Question about Archos 5 Internet Media Tablet
Recovery code 101
My archos 5 250gb is showing a "archos g6h recovery (code 101) before that it wouldnt come out of the openning screen.
  • 5 Answers
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 5 or 7:
1- Plug the unit to you computer via the USB cable.
2- The unit should start automatically and open the following page:
3- From the recovery console (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the volume control on the right of the unit (Do not press "Format" at any time)
5- Now that you are on "Repair" press the on and off button, shortly to validate your selection
6- The unit will go to "Plug the unit etc…" but it is already plugged from point 1 - DO NOT press anything anymore on the Archos
8- Wait until Pc should recognizes your Archos (around seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 5 or 7
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the USB cable until the process is finished
4- when done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Posted on Jul 24, 2009
  • arr93 Oct 25, 2010
    ce parfait je crus que j-en peux plus recuperer mon archos 500 gb apres un formatage que je fait pour ameliorer ces bon fonction
    mille merci pour ce tuto
    New Friend:
Hello, You simply need to download the firmware for your device. I had and Archos 5 Internet Media Tablet. So I downloaded the firmware for that tablet. I then added to the Root of my Archos under where you see the folders for Video, Music.... Simply select done and unplug your device from your computer. If it is the correct firmware, then it should automatically load. If it is not the correct firmware then it want load, instead it will go back to the Recovery screen. Hopefully this helps, if not. call Archos Tech support at: Technical support by telephone: Technical Support: 1-877-300-8879 Customer Service: 1-866-489-4718 Hours : 9am - 8pm CST (Monday - Friday) 10am - 6pm CST (Saturday)
Posted on Jun 07, 2013
I acciedently pressed format instead of repair on my archos 5
Posted on Apr 16, 2011
Archos 101 wont turn on
System recovery
If your ARCHOS does not respond correctly or does not start properly, you can try to remedy this situation with a system recovery. Be very careful with this as there are options to erase all the data on your device.
To enter into the Recovery screen
- Turn off the device and wait 10 seconds.
- Press and hold the volume + button while powering on the device.
- Keep the volume + pressed until the Recovery mode starts (white screen).
- To move from one option to another, use the volume buttons. To select an option, press the ON/OFF button.
Recovery mode options
No: Cancels the system recovery.
Update firmware: Allows you to connect your device to a computer in order to copy the latest .AOS file (operating system) to your device and then install it.
Repair System
: Attempts to repair the file structure on the internal memory. This does not erase any data.
No: Return to main recovery screen.
Force Touchscreen Calibration:
Select this and then select no to leave the recovery screen. Upon restarting, the ARCHOS will immediately start the touch-screen calibration utility.
Check Disk: Check and repair the system partition if damaged.
Start USB MSC: Allows you to connect your device to a PC to access the internal memory.
Format System: Formats the internal memory. All data (music, photos, videos, etc.), applications and settings are erased. "
copied from the Archos online manual
Jan 24, 2013 | Archos 101 Internet Tablet 16GB 10.1"...
Archos 101 internet tablet keeps going onto archos A101IT recovery when i turn it on i try to repair or format the devive and it just jeeps failing
every time i turn on my tablet it pop up archos A101IT Recovery.would u like to recover your system.no update firmwear.repair system.format system
Jun 26, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
Archos 101 internet tablet cant get out of demo mode
Try this:
Power your Archos 101 off by holding the Power Button for 10 seconds (this fully shuts it down).
While holding the Volume + button power it back up (tap power button to start up, hold volume until the tablet enters recovery mode, you'll see a series of choices instead of the demo mode).
Choose the Format System option.
When this process is complete make sure not to select Demo Mode as Android boots and the Archos 101 gets up and running.
Feb 20, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
My archos is showing recovery code 101
It is indicating that there is a hard drive fault. Here is another users suggested method to clear the fault.
Following some extensive use I switched it on one day to find that it hung on the Archos home screen and kept going in a loop. Luckily I could see the red HDD light flickering so knew that the Archos was trying to do something and that the HDD was recoverable. When I entered into the recovery mode I found that I had an recovery code (101) which indicates a HDD fault.
I used the following steps to recover the HDD:-
1. Connect the archos to the PC using the USB cable (the unit will start but will need to be shut down again by pressing the power button)
2. Press the power button and the 'lock' button together for a few seconds and you should get a basic recovery screen
3. Scroll down to repair disk and select
4. Click on done and wait for a few seconds and you will see the archos as a drive in 'My Computer' (Note that this does take a few minutes)
5. You now need to back up your data, movies, music, widgets etc as the next step is to format the Archos HDD which will wipe it all.
6. Disconnect the Archos, turn it off and then turn it back on again by pressing the power and 'lock' buttons together.
7. Scroll down to format disk and select. The Archos will now delete all files on the HDD and you will get a message asking to connect to a PC and install the update file. This is the firmware file that can be obtained from the Archos website. You'll also notice that the recovery code has changed from 101 to 108
8. Connect the Archos to the PC, wait for a few seconds and you will see the archos as a drive in 'My Computer' again.
9. Drag the firmware update file from your PC where you've downloaded it to directly on to the root drive
10. Click 'done' on the Archos and it will begin to update the operating system.
11. Once this is complete then there should be an update successful message, select done and the archos should restart giving you the nice bubble screen and asking if you want to enable USB.
12. Note that the Archos is now in a 'factory built' condition so you'll need to adjust settings etc according to your preferences.
13. You can now start the long process of transferring your files back to the Archos.
Jan 12, 2010 | Archos Internet Media Tablet MP3 Player
Just got Archos 5 goes into error 101...
Hi there, these instructions are for the archos 705 but they are the same for the 605.
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
D) On the Archos 705:
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
Jan 21, 2009 | Archos 605 WiFi Digital Media Player
My archos 605 won't do anything but to show recovery code 102.
recovery code 102 screen - this error message means the the hard disk has failed - I am guessing that the unit has been dropped at some point - Sorry but it back to Archos - The UK number is 0207 949 0115
Jan 20, 2009 | Archos 605 WiFi Digital Media Player
It shows-recovery error-102 & error-104
Hi
i had same issue. nothing worked until i saw a guy who fixed his by dropping it on floor?
i dropped my archos in the protective case from 2 feet off floor. the bloody thing when came back to life, 100% good. i think the hard drive was stuck and the fall fixed it!! it cannot hurt as yours is broken still i guess. hope it works for you to
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
Archos 5 Internet Media Tablet Logo
3,965 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
