Question about Acer Aspire 3610 Notebook
Starts but shuts down in a minute or two
After it starts up shuts down before it gets to start page fan sounds like its working hard
    Scholar:
  • 62 Answers
The best way to clean the fan is with a can of compressed air and you push the air in the laptop, reversed of the normal air flow.
If you can laptop sometimes have a small cover over the fan underneath the laptop that you can remove.
If you can remove it to clean it better.
If that doesn't work press F8 a couple of time rappidly after the post, like i you are going in safe mode and you will see an option in the list that says : Disable automatic restart on error
If the problem is a blue screen it won't restart, it will show you the blue screen.
Posted on May 28, 2009
  • 344 Answers
Sounds like overheat problem, make sure the vents are not clogged especially around fan intake, the fan can sometimes draw dust in! Just use a vacuum to clear, hopefully this will solve your problem
Posted on May 27, 2009
    Sergeant:
  • 145 Answers
You have a problem with the memory or motherboard, try to contact the vendor immediately
It keeps going through a start up process (clicking and the fan come on then off quickly) at first staying steady then getting longer in the start up process.
Hi David, thank you for your inquiry. I understand that your Frigidaire Refrigerator is cycling on and off more than you expected. Todays newer refrigerator's have to meet Dept of Energy (DOE) specifications for energy savings. Typically the fan and compressor runs to get the fresh food temp down to 34*, the compressor shuts off and the fan runs for thirty more minutes and shuts down. The fan will repeatedly cycle on and off to keep the temp down as close to 34*. Once the temp in the fresh food hits 40* for more than two minutes the compressor cycles back on again. This will cause the temps in the fresh food to dwell between 35-40 and in the freezer section between 8-15. Hope this helps! -JK
Oct 28, 2015 | Frigidaire Refrigerators
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
My dell latitude D610 laptop gets heated up after a few minutes I the start the laptop and eventually shuts down.
  • There is a possibility that the fan of your laptop is not working. Make sure when you power on the laptop the fan is running. And if the fan is not working replace it so that your laptop will not heat up and it will not shut down.
Feel free to reply this solution if you have further questions. Thank you.
Feb 14, 2011 | Dell Latitude D600 Notebook
A/C starts up/Cools/Fan Slows, Unit Shuts down in 4 minutes
Ensure proper voltage to the unit. Check for overheated/damaged wires and/or connections in the control panel as well as at the fan motor and compressor.
Apr 03, 2010 | Dometic Rooftop RV Air Conditioner
About 10 seconds after i turn on my aspire 3690 the fan shuts down. the laptop will run for several minutes and then it shuts down also probibly from overheating. The fan starts each time i start but shuts...
First thing I'd check is for a BIOS update for your computer under the Acer support pages (acer.com). In some cases, thermal control updates are included in newer version of the BIOS, if it is a manufacturing problem.
Goto http://www.cpuid.com/hwmonitor.php and download Hardware Monitor, start the computer and immediately run the hardware monitor app to check how high the temperature on the CPU gets before it shuts down.
Continuing use under this condition may damage your Windows installation because of the sudden shutdown.
Mar 21, 2010 | Acer Aspire 3690-2196 Notebook
When powering from full shut-down, takes about 30
whenever you want to turn it off, put it on hibernate.
Jan 02, 2010 | Toshiba Satellite M35X-S161 Notebook
Crash!!
Could be Heat, sounds like the system is shutting down to protect the processor. Let it sit shut down over night and see if it runs longer when it's cooled down. Is the fan running?
Aug 29, 2008 | Acer Aspire 5315 Notebook
Power failure
your laptop may become overheated and that is why it shuts down, make sure the laptop is on a hard service so that the fan can get air. hot weather can cause problems as well.
May 28, 2008 | Toshiba Qosmio G25-AV513 Notebook
Acer Aspire 3610 Notebook Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
