Error 100005: ADF PID excess load error
DESCRIPTION: The ADF motor stopped running in the middle of the operation
1. The ADF was stopped by
- Obstacles such as jammed paper
- Overload of the paper feed mechanism
- Disengaging or breakage of the gears
- Failed to read the ADF motor encoder
2. The timing belt become frayed or jumping
3. Contamination of the ADF encoder scale
4. Disconnection, break, skew or damage of the ADF motor cable/encoder FFC
5. Failure of the ADF motor (not completely broken)
6. Failure of the main board
It sounds like you have a sensor actuator stuck up in the ADF housing. Look for a slot in the ADF paper path in the middle. The actuator could be caught in the slot.
E000
Fuser thermistor, heater thermal fuse
E001
Fuser thermistor, or triac
E002
Fuser thermistor, thermal fuse or triac
E003
Fuser thermistor, heater, thermal fuse or triac
E004
Triac or fuser won't shut off
E007
Fuser film is off center or not driving properly. Might be able to reset in service mode 4-407
E010
Main motor drive problem
E030
Counter
E041
Paper deck motor, clutch or sensor
E064
Composite power supply or main motor board
E202
Scan problem. Motor sensor
E210
Lens drive problem
E220
Exposure lamp
E240
Main board or composite power supply
E260
Main board, power supply cooling fan or composite power supply
E261
Composite power supply or fluctuating power
E400
ADF communication to machine
E401
ADF pickup motor or sensor
E402
ADF belt motor drive
E403
ADF feed motor or slip sensor
E404
ADF exit motor
E411
ADF document detect, or registration sensor or edge sensor
E500
Sorter communication problem
E510
Sorter drive problem
E530
Stapler guide b
If you open the adf there is a small strip of glass on the left hand side next to the large glass. If there is a even a tiny speck on that little strip of glass it will cause a line when using the adf. Just clean it with a little bit of alcohol.
Hi benkoh76:
Here is your problem.
Troubleshooting checklist
Follow these steps when trying to solve a problem with the all-in-one.
Step number
Verification step Possible problems Solutions
1 Is the power on?
When the all-in-one is
connected to a grounded
power source and is turned on,
the control panel shows
Hewlett-Packard with moving
cursors indicating that the
firmware code is loading, and
the main motor rotates for
approximately 45 to 60
seconds. When the firmware is
done loading, Scanner bulb
warming up might appear on
the control-panel display, and
the scan head moves back and
forth for 10 to 15 seconds. If
you lift the scanner cover, you
will see that the scanner bulb is
lit. Near the end of this time, the
ADF motor turns on for about
two seconds.
No power as a result of a failed power source,
cable, switch, or fuse.
1. Verify that the all-in-one is plugged in.
2. Verify that the power cable is functional
and that the power switch is on.
3. Check the power source by plugging
the all-in-one directly into the wall or
into a different outlet.
Motor does not start. 1. Verify that the all-in-one is plugged into
a working electrical receptacle.
2. Verify that the print cartridge is
installed correctly. Follow the
instructions on the control panel to
remove and replace the cartridge.
3. Verify that the top cover is closed.
ADF motor does not start. Open the ADF cover and remove any
orange shipping tape inside the ADF.
Verify that the ADF connector is connected
correctly to the scanner.
If the ADF motor still does not rotate, replace
the ADF.
Scanner bulb does not light. If the scanner bulb does not light, verify that
the wire-harness connectors from the
scanner to the formatter are connected
correctly.
If the error persists, replace the following
components one at a time until the problem
is resolved: scanner assembly, formatter.
Hope this helps
I have same problem! The copy/scan function would feed the orginal from the ADF halfway and instead of making a normal loud feeding noise it made a horriable alarming sound and displayed an error message. To fix it: I waited a day or two and bang the top of the feeder cover with normal force while the original is feeding. It appeared the problem is resolved. I have no idea what the problem is, however I think if this work for few months at a time is fine by me.
