Question about Infinity Reference 611a Car Audio Amplifier
Infinity 336rms amp worked for over a year then one day stopped?
I was driving one day and listening to music low and then all of a sudden the amp just stopped working? can anyonehelp me with it i took it apart to see if it fried but found no spots that looked fried
    Scholar:
  • 84 Answers
Check your fuses. Also check the power wire connection to the amp and then the ground source maybe move that if there is paint under it. check fuses on the amp. Check ohm load to the amp from the speakers.
Posted on Jun 14, 2009
Music plays for a while, depending on the weather and how hot it is and then it just cuts off and the protect light comes on. Had this amp for 4 years and no problems till now. Some days I can listen the...
check the cooling fans inside the amp i suspect that they are not working properly and this causing it to overheat which will shut it down via a thermistor to prevent damage
Aug 18, 2011 | Infinity Reference 7541a Car Audio...
Infinity Interlude IL120s Powered Subwoofer (home) will not power
Some of these Infinity Amps have an Internal Glass Fuse. Open the Case and Check for this Fuse. Please Rate My Response! Thanks!
Feb 03, 2009 | Infinity 7540A Car Audio Amplifier
Onkyo tx-sr602 as soon as i turn receiver on it flashes protect
Does it display any message like "Protect" or something similar? Do you hear a relay click on then off?
Did the amp just not power up one day or did it stop working while you were listening to it? Finally, do you have teenage kids who might have been listening to your receiver and would have "neglected" to tell you that after listening to their music it suddenly stopped working?
It could be an internal fuse but chances are its something that requires a technician to repair (like the output transistors).
Dec 29, 2008 | Onkyo TX-SR602 Receiver
No sound...
you have wires grounding out at the back of the unit. i suggest trying to completely rewire it and see how that works. its easy if youve never done an install so dont sweat it. email me if you have any questions.
wellgood04@yahoo.com
May 13, 2008 | Panasonic CQ-C7301U CD Player
My iPod stopped playing through speakers- but only at work...
Esmurfette
First things First!
1) check on other speakers to see if your iPod work fine
2) check connector for loosing electric connectivity.
3) check with your headphones to see if your iPod play music well.
4) Check, power on the computer spk. you got. or the input that is working right.
Good Luck
Jan 29, 2008 | Apple Logitech Inc MM50 Portable Speakers...
Car audio problem
Does unit still load and eject cd,s.?? Does audio still work but just display is out?? Does it operate the same way as if acc switch is in off position??
kstahl65@att.net
Jan 12, 2008 | Car Audio & Video
Infinity 3.5c , 2 powered Woofer 5.25" suddenly no sound.,
The woofers on my 3.5c stopped working, but with mine the light was off. I unplugged it and left it for about 24 hours and then plugged it back in and it worked. No idea why. It's happened twice and each time takes at least 12 hours or a day or so before it'll work again, just unplugging it for an hour won't do it.
It seems like both times the problem started when the speaker got unplugged without it being shutoff first, but I can't confirm.
But if your light is still on it's probably a different problem. With my 4.1t towers when the light was on but there was still no sound it equated to numerous fried amp components which cost about $150 for repair.
Oct 31, 2007 | Infinity Intermezzo 3.5C Center Speaker
Subwoofers unresponsive
Check the physical condition of subwoofer to make sure that the surround has not rotted out or been blown away. If ok, then using an ohm meter check for the nominal speaker voice coil resistance to make sure it is within spec. If both of these areas are good then you have destroyed the output stages of the amp(s) driving them. Every 3 db of bass boost doubles the output power. So if you are blasting along at 100 watts and you jack up bass by just 3 db the amp now has to put out 200 at those lower frequencies; go up by just 6 db and you are now talking 400 watts! And what does that do to an amp when you over drive it? You guessed it!
Aug 27, 2017 | JVC MX-G50 CD Shelf System
Amp stopped working...
Has the amp been overheating lately? It's quite possible that the amp could have just blown. Smell around the outside of the amp for an electrical burnt smell. If available, see if a friend also has an amp hookup and try removing your amp and copnnecting to the friend's cables. That will tell you if it's a wiring problem or an amp problem.
Sep 13, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Infinity Reference 611a Car Audio Amplifier Logo
157 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
