Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
SCREEN IS COMPLETLY RED AFTER 15 MIN OR SO
WE HAVE THE KP 51WS510. I HAVE OWNED IT SINCE 2002 OR SO. IT STARTED WITH RED LINES ON THE TOP PORTION OF THE SCREEN... THEN STARTED TO BE A HAZEY RED COLOR AND NOW AFTER THE SET IS ON FOR 15 - 20 MINUTES IT EVENTUALLY IS COMPLETE RED SCREEN. YOU CANT MAKE OUT THE CHARACTERS ONLY VOICE... ANY ONE KNOW WHATS WRONG WITH IT?
  • rubio54 May 27, 2009
    thank you for your information
  • 126 Answers
Yes, the red picture tube has what is called a cathode to heater short. The only solution is to replace the tube. Problem is that it is no longer availible. There is a solution however. The tube can be pulled and sent off for rebuild to a company called Video Display. They do good work but this repair is expensive. Usually running around $400 to $500.
Posted on May 27, 2009
  • 585 Answers
Heater-to-cathode shorts come and go like throwing a switch when they occur. If this comes on gradually as the set warms up, then there is a problem with the drive circuits or the screen (G2) voltage. That is a much less expensive repair.
I have a sony kp-51ws510 projection tv, i replaced the convergence ic's and a pico fuse and then reset the convergence. The tv looks good except for a green shadow on lettering, also on the convergence...
Did you check the two pico fuses on the G board? Usually at least one will blow when the original ICs failed. I am attaching a pic that shows the 2 pico fuses on the G board.
Jul 08, 2011 | Sony KP-51WS510 51" Rear Projection...
HELLO I HAVE A Sony Projection KP-51WS510 IT HAS HORIZONTAL LINES ALL OVER THE SCREEN WHAT CAN BE THE PROBLEM?
SORRY IF I GOT YOUR HOPES UP, I HAVE A KP51HW40 SONY WITH THE VERY SAME PROBLEM...FINE HORIZONTAL LINES COVERING ENTIRE SCREEN AREA TOP TO BOTTOM. I WAS HOPING MAYBE YOU HYEARD SOMETHING??? IF YOU DID PLEASE CONTACT ME AT BMER@CFL.RR.COM, I WOULD MUCH APRECIATE IT.
Nov 19, 2010 | Sony KP-51WS510 51" Rear Projection...
Unable to flash focus, red curved lines at the top of screen, manual convergance will not work, problem started after a lightning storm with power surge
Ur tv now,totally have dead parts,on the tv convergence board.That,why ur flash foucus or manual covergence alignment R,G,B colors line will not matches up.The convergence board parts 2 STK convergence ICS and some or all it resistors,must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 29, 2010 | Sony KP-51WS510 51" Rear Projection...
SONY kp-51ws510 rear projection tv. recently it started showing a rainbow on the left top corner and middle bottom of the screen. what might be the problem? can it be fixed? for how much?
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 20, 2010 | Sony KP-51WS510 51" Rear Projection...
Sony kp 51ws510 upgrade to HD - how to do this
There are inputs on the back of the set. If your tv is Sony 51ws510 then it is capable of HD, but you have to have component or DVI cables to connect the tv to the HD device (HD cable box or DVD player).
<br>
<br>
On your set the component inputs on the back of the tv are video5 and video6 in the middle located in a vertical line (red, green, blue rca video connections with red and white rca audio connections).
<br>
<br>
You also have a DVI input toward at the top of the input panel (white connector with red and white rca audio connectors).
Jan 03, 2010 | Sony KP-51WS510 51" Rear Projection...
My sony 51" model KP-51WS510 flahes red 6 times when turning on.
Six flashes of the Red Stand By Light means the +5V line is probably shorted on the A or B board. Could also be an overload. Replacement boards can be ordered here: http://servicemanuals.vstore.ca/
Sep 25, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony rear projection kp-51ws510. color alignment
sounds like bad convergence IC---not uncommon on this set-both convergence IC"s need to be replaced and the set adjusted
Aug 07, 2009 | Televison & Video
Sony KP-51WS510
you need a green CRT thats whay you have the white kind of concave lines with the green screen. You can try adjusting the green screen control but you need anew CRT ( tube) the speaker cover has two plastic plugs that get removed on the lower edge os the grille which covers the two screws that hold the grille on. If you need more assistancr or where to get a green CRT let me know as I have a link that has some green and red Tubes for your model.
Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony kp-51ws510 tv
wow that should have taken care of it, check voltages on g board (power supply)
Feb 16, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
