Sony amp TA-V5 Death
I can't switch on amp. Switch is O.K., Hi-DC voltages on power supply O.K. Low voltage missing. Can me anybody help, missing me schematic diagram. Thanks Viktor The same problem-last point with 300V is that capacitor. Then current should come into switching power supply. There is also relay which is not turning on (described 24VDC). I think that there is missing Remote signal. Any ideas?
MicrowaveSvc
  • 9098 Answers
SOURCE: NEED PART DE41-10330A PCB AND/OR SCHEMATIC
Looks like the new part number is DE91-10368A and it's available for $90.25 from http://www.samsungparts.com
If you'd like the board repaired, we do that for $39.95 in most cases.
We have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Nov 17, 2007
  • 236 Answers
SOURCE: yamaha dsp-/e300 wont switch on
no display at all in your front panel?
you said power supply is ok... all voltages...
i remember DSPE300, small power amp only IC. can you check your +/- main power supply if ok it should be around +/- 35V. If it's there then place your meter neg to speaker ground, the + to red and try to run on the unit. see if you'lll get a pulse in AC meter mode. Or a DC voltage in DC mode.
then check also your secondary supply that's about +/- 15volts. Your standby voltage for the CPU to work is 5V. please check that as well
If the trouble is main amp, you should still have a display screen. Unless it is a total breakdown and main out totally shorted, it really wont turn on but you said you seem to find voltage.
reden
Posted on Mar 19, 2008
SOURCE: sony TA-F210 amplifier no sound
Check R803 and R804!!! They must be 0.33 Ohms. When they are more check the capacitors.
Posted on Apr 27, 2008
  • 4234 Answers
SOURCE: Proton 1100 Pre-Amplifier not working
The probability of a relay going bad is remote. This relay is part of the protection circuit and will not turn on if there are problems detected. If you can detail the parts that have been replaced, I may e able to determine the reason for the relay failure. Realize that some internal measurements may be required as well.
Thanks,
Dan
Posted on Feb 02, 2009
VOTIT
  • 2071 Answers
SOURCE: power supply problem in Behringer pmp 3000 mixer
Just try to resolder all component parts in power supply section,maybe there is a loose connection or cold solder joints that causing of abnormal voltage or missing voltage.Also check the resistor for cange value causing the voltage trap.Check also all electrolytic capacitor for leak. Hope it may help you;;
Posted on Jun 08, 2009
Wht kind of current comes out?
The computer's switch mode power supply produces DC (direct current) electricity.
Nov 05, 2012 | Computers & Internet
Blinking red light won't start
No Power (Totally Death).
  1. Check the output regulator 12volt DC Power Supply.
  2. Check the Fuse (Voltage Security Fuse).
  3. Check the Flexible cable on switch board (reset & eject button).
  4. Check the Output Diode.
  5. Or check the I/0 button.
Sep 17, 2010 | Sony PlayStation 2 (PS2) Console
Monitor LCD of my sony vaio VGN CS 13 G/Q laptop is running blank. The monitor LCD light does not perform appropriately (its light is off. I can not read the monitor's LCD so I must add/connect external...
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 15, 2010 | Sony Computers & Internet
It switches on however can not see anything but a black screen
Try an external monitor & see if it will work. If it does, then this might be a sign of a faulty LCD cable or screen inverter board.
Aug 29, 2010 | Acer Extensa 5635 Notebook LXEEA03007
Power adapter of Avocent SwitchView® 1000
All power adapters usually have a label on the bottom of the adapter that show voltage and current for both the input and output connector, unless that label has been removed. Your KVM switch may have the voltage and current requirements printed on a label on the bottom of the device.
Feb 16, 2010 | Avocent SwitchView 1000 KVM Switch
Use Sony ICF-C1IPMK2 in Europe
A transformer type (Linear Mode Power Supply) AC to DC power adapter with a 9.V nominal output, measures about 12.V without load when tested with a multimeter. A power adapter with a nominal output of 7.5 V, measures a little over 9.V. Considering a number of people across different forums reported the adapter's measured power output as 12.V, I think the nominal rating of the AC to DC adapter should be 9.V. However, keep away from Switch Mode Power Supplies.
Jul 21, 2009 | Sony ICF-C1IP White Powered Speaker System...
Sony AVD-S50ES fully dead.
Below is view of voltage out put connectors of power supply of AVD-S50ES
You can confirm volts on connectors as mentioned here.
6a9021f.jpgGood Luck.
Nov 27, 2008 | Digital Audio (DADVDP) DVD Player with AM/...
Sony 2167 No power on
I have not worked on your particular model. But, I have serviced many TV sets over the years. My answer will ge generic.
Check all the capacitors in the horizontal output stage and power supply areas for high ESR. All the caps that are out of spec must be changed.
The high voltage multiplier & flyback can also cause the fault you are having.
You have to consider that the DC voltages are not the only important spec that has to be met. There are also many power drive signals that work with reactive devices. If there is any defect in the critical areas there will be failures.
Jerry G.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Yamaha dsp-/e300 wont switch on
check your speaker wire and speaker for short circuit.
Jan 17, 2008 | Yamaha DSPE390 Amplifier
238 people viewed this question
 Grubhead
Grubhead
