Question about Whirlpool WFW8300SW
Bad smell in drum of washer
Bad smell in drum of washing machine bad smell from in between the tub and the housing
  • Anonymous Mar 30, 2014
    after not using it smells bad
    Scholar:
  • 72 Answers
Unfortunately this is a quite general problem today as we are washing more and more in rather low temperatures. Gunk and slime packs up in the rubber gaskets and elsewhere in the machine, smells horrible if not kept under control.
There are a few things you can do.
1) The most important thing IMO is to make sure to wash at the highest temp at least once a week, 90-95 degrees Celcius.
2) Always leave the washing machine lid half open when not in use in order to allow the inside to dry.
3) A supplementary thing is to run an empty machine wash cycle once a month or so using bleach (chlorine) in the recommended dose for your machine. Use highest temp to maximize effect.
There is also some work that can be done with a rag, mechanically cleaning out the gasket and all accessible parts in the detergent compartment etc, however this may have quite limited effect. Worth trying nevertheless.
Other than that you c
Posted on May 27, 2009
  • 1 more comment
  • Håkan Sterner May 27, 2009
    I was going to say it could be a good idea to complain to the place where you bought the machine and/or to the manufacturer,
    I'm sure they can come up with systematic solutions that are built into future machines if they are forced to do so. It will not help you in the short term though, I don't believe there are any brands or models that could be singled out as being much better than others here.
    As I said, there are a few things that can be done to keep the problem under control.
  • Håkan Sterner May 29, 2009
    How is it going for you, OP? Did yu find the suggestions useful to solve you problem? Maybe you already tested it all? Please give some feedback or people like myself will be much more unlikely to take the trouble of posting potential solutions in the future. No feedback, no learning, no fun.
  • gcsa Jan 06, 2011
    I have suffered the same problem with my Hotpoint front loader and although I gave it a good clean, pipes as well it still had a bad smell. Use a water softener tablet or a stain remover occasionally and it keeps it away. Hope this helps.
Thank you Posted bybad smell in drum of washer - avatar11.jpglandryphotog on May 27, 2009 $(".meta").find("img").brokenImage({ replacement: "http://c.fixya.net/fixya20/images/icons/expert-not-found.jpg" })
I have been running a spoon full of eucalyptus oil thru the spin cycle, this masks it until the next wash
Posted on Mar 24, 2012
My washing machine smells bad . There is grime stuck between the rubber boot and drum . How do I fix this
Make sure you are using HE detergent. Non He detergent can cause a mold smell because it does no dissolve and builds a film in between the inner and outer tub. You should probably run a washer cleaning solution.
Aug 14, 2013 | Samsung Washing Machines
Ge front loading washer drum fills with smoke at end of last rinse cycle and smells of burning rubber
THE INNER DRUM IS BAD WITCH LETS IT RUB THE FRONT SEAL OF THE WASHER YOU NEED TO SEE IF YOU CAN MOVE THE DRUM UP ARE DOWN ARE SIDE TO SIDE IF SO ONE OF THE SUPPORTS ON THE BACK BROKE AND THE GET THE SMELL OUT WASH THEM IN WHITE VINAGER
Oct 31, 2012 | Kenmore Front-Load Washing Machine 3.5...
My LG front loading washer smells like wet clothes that have been in the washer for months? Musty smell?washer overnight? Strong smell of musty old clothes
This is caused by the biomass built up inside the tub of the machine. This can also be caused by a moldy door boot. You need to scrub your door boot between the tub and the door. Water settles in the bottom of it and molds. Once you clean this, order affresh washer cleaner for your machine. This kills all the biomass built up in the tub and removes the smell. You will put all three tablets in the drum and run on the longest hottest wash available. When this is completed your machine should smell much better. To keep this from getting so bad again... Keep the washer door cracked open between cycles. This keeps the inside from smelling. Hope this helps
Apr 04, 2012 | LG WM-2277HW Front Load Washer
Washer smell
If this is a front loader, clean around the rubber "boot" inside the doorway between the front of machine and the drum by pulling out a little to reveal buildup behind it. This can get a funky smell. You can also run the "sanitary" cycle if your unit has one, with bleach, which will clean the tub better.
Jan 12, 2012 | Kenmore Washing Machines
My front load washer has bad rotten egg smell when draining water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} A lot of machines can suffer from this problem. It is usually down to a bacteria build up between the drum and the tub. The majority of appliances that suffer form this have been used mainly on 40 degree washes and with a biological detergent.
The best way to get rid of this smell is to place two tablespoons of washing soda or soda crystals in the detergent drawer and then run the appliance empty on the 90 degree wash. You may have to repeat this treatment several times before the smell goes but it will go eventually.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
Jan 24, 2010 | Frigidaire ATF6000ES Front Load Washer
Smells very bad inside washer
Jan 20, 2010 | Speed Queen CTSA0AWN Front Load Washer
Water remains in tub after spin cycle
Have you tried to clean the drain hose on the back of the washer? It may have build up inside that you are loosening up by using bleach.
Sep 06, 2009 | Frigidaire ATF6000ES Front Load Washer
My Maytag washer has a defect, technican told me, that lets water get between the tub and outer lining and sit there and stagnate smelling terrible.
The water always goes from the tub to the outer shell, that is where the pump connects. Put a little bleach in the tub with some water, shake the agitator side to side to move the drum enough to circulate the bleach around the tub. Then pump the water out and then lower the hose down to a bucket to get the last of the water out. Feel around between the inner and outer drums for anything that has jumped out of the inner tub to the outer drum. You should be able to push the inner drum aside enough to get your arm in. You may have to open the top to get your arm in the space.
http://www.pcappliancerepair.com/model-display.php Check this site for your machine.
May 07, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Clothes come out of washer smelling musty
It sound like lint bult up under agitator orIn Between inner and outer tub it would have to be manualy cleaned thanks and good luck:)
Nov 16, 2008 | Maytag MAV3855A Top Load Washer
Law Suit
I don't know anything about a lawsuit with LG but the proper solution to this is to have a qualified LG tech disassemble the washer drum and tub assembly and wash it down with a garden hose.  Once it is cleaned out, the smell is gone.  To avoid the smell from returning, do not put more than 2 tablespoons of detergent per wash.  The reason is that the washer can produce excessive sudsing and line it throughout the tub.  The front load washer cannot rinse this excess suds off by itself and will in time, cause that nasty odor again.
Apr 06, 2008 | LG WM-2277HW Front Load Washer
Whirlpool WFW8300SW Logo
328 people viewed this question
Dan Webster
Dan Webster
Sal De
