71 May 11, 2010
    I'm having exactly the same peoblem. Have you found a solution yet?
3 Suggested Answers
  • 3 Answers
SOURCE: Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
Posted on May 22, 2008
  • 111 Answers
SOURCE: I have checked the needle
These machines get knocked out of time very easy. Especially when you sew over denium. To check this, take off the needle plate, take out the bobbin case, have a new needle in, put the needle in left needle position or on wide zig zag. You going the check the timing of the needle and hook. With the needle over to the left, and when it is on it's up stroke, you want to see the hook tip passing behind the needle just above the eye of the needle. If it passes by after the needle eye has gone up, the timing is off. If so, you'll need to get access to the lower hook shaft timing belt gear set screws to readjust the timing. This also affects the feed timing, so you might have to have a repairman do this. I can help you if your up for it.
Posted on Apr 27, 2011
How does one thread a Bernette 320? I bought a very old one with the stitch settings all 3 on the front of the machine
Perhaps this will help:
Bernina Bernette 320 330 Owner Manual
Just an additional hint, ALWAYS RAISE the presser foot when threading the top thread. This releases the tension disk allowing the thread to seat completely.
Mar 19, 2017 | Sewing Machines
How do I turn off THE BOBBIN winder on a Bernette 65 sewing machine?
The bobbin spindle needs to be moved to the left in the slot to disengage the winding mechanism. (It may be easier to do this with the bobbin on the spindle. The bobbin and spindle should be moved to the right after putting the bobbin on for winding.)
The directions and pictures for winding the bobbin are on page 30-31 of the manual. The manual is available from Bernina on their support page for the out-of-print Bernette machine manuals: .http://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/bernette-manuals/Bernette-Sewing-Machines . The direct link to the Bernette 65 manual is here: http://www.bernina.com/getdoc/6d2754b8-af09-4edb-a6a6-7a4c57965b8d/bernette-55-65-80e-90e .
I hope this helps.
Oct 13, 2015 | Bernina BERNETTE 65 Mechanical Sewing...
Is there a way to oil the right hand turning wheel on my Bernette 730A sewing machine?
You will either have to remove all the covers and oil the main bearings or have. A service tech do that for you
Aug 03, 2014 | Bernina Sewing Machines
How to insert bobbin in a bernette 680 sewing machine?
Try going to this link and download the manual for either the Bernette 410 or 715 and look at the directions for threading and inserting the bobbin:
Bernina may not have a manual for your particular model, but these models may be close enough that you can still use the directions for your machine.
Jul 07, 2014 | Bernina BERNETTE 65 Mechanical Sewing...
I have a Bernette 134 - despite threading according to the pictures, will not overlock stitch. Can anyone help me with a manual? Thank you
Try http://www.sewingnz.com/bernette-134d-134-overlocker-overlocker-instruction-manual/ (10.00).
Jan 20, 2014 | Sewing Machines
Threading bernette overlocker
have you tried the video's on youtube
Apr 06, 2012 | Bernina Sewing Machines
I have a deco 600...the top thread is pulling thru to the bottom and making a mess..it seems as if the bobbin thread s not picking up. Could this be a timing issue? Can I fix this myself
sounds more like top tension device is faulting, can you clean between the tension discs? if you can get to them turn tension to zero and floss between discs with selvage edge of clean cotton fabric scrap. thread dye particles and lint will build up in there. timing off usually presents as the stitches not being made at all. always raise presser foot when threading up too. if top tension looks like it is not working correctly consider getting a service and clean done, should be done at least biannually.
Jun 07, 2011 | Bernina Bernette Deco 600
Tension: A new user of machine, I need training. Or a on line manual, that i do not have to pay dollars for This is South Africa, Paying $ 9.99 is too expensive for me.
hi there,
well, try to log on www.youtube.com on search box type "sewing machine" then select your want to know on ssewing the click,there are several basic step on how to thread and bobbins winding,and setting up upper and lower tension.regards and hope this could help you a lot.
Aug 01, 2009 | Bernina Bernette 75
Threading of Bernette overlocker 004D?
You could try to find the manual on eBay
Jun 08, 2009 | Bernina Bernette 75
Bernette 90E
Our Bernette E90 timing was off due to a jam (design flaw I think)...Instructions on how we fixed it.
1. To correct timing, tip over machine and unscrew inspection plate.
2. Find the gear and unscrew the 2 grub screws so the gear is free from the shaft
3. Turn the main sewing machine handle to manually get the hook (pointed piece) of the housing (see arrow) to be directly behind the needle
4. Hold it the tightly, and turn the handle again, the needle should be able to go up and down while holding the hook in position.
5. When the needle is at it lowest and starting to move back up and the hook is directly behind tip the machine over and tighten the 2 grub screws on the gear underneath.
6. Replace inspection cover and you’re done
Dec 26, 2007 | Bernina Bernette 75
Sewing Machines Logo
150 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
