Question about Intermatic & Indoor/Outdoor Rain Tight Timer
CANNOT SET THE TIMER Intermatic pool timer model # P7102ME
The screen on my Intermatic P7102ME pool timer has 88888 across the screen and will not let me set anything.
The on off switch works but I can't change any settings.
It worked fine last year.
rockitman187
  • 2559 Answers
SOURCE: How To Program An Intermatic PE15300 Pool Timer ?
1. Press PROG Key to cycle through menu options.
2. Press UP and DOWN arrow keys to change program settings.
3. Press ENTER key to save changes and exit programming mode.
4. Press ON/OFF keys to manually turn devices ON or OFF.
Please post back if additional info is needed
Please take time to rate this fixya
Posted on May 13, 2009
  • 30 Answers
SOURCE: Changing Pool Timer
As long as you get a new timer that is 220/240v and is the same amperage or larger, you should be fine. Wiring would be the same.
Posted on Jul 09, 2009
  • 351 Answers
SOURCE: Intermatic Pool timer will not turn off... I have
If the pool pump timer is not working, first look and see if the clock dial is moving, if not then you need to check the 120volt breaker that feeds it ,, then you would check the connections on the timer to be certain that they are correct.
Posted on May 04, 2010
MOTORWIZJ
  • 1338 Answers
SOURCE: clock for pool pump intermatic timer Model T104P3 stopped ticking
LOOK HERE ON EBAY .. Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIXTO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ.. JAY
Posted on Jun 02, 2010
aquaman987
  • 927 Answers
SOURCE: I have the intermatic TN 300 model lamp timer and
Turn the dial in the direction of the arrow to set the correct time of day. Make sure all pins are up. Push down a pin at the time you want to turn ON your load. Push down a pin at the time you want to turn OFF your load. Plug everything in. Good Luck, Gary
Posted on Dec 12, 2010
The supplier that fiited my swimmimng pools timers never gave me the booklet on how to set the time.
1) Unknown brand name pool timer, probably Intermatic:
Unknown if this is mechanical timer, or digital, or remote control, or air activated. Or if this is control center with circuit breakers and multiple timers to control heater, and pool pump, or if unit has firemans switch to turn pool heater off 20 minutes before pool pump, or if unit has freeze protection thermostat, etc
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
2) For Tork:
http://waterheatertimer.org/Tork-Pool-timers-and-manuals.html
3) Jan 2013.
Add a comment with model number or attach photograph and add any other information available for best possible answer based on specific product.
Jan 02, 2013 | Hardware & Accessories
I want to know how to set the time on my swimmimg pool timers
Hello Gerhard
2) For Tork:
3) Jan 2013.
How can i set up the time of the pool light in the a box model T10004R?
Typical T1000R series pool control center has space for 2 timers, and comes with one T104M 240Volt timer. Additional timer mechanism can be added to control lights, etc.
Copy following link for setting T104 series Intermatic clock, with link to wiring diagrams.
Intermatic pool timers are extremely durable and versatile, and modular so they can be repaired almost indefinitely using ez-to-locate parts
Additional link for replacement parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
Oct 28, 2012 | Intermatic T10004R - Pool-Spa Mechanical...
Need instruction manual for pool/spa Intermatic timer model RC 2343PT
Intermatic does not post that product manual, or the door label for that specific product. Nor is the door label clear when viewing images of timer.
Copy following links for possible assistance wiring timer, and then setting timer:
http://waterheatertimer.org/pdf/RC2403RT-Door Label.pdf
http://waterheatertimer.org/How-to-set-timers.html
Apr 20, 2012 | Intermatic Hardware & Accessories
I dont know how to set the timer
Question posted under Intermatic T104 series timer and pool control center.
Open following link to see how to set this timer:
Intermatic T12404R control center has 2 timers.
Each timer is set same way.
Timer must be reset after power outage. If time dial is not rotating correctly or is sticking at the tripper, then the WG1573 clock motor can be replaced by homeowner.
Both timers are 240Volts, and can be wired in variety of ways to control different voltages. For example 120Volt pool lights, and 240Volt pool pump and pool heater etc.
Each timer snaps out of control center using thumb spring located top inside box.
Each timer mechanism is sold separately. One timer is T104M. The other is T104M201.
The difference is that the 201 has a 'fireman's switch' that can be wired to pool heater, and the switch turns off heater 15-20 minutes before turning off pump.
Each timing mechanism can be repaired by homeowner using available clock motors and trippers.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Intermatic Timer T12404R Pool & Spa...
Pool pump starts randomly (as if there is a short) even when it is not set to start and stop. Otherwise works fine, not sure if I need to replace unit or dissassemble and clean or ????? T21004R
Sounds like 240Volt WG1573 clock motor has gone bad and needs replacement. But more checking is needed.
You posted under T2100-4R which is 60 amp Intermatic control panel with a single T104M 240Volt timer mechanism.
All Intermatic timer mechanisms can fit into same control center, so you can possibly have different timer mechanism inserted into the T2100-4R control center.
The control center can have up to 4 circuit breakers.
