Question about Invacare Supply Group Invacare Pronto M91 Electric Wheelchair
Wheelchair has power will not go
Controler flashes but will not engage gearbox and drive wheels
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Hi there Got a grating noise on my pronto electric wheelchair. Almost like a drive belt (if they have them) is broken on one side.
No belts on the M91. Your right motor sounds like it has stripped gears. The gears cannot be replaced. The whole gearbox has to be replaced. Most stores will only replace the complete motor and gearbox assembly. Invacare may not sell just the gearbox.
May 27, 2014 | Electric Mobility Invacare Pronto M41...
One drive wheel does not turn. If you pull the release lever,it still does not turn.
There are TWO release levers on the Smartie. (Link to specs and manual below) Please make sure you are engaging both levers. If you find both levers and are still having issues it is likely that you have a broken or frozen (rusted/oxidized/clogged) brake disk. This issue is common to all power chairs and scooters in high humidity areas.
A frozen brake disk require disassemble of the brake on the end of the motor, cleaning with super fine sand paper or an emery cloth and then careful alignment and re-assembly. This is a pain and requires skill and patients.
THe issue may also be a bad motor or gearbox. If the motor or gearbox will not turn once the brake has been removed then it is a bad motor/gearbox.
Many dealers will not invest the time to replace or fix the brake and will opt for replacing the motor/brake assembly as it is a sure fix and not time intensive. Shoprider Smartie Power Chairs
Feb 27, 2014 | Shoprider Smartie Power Wheelchair ()
MPV4 - Right wheel is semi locked
Could be a number of issues here.
Caster bearings need cleaning\replacement
Fork bearings need cleaning\replacement.
Drive Tires could be too low and need air.
Motors were not properly mounted to gearbox and/or motor coupler is damaged.
Too much crud is wrapped around a wheel - obstruction.
The VSI controller isn't flashing a code so you are electrically connected to the motors, brakes and batteries. Problem appears to be mechanical - not electrical.
Feb 04, 2014 | NRS Hoveround MPV 4 - Hovaround Used...
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
On the dash of my 92 pajero the two front wheels keep flashing green when its not in 4x4 how ever i degreased under the engine and gearbox and realised after.that the lights had stop flashing until my son...
4X4
On these issue, there are few solved help links for troubleshooting the issue easily.-------
Click the link below: ---
No 4x4 light on dash?
http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Car will not go into 4WD high or 4WD low?
http://schematicsdiagram.blogspot.com/2011/12/car-will-not-go-into-4wd-high-or-4wd.html
4 wheel drive system will not disengage?
http://technoanswers.blogspot.com/2012/01/4-wheel-drive-system-will-not-disengage.html
4WD light is flashing and beeping? NO 4WD high?
http://schematicsdiagram.blogspot.in/2012/02/4wd-light-is-flashing-and-beeping-no.html
2002 Jeep Wrangler: 4WD Idiot Light is ON?
http://technoanswers.blogspot.in/2012/06/2002-jeep-wrangler-4wd-idiot-light-is.html
Traction control switch will not engage on 4WD High or Low
http://whoisbyme.blogspot.com/2012/10/traction-control-switch-will-not-engage.html
4WD light flashing and 4WD will engage after few minutes
http://repairhelpcenter.blogspot.com/2012/10/4wd-light-flashing-and-4wd-will-engage.html
2008 Toyota Tundra: 4x4 Wheel Drive Light is Flashing?
http://technoanswers.blogspot.in/2012/05/2008-toyota-tundra-4x4-wheel-drive.html
4x4 front differential will not engage the axle on ford?
http://technoanswers.blogspot.in/2012/02/4x4-front-differential-will-not-engage.html
4x4 will not engage on Ford F150?
http://technoanswers.blogspot.in/2012/02/4x4-will-not-engage-on-ford-f150.html
Dodge Ram 4x4 light keeps flashing
4X4 LOW LIGHT IS FLASHING ON DASH
http://technoanswers.blogspot.in/2012/09/dodge-ram-4x4-light-keeps-flashing.html
Ford 4x4 front wheels will not engage?
http://technoanswers.blogspot.in/2012/02/ford-4x4-front-wheels-will-not-engage.html
These details will help.
Thanks.
Nov 28, 2012 | 1992 Mitsubishi Pajero
My right front wheel is "locked" and unable to
Seth first push the freewheel lever for you right motor to freewheel to see if it move if you can turn the wheel in freewheel then the gearbox is not frozen. But even if you can get it in freewheel then the problem of not getting the motor to run when you engage the joystick is a bigger problem I'm afraid the only fix is to replace the motor/gearbox assembly. Now if medicare paid for your chair then they will pay 80% of the repair cost. Contact the provider that sold you your chair and ask if they can repair it. If not contact Repair Express @1-877-581-373 or Roadrunner Mobility @ 1-88-467-2668 to have the chair fixed Hope this helps you
Mar 02, 2011 | NRS Hoveround MPV 5 - Used Power...
My mother has a pride jet3 electric wheel chair that doesn't move now. the power button bar shows full charge and the light below that just blinks. Did she lock it up some how?
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Dec 29, 2010 | Electric Jazzy 1115 Power Wheelchair
Replaced battery in jazzy 600 wheelchair and the light comes on, but wheelchair will not do anything.
Make sure that your drive wheels are engaged and the power chair is not in the freehweel position (so it can be pushed).
Sep 09, 2010 | Pride Jazzy Select 6 Indoor Power...
Chair won't go. Lights flash
Check your freewheel levers. They must be engaged or the lights will flash and the chair will be inoperable. These levers are under the shroud behind drive wheels. (One on each side)
Apr 30, 2010 | Pride Jazzy Select 6 Indoor Power...
My jazzy 1115 joystick controller flashing and the chair doesnot move .
1. make sure it's not still pluged in recharging.
2. make sure both free wheel levers are engaged.
if the jazzy is still flashing and not moving refer to the flash code in your owners manual. count the flashes between pauses. get back to me if you don't have the manual. Mike
smithrm70@hotmail.com
Nov 20, 2009 | Electric Jazzy 1115 Power Wheelchair
Invacare Supply Group Invacare Pronto M91 Electric Wheelchair Logo
127 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
