Question about Tascam CD-A500 CD Player
CD player WILL NOT PLAY and does not recognize CD presence
Radio/CD player (GE 7-5295A undercabinet)..CD player problem...radio, tray open/close mechanism, spin motor, shuffle and track selection commands work OK ...yet no longer able to play any audible sound and even says or just flashes as if in "pause" state....have tried cleaning to no avail...any suggestions ?...
  • Anonymous Mar 28, 2014
    I'm trying to reset the clock
  • 6,784 Answers
HI. this is optical lens assembly failuer. the optical lens is burned out, in return, inducing the (no CD) message. simply replacing the optical lens assembly will fix this issue.
Posted on May 27, 2009
Testimonial: "have same problem..solution sounds great...the only thing now is where can one obtain the optical lense replacement..no help from radio vendor"
How do you put a cd in
Kylie, if there is a CD tray press the eject button and put CD in tray, push tray in easy to load. If no CD tray insert CD into CD slot and push gently to load. Some have a lid on top that you simply open with your finger then load CD. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jensen JCR 310 AM FM Stereo Dual Alarm Clock Radio with CD Player
Christmas Presents 2013 RCA RP5605 AM FM CD Clock Radio
Magnavox alarm clock radio CD player
Problems With My GE General Electric 7 4901A CD Player AM FM Clock Radio
Jun 17, 2016 | Audio Players & Recorders
Cd player is not workig.
Sometimes the lazer will get jamed.
Gently move the lazer eye (without touching the lense) to the outside of the disk draw, put in a disc and try.
It might work (has for me)!
If the disk won't spin then the drive is probably stuffed, probably cheaper to replace than repair.
Good luck, new cd/radio players are relatively cheap, so not many people fix them any more.
Throw away society, sorry if this didn't help.
Dec 17, 2017 | GE 7-5290 Clock Radio
RCA RS2612 Digital CD system malfunction will not play CDs
The changer is fubar and repair is not cost effective.
Sep 16, 2017 | RCA RS2656 Shelf System
Radio in 2003 jeep grand cherokee does not play cd's. it plays the radio stations, volume works, but it does not eject the cd or even recognize it .
you can look for a radio shop to repair the cd player it would be cheaper to install a aftermarket radio they do have kits if you have steering wheel controls
Apr 10, 2012 | 2003 Jeep Grand Cherokee
Need screws and spacers to install under cabinet radio
If the manufacturer's website can't help you, you could try ebay.
Good luck
Dec 15, 2011 | Sony ICF-CD543RM CD Player
CD opens and closes perpetually. CD won't play.
likely yes. does not sound like coincidence. try this: search ebay for an AS-IS item for $1 and use it for part-swapping. first to swap-the main circuit board holding the micro chip.
Jun 04, 2007 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
My VCD player doesnot recognize a cd
Try cleaning the laser lens with a cleaning disk like you might find a Wal-Mart or Radio Shack and see if that helps. If the lens on the laser is too dirty to read that it has a disk then it will not attempt to spin the disk. If cleaning doesn't solve your problem then it may be a much bigger problem like weak laser etc. Good luck.
Jan 28, 2007 | LG ADR-620N CD Player
Cd won't play
Easy fix, look at the front of your CD player, you should see a little pin hole, insert a paper clip into it and the pop the CD tray open.
Jul 23, 2006 | Panasonic CX-DP801 8-Disc CD Changer
Tascam CD-A500 CD Player Logo
607 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
