Question about Sony KP-53S65 53" Rear Projection Television
Tearing Blue streak from top left.
It looks like the blue part of the screen is being torn back from upper left like a piece of paper.
Convergence was off, dead center, but I adjusted that with no effect in the upper left hand corner.
  • 126 Answers
The convergence amplifier responsible for blue is dying. Soon blue will be off all over the screen when it fails completely. Only solution is to have the convergence output IC's replaced.
Posted on May 27, 2009
My JVC projection television AV-48WP30 has green and red streaks at the top with one long blue streak going across the screen. I tried everything that I could to fix it by the tv and remote and it still...
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 22, 2010 | JVC AV-48WP30 48" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
51 philips yellow streak
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 24, 2009 | Televison & Video
Panasonic PT-47WX49E blue convergence problem.
if convergence does not adjust in menu mode could be a defective convergenceic or fuse
Nov 11, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Hitachi dlp - 52" . neon blobs
Hi, the convergence chips on the board are showing signs of failure. simply replacing the board will fix this issue.(convergence board failure)
May 14, 2009 | Hitachi Televison & Video
Hitachi 46f500 convergence?
a common problem wich i also have with convergence with blue and red convergence.
the image converge amplifiers are burnet out wich in turn blow out resisters that control individual color convergence.
Jun 19, 2008 | Hitachi 46F500 46" Rear Projection...
Projection tv - Hitachi
sounds like you need to do convergence.
Feb 21, 2008 | Televison & Video
Blue Streak
I had the same problem w/ the same TV about 6 months ago. You need a new optical engine. Hopefully you are still under warranty. Once that was replaced, the tv looks great.
Dec 26, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
PT-47WX, Blue streaks across the screen?
It is not a bulb. It is a picture tube. If there are thin blue lines across the entire screen, not just the edges, and the picture itself looks too blue, it means that the blue picture tube is being driven too hard. This could be because the blue screen voltage is too high, the boost voltage on the blue picture tube is too low, or the video output is leaky or shorted. If the picture has what looks like blue arcs and double images on one or more sides of the picture, it means that one of your convergence IC's has burned out and needs to be replaced. These are things that should be tested and serviced by a qualified tech, so allow an experienced tech to handle it for you.
Sep 07, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
87 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