Instruction manual shows that timer can also have fireman's switch that is wired to pool heater and causes pool heater to turn off 20 minutes before pool pump turns off.
http://www.poolandspacontrols.com/products/mechanical%20controls/60%20amp%20pool%20and%20spa%20control%20panels.aspx
(1) First thing: If you have T104 mechanism, do a troubleshoot run-down to see if trippers, clock motor, or wiring are suspect:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
(2) Next would be to check the circuit breakers for loose wires, burned connections, or the smell of burning or crackling sound that says breaker is loose on the busbar.
(3) Check for loose wiring on T104 and test circuit:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
(a) Push the manual override lever to OFF position and test across terminals 1 and 2 and then across terminals 3 and 4 to make sure timer is turning off power to pump. Both tests should show 0 volts.
(b) Push manual override lever to to ON position and repeat test above. Both tests should show 240 volts.
If the test fails, then buy new T104M timer mechanism.
(4) If the T104 timer is turning off both lines in the 240Volt circuit, then pump cannot turn on since neither wire is Hot.
However if your T104 timer is actually a T101 timer or if timer has different wiring, where timer is turning off only 1 leg and not both legs of 240Volt circuit, then pump has one hot wire available and a short to ground could cause pump to turn on unexpectedly.
Jul 08, 2011 | Intermatic T21004R- Pool-Spa Mechanical...
I have Intermatic Model T104 timer for my pool. The power went off a few days ago, and i have not been able to set it where i wanted it since. I do not have a manual. The pool contractor didn't...
Open following links for T104 timer manual and information, and then add a comment for more information.
To set timer, lift and rotate dial until current time lines up with stationary silver pointer.
Stationary silver pointer is pointed at 6:00.
Jun 24, 2011 | Intermatic Industrial 24 Hour 120v...
Purchased new intermatice pool timer and it will not turn pool on but will turn pool off.
Timer is not known.
Timer is probably not wired correctly, or on-off trippers are not on the dial.
Add a comment with model number that appears on inside of timer door.
Jun 18, 2011 | Intermatic Hardware & Accessories
My intermatic pool tmer will not set time or let me auto. turn to on so I can't filter or backwash pool
Problem points to electric power.
1) For best possible free answer, please add a comment and give model number that shows inside timer door.
This will give expert access exact manual for the equipment you have, and show what voltage you are working with.
2) You can also review Intermatic pool timer sell sheet, and pool timer site to help identify product:
http://waterheatertimer.org/pdf/Pool-and-spa-catalog.pdf
http://www.poolandspacontrols.com/products.aspx
3) If you have mechanical dial timer, see if manual override works.
And then check electric power.
Check circuit breaker.
Check if manual override works.
4) If you have P1353 digital electronic timer:
http://waterheatertimer.org/images/P1353ME-digital-time-clock-mechanism.jpg
P1353 digital electronic timers have auto setting.
Check programming.
Programming for P1353 is complicated, and longer than space allowed for free answer.
http://waterheatertimer.org/pdf/Intermatic-P1353-manual.pdf
Programming starts on page 25, and you can add a comment about any specific part of manual that is confusing.
Mar 09, 2011 | Intermatic Timer T12404R Pool & Spa...
My model t12404r will not turn the pump off. Even if I manually move the switch to the off position, the pump keeps running. The only way to stop the pump is at the breaker box. The other timer in the...
I don't know if you have a 240V pump and 120V cleaner.
Or if both are 120V
T10000 series manual has troubleshooting
http://www.polytecpools.com/images/pdf/intermatic_t10000r.pdf
I specialize in timers.
If the manual override will not work and the circuit cannot be stopped by the timer:
Then the timer is bad.
To check for sure:
When pool pump is OFF, use tester and check voltage across terminals 1 and 2 on pump side
When cleaner is OFF, use tester and check voltage across terminals 1 and 2 on cleaner side
What test results show:
The cleaner side test across 1 and 2 should show no voltage when timer is OFF
The pump side test across 1 and 2 should also show no voltage when timer is OFF
If the pump side test across 1 and 2 shows voltage all the time, then the timer is broken.
There are no replacement parts for the internal on-off mechanism.
Polytec pools and spas sells the same timer for $215:
http://www.polytecpools.com/intermatic-t12404r-control-center-w220v-dual-timer-wo-breakers-p-543.html
BH electric shows the T10000 series for $178
http://www.beverlyhillselectric.com/t12404r.html
Add a comment if you need help wiring your new timer
You have what is called a 2-channel timer.
A single-channel timer can operate 2 or more Loads (pump, cleaner), but the Loads turn on-and-off at the same time.
A 2-channel timer has a clock (or digital program in the case of digital timers) so each Load turns on-and-off with a different schedule.
As a general rule, 2-channel timers are more expensive.
To avoid the higher price, you can replace a two channel timer with 2 ordinary timers.
Let me offer a replacement strategy that might save you money.
Keep the existing timer for the cleaner.
a) Buy Intermatic T-104R weatherproof timer if you have 240V pool pump.
b) Buy Intermatic T-101R weatherproof timer if you have 120V pool pump.
Here is a resource for the Intermatic timer I am suggesting:
The webpage has links to sellers, it has manuals and it has wiring diagrams for the do-it-yourself-er
Nov 04, 2010 | Intermatic Timer T12404R Pool & Spa...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
185 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
