Question about HTC G1
Bluetooth not accepting anything
Hi, My G1 is not accepting any photo's or music from any other phone. It is trying to pair up with any bluetooth connection turned on around it but when I send stuff from another device the other device tells me that connection was failed. I am seriously thinking of getting rid of this G1 it has so many flaws. I cant get my g1 to even find my bluetooth headset...it keeps scanning but does nt pick it up...n ideas n e one
  • 22 Answers
The T-Mobile G1 doesn't actually support file transfer through bluetooth :S So it's not faulty, it's just not programmed to do that. Sorry! However it should be able to find your bluetooth headset, it always finds mine. Maybe the headset is faulty?
Posted on Jun 15, 2009
2 Suggested Answers
SOURCE: Bluetooth not accepting anything
Hi
I was trying to transfer some ringtones from old phone to G1 and facing the same problem.
And now somewhere from net I found the solution to my problem.
Although it could not be done by bluetooth, but my problem is solved now.
You can also try it. It may help you out.
> Transfer ringtones/music/photos from your phone to Desktop
> Connect G1 to Desktop by USB cable
> On the top of G1 screen it will show the icon of USB (connected)
> Scroll down from the icon and select 'copy files from computer'
> Select 'Mount'
> On desktop a massage will appear, click 'open folder & show files'.
> Copy & Paste files from computer to G1. Now your files are in G1
> If you want to set any song as ringtone press & hold that song, a menu will appear and you can select 'set as ringtone'
Posted on Mar 21, 2009
I cant turn on the bluetooth on my zte sonata phone to listen to my music on my LAX MAX bluetooth speaker.
  1. Before you begin, place the Bluetooth device in pairing mode . Open the Notifications panel and tap Bluetooth . Or, from the home screen, tap > System settings and slide the Bluetooth switch to the On position to turn on Bluetooth . When Bluetooth is on, the icon will appear in the status bar .
  2. Tap Bluetooth .Your phone will automatically search for Bluetooth devices and will show all visible devices in range .
  3. Tap the device you want to pair with .
  4. If necessary, confirm that the Bluetooth passkeys are the same between the two devices and tap Pair . Alternately, enter a Bluetooth passkey and tap Pair .
    Pairing is successfully completed when the other device accepts the connection or the same passkey is entered .
Dec 28, 2014 | Cell Phones
I can't get my Braven 570 bluetooth speakers to connect to anything using bluetooth
Hi,these devices like bluetooth hand set or speakers must be paired in the master device,for example turn the speaker on make sure its blutooth is visible too all and find it with your phone device if your phone can see it try to go to option and make a new pair device,if your phone cant see it you may have problem with the speaker,try to read manual,if you still have problem,something goes wrong with device,and if it works successfully you can pair it in the laptops or PCs
kind regards
Apr 16, 2013 | Computers & Internet
Bluetooth paired but not coneected
How to pair and then connect to a Bluetooth device on your T-Mobile G1 Google smartphone.
1. First, ensure Bluetooth is enabled.
2. From the Home screen, press Menu.
3. Select Settings.
4. Select Wireless controls.
5. Select Bluetooth settings.
6. The G1 starts searching for Bluetooth devices in range. Select the device when it appears.
7. Type the PIN for the device.
8. The device should then pair with the G1. You can then select the device name to connect.
Bluetooth only supports ad2p profiles for headsets, music, and sharing of contacts and pictures. This is limited by VZ. Until the phone is rooted, there is absolutely no way around this. You cannot send files other than contacts and pictures via bluetooth.
It sucks... I know. I am in the same boat. I am [im]patiently waiting for the droid to be rooted so I can use bluetooth to share files between two droids.
Feb 24, 2012 | T-Mobile G1 Android HTC Google Smartphone...
I have a samsung hm1100 Bluetooth device but i cant hear music from music player ........ what to i do
Hi ranjit975896,
This happens sometimes for this bluetooth dongle , what you can do now is follow the below steps:
1 ) Switch off the bluetooth
2 ) Delete the bluetooth pairing from your phone
3 ) When you delete the bluetooth pairing , restart your phone.
4 ) Then switch on the bluetooth in your phone and your dongle
5 ) Pair the bluetooth , start the music player and check if it works.
Hope this helps ...:) Let me know in case you have any queries.
Sep 09, 2011 | Samsung HM1100 Bluetooth Headset
Cant pair phone with jabra bt2050 needs a passcode
How to pair and Send Music to a Phone Via Bluetooth
Bluetooth is a type of technology found in electronics that allows you to send and receive signals and files wirelessly. Most commonly used in cell phone headsets, many people also use Bluetooth to transfer data. There is no set protocol for all devices, so instructions for use vary from one device to another. Check out the following loose guidelines for sending music from one Bluetooth phone to another, or from a Bluetooth-enabled computer to phone.
Instructions
Verify that Bluetooth is turned on or enabled in both your devices. Most cell phones will have a Bluetooth menu in their Settings or Tools. For computers, you may see a Bluetooth icon in your system tray. If unsure, check your product manual for specific instructions.
Follow the instructions to pair (connect) your two devices. If you are asked for a passkey, try entering 0000 which is usually the default for any device.
When prompted on the other device, give permission for the original device to access it.
If transferring from phone to phone
Navigate to the song you want to send and hit the button that takes you to the options menu. Choose the option to send your song; depending on the brand of phone it may say "Send" or "Move."
The next menu should ask if you want to use a text message or Bluetooth to move or send the file. Choose Bluetooth.
When prompted on the phone receiving the file, accept it.
If transferring from computer to phone
Look for an option to browse the contents of the phone. Navigate to the Music or Multimedia folder on your phone.
Navigate to the place on your computer where your music file is kept in a separate window.
Drag the file from its original location to the correct folder on your phone.
Accept the file when prompted by your phone.
Tips & Warnings
Pairing is usually the most difficult part of the process. Make sure you read your manual on both devices if it isn't working for you. If you don't see the menu to move or send your music, your phone manufacturer may not allow it. Check your manual or with your carrier's tech support website. This process usually applies to MP3s and not ringtones.
Feb 17, 2011 | Jabra BT2050 Bluetooth Headset
My fones blutooth isnt workin
Sounds to me like your G1 isn't set to discoverable. Should be an option for it in the bluetooth section. Then go ahead and try to pair them, also make sure your bluetooth is in pairing mode, most bluetooth headsets get be set to this by holding down the on button for over 5 seconds and usually shows as a constant blue light.
Jul 18, 2009 | HTC G1 Smartphone
Bluetooth problems!!!
you need to pair the devices in order to connect and use the bluetooth. Its for security reasons.
once the pairing is done you can use it
to pair go to bluetooth menu then options or configuration >devices>add new
now search everything will be fine
Jul 02, 2009 | HTC G1 Smartphone
Bluetooth My husband and I both have upgraded to G1 phones and neither phone will connect to bluetooth, we have tried with several phones, we can pair up to another phone (and each other) but when we try...
hiya, the G1 does not let you connect to other fones and will not enable you to send ringtones pictures etc wether it is a g1 or any other make! t-mobile are working on this to set up the application! they will notify us g1 users when it is available. hope this helps you out
all the best
kel
x
Jan 02, 2009 | HTC G1
Hi
> Select 'Mount'
Dec 01, 2008 | HTC G1
HTC G1 Logo
335 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
