My insignia ns-lcd15 has no audio out the speakers. The speakers are good. I hear this is a common problem with this TV. Whats is going bad on the main board?
  • 1 more comment
  • dougandteri May 27, 2009
    I checked the menu and the speakers are turned on.
    my insignia ns-lcd 15 has no audio out the speakers does anybody know what component is bad. I hear this is a common problem. The speakers are good and the speakers are not turned off.
    Yes, very helpful, Just wanted to know if anyone knew which component was the problem and this took care of that. Thanks!
    Novelist:
  • 130 Answers
You are very correct.you are not the only one facing this problemthere are many facing this problem.and yes its the problem of amplifier ic that is connected on the main board .that goes faulty.and due to this the sound stops working,even though the speakers are proper.as the amplifier is the part which controls the sound in speakers located on main board. you will have to take the help of local tv repair technician as this part is not available online and company has stopped manufacturing this part for sale.but the local tv techs have the compitable part which can come in use of your tv part. if you want to know how the amplifier ic looks  just click the link directly  http://media.digikey.com/photos/Cirrus%20Logic%20Photos/MFG_CS4525-CNZ.jpg
there are two such ic on the main board. the cost of per ic will be near to $10. this will help you. please do rate the solution.thank you for using fixya.keep updated.thanks.
Posted on May 27, 2009
    Top Expert:
  • Televison & ... Master
  • 76,673 Answers
Are you sure someone didn't turn off the internal speakers by mistake, seen it more than once, if that is not the case you will need to replace the audio amplifier board.
  • yadayada
    yadayada May 27, 2009
    then the audio amp section of the main board has failed, there are no parts sources outside of the sellers own repair shops like Best Buy, so you will need to return the tv to an authorized repair facility for repair.
  • yadayada
    the defective component is the main board, but like i said no one sells parts for these yet, not on the market long enough..
Tv has sound but no picture
This is almost certainly a problem with the backlight power supply, not the ac adapter. If the backlight isn't working, you will see nothing on the screen.
Aug 30, 2012 | Insignia NS-LCD15 15" LCD TV flat monitor...
Can I change the font size for closed captioning on model no NS-LCD15-09 TV
To change the text size of close caption, you have to enter its service mode options. For more details, check this link by search to your TV model number
Feb 11, 2012 | Insignia Televison & Video
Insignia NS-LB032X-10A we bought from a friend that claimed virtually no use and we have not manual and can't get any sound out of it. Please help if you can. It is a 32 TV &built in DVD year 2009
Do you mean the NS-LBD32X-10A? The manual is available here: http://insigniaproducts.com/products/televisions/NS-LBD32X-10A.html?supportTab=open . The direct link to the manual is http://insigniaproducts.com/cms/documents/NS-LBD32X-10A%20UM%20EN.pdf .
Check if the speakers are muted or if the volume is low. Then go to the Menu and in the Audio submenu go down to Speakers. Make sure that the internal speakers are on.
If the speakers still don't work, they may have failed or the wiring may be damaged. Unfortunately, I do not see any speakers for the TV from my usual vendors.
I hope this helps.
Jun 21, 2011 | Insignia Televison & Video
Can't run tv sound from my Vizio M190VA tv through my Insignia NS-R2000 receiver so it will play through my speakers in the ceiling which are connected to the receiver. Is it possible to do what I am...
I have no idea why manuafacturers or users think a TV is a good place to originate sound in this Cable Box age. The Cable/SAT box is for all intents and purpose a hi-fi multichannel audio source like any other audio component, where the TV's audio was probably an afterthought.
With that in mind, source the TV-related audio directly to the NS and skip all that zig-zagging of audio all over the room before it gets to your ears.
I also recommend taking all high-end video directly to the TV/monitor from whatever sources you have. Added cabling (and cost) doesn't help. Let the specialty devices each handle what they master.
Does that help?
Mar 18, 2011 | Insignia NS-R2000
Plugged in no power light or picture cord checks out good
replace power supply. multiple components died on power supply to many to replace and some to small for hand solder. cause cheaply made power supply
Apr 27, 2010 | Insignia NS-LCD19 19 in. LCD TV
Insignia NS-LCD37 TV - no sound
Start checking the cable connection to receiver, try moving or replacing cables.
If you have a surround with external speakers check surround connection cable and speakers wiring.
If the cables are OK, then the unit may be faulty.
In that case the fault can be either the audio board (often audio circuit is integrated on the main board) , or the sinput output signal board.
Also a contact on connection to internal speakers can give you same problem.
May 22, 2009 | Insignia NS-LCD37 37 in. LCD TV
Do I need a convert box for my tv.
the screen is not as large as it could be......has black frame around it.....also need a instruction booklet
Dec 12, 2008 | Insignia 15 in. Flat Panel LCD HDTV
Insignia ns-lcd15
The problem i have seen is the main surface mount IC ( the one with the heat sink) runs hot and the connections go bad from expanding. poor design. somtimes pressing down on the heat sink while its on will yield a picture and then goes out.
Feb 12, 2008 | Televison & Video
Insignia NS-8PDVD blank screen...
There is a switch on the side of the DVD player that reads "in / out".  Switch it to out and you should get the blue screen back.  It's a strange set up but this is how it works.
Dec 08, 2007 | Insignia NS-8PDVD
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
