Question about Gateway Solo 9500 (3500847) PC Notebook
Can't use install discs
900mhz P3 cpu, 512mb memory; I bought this laptop used w/o a hard drive, and installed one last week; when trying to install 98SE using disc 2 of the install disc, I get a message saying they are only for use in a Gateway computer; any ideas what the problem could be?
    Sergeant:
  • 145 Answers
Why dont u using booting CD? it much more easier..
Posted on May 27, 2009
I have an IBM Thinkpad 1200 and its running slow, i need to change the CPU to a faster one. What CPU is available for it?
I think cpu changing is not wise in budgetry if really you need to make your device faster .
if really you want to make it faster just change the motherboard and cpu to gether but still its not resionable.
better to try and increese the ram and the use faster hard drive .
and run only the programs only required by disabling application on startup.
Dec 13, 2010 | IBM ThinkPad i1200 1161 Notebook
Newer system with higher performance specifications
To maximize the best performance for your model, you would need
- Highest CPU 1.80GHz
- Maximum memory amount installed (2 x 512MB PC2700 DDR)
- Virtual Memory / Paging File size set correctly
- Use 1GB Flash Memory Drive as additional Virtual Memory
- Hard Disk with highest RPM (7200)
- Minimum programs in startup items
- Install FreeRAM XP Pro 1.52
- Windows XP Professional SP3
- Low resource using Antivirus (Norton 360 v3.5)
- Use Laptop Cooling Pad to keep components cool
At some point, if you want to have a fast performing machine to run newer operating systems, and a higher video card size for media and games, ultimately you should invest in a newer system, then adding harder to locate more pricey components to an older machine.
Adding new hardware to a desktop can be somewhat straightforward for a non-tech. Adding these same componenets to a laptop, is no so easy for the untrained, and can cause damage to other components, not to mention labour costs can get to be quite high.
I hope this helps.
Jan 10, 2010 | Compaq Evo N1000C Notebook
Rebuilding Acer Aspire 3660
Acer Aspire (NoteBook) 3660 Series
Please see below for the Memory ( RAM ) upgrade options available for the Acer Aspire (NoteBook) 3660 Series.
Memory Details for the Acer Aspire (NoteBook) 3660 Series Standard Memory : 512MB (Removable) Maximum Memory : 2GB Total Memory Slots : 2 Memory Type : DDR2 667MHz (PC2-5300) 200-PIN SODIMM
Dec 28, 2009 | Computers & Internet
Ubuntu install fails at random points on via epia mII 10000 mini itx system. Memory & hard drive test OK. Tried 9.04, 8.04, alternate install - all give the same sort of results. Suspecting...
As you try to install, there should be a read-out on the screen, if not set it so that there will be as you install.
Take note of the errors. You may not have enough memory to install this OS. Try a smaller different Linux version. Look at the Ubuntu home page and ask for help.
Aug 23, 2009 | Computers & Internet
Can't run a PC game, but its properly installed.
Chances are the desktop PC had a video accelerator and the laptop didnt. Laptops have integrated video cards that share the systems processor and memory to do its work. Video accelerators have their own dedicated CPU and memory and take the video work away from the system. A video accelerator with say 64 to 128 mb of video memory may have a 250 to 300 mhz CPU on the card. This means the system can dedicate the full 1.5 GHz and 512 mb of memory to the game. Integrated video cards like this one will give up about a third of its memory AND half of its processing power to run your game. In essence, the laptop is SLOWER than the desktop when playing the game. If the laptop is running Vista, then the slowdown is even greater.
Mar 01, 2009 | Computers & Internet
Laptop is a Sony Vaio VGN SZ230P. It started freezing up. Looked in Task Manager and SYSTEM was using 80% or more of CPU. Reformatted using the recovery partition and problem was still there. Reformatted,...
It could be a bad driver, have you checked Sony's site for an update, or looking a non-sony, later version of the driver for the device, perhaps just google SigmaTel [device name]?
Feb 03, 2009 | Sony VAIO VGN-SZ230P/B Notebook
My acer aspire 5600 warned that I am running out of memory. My "D" drive says there is 30g of free space. How do I use it?
I think the computer actually said you were running low on Virtual Memory ... memory is the physical ram installed in your machine ... virtual memory is an area of hard drive the computer uses to store data when in runs out of "real" memory .....hard drive space is nothing to do with memory.
Ok, that got that cleared up :-) .... now the quickest way to get over low virtual memory problems is to install more RAM. For XP you should really have a minimum of 512mb .... 1gb is probably optimum. For Vista you should really have a minimum of 2gb.
So if your laptop has less than 512mb(xp) or 2gb(vista), the first thing to do would be to upgrade the memory.
Virtual memory problems should only ever crop up when you are running multiple applications .... so just try and keep the amount of programs you have running to a minimum. Instead of just minimizing programs, try to close them down to save memory.
Jan 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Please help me in my RAM
Hi hope13,
you had it correct the first time. The DDR2 533MHz memory should be in the Blue slots. When using two DIMMS the motherboard requires the DDR2 533MHz memory be of the same size, brand & speed. For you to get a blue screen has nothing to do with you're memory. If there was a problem with you're memory, you bios would let you know by beeping a series of repeating beeps. Blue screens are usually caused by software & some hardware like you're hard drive. If you have data on you're hard drive & you do not want to erase it by re-installing windows fresh (That includes a must format), than I can suggest you download this software from this site. Click on the link.
http://www.ultimatebootcd.com/ Read what the software can do for you. If you do not want the software. Than break out you're windows CD & load it into you're CD-ROM drive. Boot the PC to the CD-ROM drive & in-stall windows. You're PC will function again when you finish installing windows & you're motherboard driver cd.
Good Luck!
I would have posted sooner but I though another was answering you're question.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 14, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
Upgrading hard disk
yes of course it will handle a 40gb hard drive..your P3 will handle a hard disk up to 60gb...coz i have a friend, his using a P3-700MHz,512mb, 64mb video card and barracuda 80gb hard disk=.)..to make it sure..bring your P3 to the computer shop so you can also know if your P3 is handle a 40-60gb hard drive..thanks..
Feb 20, 2008 | Dell OPTIPLEX GX1 PIII-550MHz 128MB 10GB...
Upgrade processor?
I read the thread over at computing.net just now. I'm having trouble locating a picture of the internals of the Deskpro 4000 online but I know Compaq did some pretty non-standard things back in the day.
Yea, try upgrading the processor - it's not going to cost much to try. Much as WebsWonder commented, I've been throwing out everything below 2ghz at work.
The 2mb S3 Graphics was great for its day. Look around on eBay and find a PCI interface card with 8 meg of ram or better. An ATI 7000 series would be good n cheap but even a Rage 128 would be an improvement over what you have now.
I honestly don't know if upgrading to 333 mhz is going to produce smooth video for you. I upgraded my son's Compaq Armada 1750 from a P-II 333 to a P-III 500, bumped the memory up to the max 312, and installed a 7200 rpm hard drive. It streams video just fine on XP Home.
Nov 11, 2007 | Intel Pentium MMX , 233 MHz
Gateway Solo 9500 (3500847) PC Notebook Logo
52 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
