Question about Sirius Stiletto 2 Portable Satellite Radio Receiver
Stiletto 2: Device works, but no radio
This is the 2nd S2 I've had in two weeks and after a few days of working fine, I get to the channel page, select a channel and nothing happens. My stiletto 2 has a similar problem. It will connect to the internet and display channel selection however after attempting to select a channel, nothing happens. Connecting to a sat. will also result in nothing happening. The library section still works. Any advice?
I've had this same problem happen a number of times to mine and all I do to fix it is to disconnect the battery for about 20 seconds and then reconnect and power on. Has fixed it every time (so far)! Hope this helps!
Posted on Jun 08, 2009
My Stiletto 2 works fine in the car and in the home dock, but it will not read my battery. I have changed batteries out with another Stiletto 2, and the batteries show 100% charged in the other Stiletto,...
You may want to try to run a device recovery. Sometimes when a battery is drained, the Stiletto only remembers the status of the last battery as it ran completely out. A device recovery would help it reinitialize and recognize a new battery. Instructions and links for device recovery can be found here: http://www.tss-radio.com/links
Jun 13, 2011 | Sirius Stiletto 2 Satellite Radio Receiver
How to debug a stiletto 1
Stiletto 2 ...pin bent...now broke off !
The pin on the Stiletto 2 connector was indented a little last week. This week it broke off and the radio will not work. I am thinking the dock connector would have to be replaced.
Anyone know who can repair this?
Is this a common problem for the Stiletto 2 ?
Thank you !
Mar 19, 2011 | Sirius Hoods Stiletto SL100-PK1 Satellite...
Sirius Stiletto SL100 not recording Replay
Just plug in the usb wire and wait a few minutes and see if new down load comes on your pc.Download it.You'll lose all recorded info.They say buy a new 1 when they're not sure whats up.Don't think many are trained.It's like a pc it bogs down .screws up.Needs up dates etc. union k
Mar 10, 2009 | Sirius STILETTO 100 MP3 Player
I have seen the same problem. If I remove the battery and then reinsert it, the radio re-initializes and works fine. For some reason it appears that the Satellite reception gets disabled. Taking the battery out and in seems to reboot the radio.
Jan 13, 2009 | Sirius Stiletto 2 Portable Satellite Radio...
Stiletto 2 Internal Antenna broken - Am I F'ed or what?
you can try to open it and resolder is really easy but you have to be carefull when you take it a part there is many small resistors and capasitors near the antena and you will need a scope to see the wires and to solder i fixt my like that and it works fine
Jan 12, 2009 | Sirius Stiletto 2 Portable Satellite Radio...
Can I use a stiletto 2 home kit for my Stiletto 1 receiver?
no sorry it wont the stiletto 1 it deeper than the stiletto 2.
Dec 04, 2008 | Sirius Home Kit for SIRIUS Stiletto 2...
Sirius Stiletto 2 Problem
That's one of several problems my Stiletto 2 has. The only solution I've found is to "reboot" the unit. You'll have to remove the unit from the cradle, pop the back off, and remove the battery for a few seconds. Then put everything back together and power it up. It will take a minute or two, but once it reboots it should be fine.
Aug 15, 2008 | Sirius Audio Players & Recorders
I'm recieving a strong signal on my stiletto 2 but no sound on the radio. The MP3 player works with headphones and so does internet radio.
You need the firmware upgrade from the Sirius website:
Bug Fixes
· Reduced incidence of “acquiring signal” and “antenna not detected” messages
while the radio is installed in the Stiletto Vehicle dock (SLV2)
· Improved audio quality and distortion reduction
· Reduced incidence of long block recording and Radio Replay corruption
How to Get this Release
Updating over WiFi:
Subscribers may update Stiletto 2 over WiFi by following these steps:
1. Power cycle the Stiletto 2 by holding the power/lock switch down for 5 seconds
and releasing.
2. Turn on the Stiletto 2 and press the HOME button
3. Use the MEDIA DIAL to scroll to Internet Radio
4. Press the SELECT button to connect to Internet Radio
5. Tune to your favorite station and let it play for several hours.
6. Follow prompts on screen to complete the update, then power cycle your radio to
apply the updates.
7. Next go to HomeSettingsDeviceDevice info, if the baseband version is
already 00.14.94 you are done. If not, continue to the next step.
8. Reconnect to Internet Radio and listen for at least 15 minutes.
9. Disconnect, and tune to Satellite Radio. Updating Sirius will be displayed for
approximately 5 minutes.
10. Once the message clears, your update should be complete. Go to the Device
Info screen to verify the update has been successful.
Updating using My Sirius Studio™:
Customers without WiFi access may update using My Sirius Studio™ running on a PC
with an active internet connection:
1. Launch My Sirius Studio™ on your computer. Be sure you are running the latest
version of My Sirius Studio, currently version 1.5.1.
2. Power cycle the Stiletto 2 by holding the power/lock switch down for 5 seconds
and releasing.
3. Turn on the Stiletto 2 and connect it to your computer using the USB cable
supplied with your device
4. In My Sirius Studio, click on the gear icon next to the device or go to File
Device Settings Check for Software Update.
5. Follow the instructions that appear in My Sirius Studio™ to complete the update.
Please Note: During the update, your media library must be re-built. If you have a
large amount of content stored or a microSD™ card installed, the process can last
for as long as 10 minutes. During this time the message “updating media library” or
may be displayed.
6. After disconnecting from your PC it will be necessary to power cycle your Stiletto
and connect to Satellite Radio to refresh your channel list.
For additional questions regarding your Stiletto 2 or the SIRIUS service, please refer to
the product manuals. You can also reach the dedicated Stiletto Technical Support Team
at 1-800-869-5364 from 10 AM to 10 PM Eastern Time Monday through Saturday, or by
email at customercare@sirius-radio.com.
Jul 06, 2008 | Audio Players & Recorders
White square on sirius stiletto 2
I ran the stiletto device recovery program and it works again. You can find it on the Sirius website by searching for "stiletto device recovery". However, it does delete all of the content that you have saved on the stiletto.
Feb 02, 2008 | Sirius Stiletto 2 Satellite Radio Receiver
Sirius Stiletto 2 Portable Satellite Radio Receiver Logo
400 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
