Question about Ryobi Garden
Ryobi fuel lines I do not have a diagram how they go and if there
I need a diagram for the gas lines and need to know if there are 2 different sizes of lines
  • 57 Answers
SOURCE: I need to know how the fuel lines should be
The line from the fuel tank that has the filter on it goes directly to the carburetor below the primer bulb. One line comes from the carburetor to the primer bulb. The other line goes from the primer bulb to the fuel tank. Primer bulb can be pressed to determine which side is pulling fuel (line from carb) and which is pushing (line to fuel tank).
Posted on May 15, 2009
mitchjl_1692
  • 3 Answers
SOURCE: Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
Posted on May 27, 2009
SOURCE: RYOBI 725R FUEL LINE DIAGRAM
I just rebuilt my 725r. I don't have a diagram but I can explain it. There are two lines coming out of the fuel tank. The line closest to the rear is the fuel feed and has the in-tank filter (these are available for replacement). This line goes through the lower case hole of the air filter housing and attaches to the bottom of the carburetor. The line toward the front of the tank attaches to the longer/lower fitting the primer bulb and is the return. The line coming off the shorter/upper fitting of the primer bulb goes through the upper hole of the air filter housing and attaches to the top of the carburetor.
FYI also, the forward carburetor screw is the low idle adjustment & the rear, the high-speed mixture. The original oil mixture spec called for 32:1
Posted on Jun 27, 2009
canbruce75
  • 1776 Answers
SOURCE: need a diagram on how to connect the fuel lines
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Posted on Oct 01, 2009
SOURCE: where do I connect the fuel lines on my ryobi weedeater?
I have Ryobi775r string trimmer with walbro WT526 carb. The fuel lines connect 3 parts eg. gas tank, bulb (mine is a separate bulb not part of carb.) and the carb. The bulb has 2 fittings- a short and a long one. The carb also has 2 fittings- one on top (vertcle) and one on the bottom (L shape). The gas tank has two holes in the bottom one for over flow line and the other for fuel inlet to the carb. This has a filter in the gas tank. Now the connections- connect the long fitting on bulb to the tank. this is the overflow. Connect the short fittin on bulb to the carb top (verticle) fitting. Connect the fuel line (with filter - it is in the tank) streight to the L fitting on the bottom of the carb. Make sure the fuel lines are of right diameter. Too big-and you will have leaks. You are done connecting the fuel lines. just for info. the bulb is there just to pull a vavcume in carb so that the fuel is sucked into the carb and is present there when you start the engine. Hope it helps. Good luck.
Posted on May 10, 2010
What size fuel line for Ryobi Homelite Fuel Tank Fits Trimmers 308181008
Ryobi makes a neet little fuel line kit for these , and its inexpensive too , it contains a new fuel filter (and tool for installing it) a new primer bulb (change it anyway) and enough of two different fuel line to reach your trimmer's carb , I stock a few of these here and you can buy ne from any roybi dealer , the only tool you need besides your fingers are a pair of scissors and a Phillips screwdriver for taking off the air cleaner to gain access to lines
directions are included on back of package
Jun 09, 2014 | Ryobi Homelite Fuel Tank Fits Trimmers...
I need a diagram for the fuel lines on a ryobi 31cc trimmer plus 15" from the fuel tank thru the primmer bulb to the carb for both lines
Don't quite understand your dilemma... there are only two fuel lines which go from the tank to the carburetor.....if looking at the engine from the back, the fuel line on the left is the intake line and the one on the right is the fuel return line....on the back of the carb are two fuel line brass inserts...they are inlet on left and return on the right....hope this helps ;-D
Jul 15, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I need to know how the fuel lines are hooked up in my ryobi gas trimmer. All of the fuel lines rotted out. I took them out and I need to know the correct connection sequences (what goes where).
line runs from little filter in tank to carb.
line from carb. to primer bulb
line from primre bulb back to gas tank.
lines are 2 sizes
need to cut at angle end of lines in tank so you can get them thru holes
and grab with needle nose plyers and pull them thru.
make sure you put the little filter on end before you pull line thru and leave
enough so filter can move around the whole tank.
second line in tank is smaller and need to cut and pull it thru hole in tank to primer bulb
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My Ryobi 77 line trimmers revs like mad when I
Hi and welcome to FiXya. I am Kelly
What your describing it the result of fuel starvation. This can be caused by:
1. Debris in the fuel line or a crack in the fuel line
2 A clogged "fuel tank" internal pick up hose screen
3. A pinched fuel line
4. A clogged needle jet seat
5. A hole in the carb diaphram
6. Debris in the fuel air mixture screw / needle passages
7. A non vented gas tank cap.
Any of the above can cause the symtom you described. For sure it is a fuel supply problem.
I tried crossing the part numbers for just a Ryobi Model 77 and was unalbe to cross it to a working model number.
I came up with 2 different carb part numbers using a 30 CC engine
1st PN: 791-182875
2nd PN: 985624001
If you can pass the exact Model Number, I can provide you with a source for the carb or parts.
Thanks for using FixYa.
Kelly
Feb 15, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
2 Cycle Gas Trimmer will not start
it is normal to see air bubbles in line when pumping the bulb. to make sure what the problem is, try starting several times, remove spark plug. if dry, yes no fuel, remove the carb. if wet, place plug on engine block and look for blue spark. no spark means you need new plug, plug cord or ignition module
Jul 24, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Where can i get a diagram on how to replace my crumbling gas lines on my ryobi trimmer?
You need to buy a length of the right size petrol pipe from the internet or garden machinery shop.Should only cost a few quid.Normally got 2 pipes going into tank from carb.Disconnect one from carm then slowly pull out of fuel tank.Measure length and replace with same length of new pipe then do exactly the same with second pipe.Hope this helps.
Jun 12, 2009 | Ryobi Garden
Lenght and position for Ryobi RY08548 Blower fuel line in gastank
take off the fuel filter and see if that works . if it runs then it needs a new fuel filter. keep me posted
Apr 11, 2009 | Garden
Ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Aug 28, 2008 | Ryobi Garden
Garden Logo
371 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
