Question about Lexmark E232 Laser Printer
Can I print legal size from Lexmark E232 or is there a 2nd tray?
I have a Lexmark E232 and I need to use legal size paper. Can this be done or is there a separate tray that needs to be purchased?
    Genius:
  • 1,018 Answers
Please follow this link:
http://www.lexmark.com/publications/pdfs/e230/eng/ug.pdf
Go to page 23.
Don
Posted on May 31, 2009
Where do I load legal size paper 8.5 by 14 to print on my m2727nf
The tray should extend to the 14" length size, pull the tray all the way out and look for the unlock (green) lever...Extend the tray to the proper size and then install the paper. You will most likely need to go to your paper size settings in the menu of the printer and tell the machine that you changed the tray to 8.5 x 14...usually under paper tray settings. If you do not have a way to extend the tray then you do not have the option to run 8.5 x 14 paper and an optional tray will need to be purchased, or the bypass tray can be used but only 10-15 sheets at a time.
Hope this helps
Dec 22, 2014 | HP M2727NF Laserjet Printer
Lexmark officeedge pro550 print drawer won't close with legal size paper in it
That's normal. If you extended the tray to accommodate legal-size paper, then the tray sticks out from the front of the printer when inserted.
Aug 24, 2012 | Lexmark OfficeEdge Pro5500 - multifunction...
Lexmark E232, keeps telling me paper tray is empty even though it has paper in the tray, then it just keeps clicking instead of picking up the paper and feeding into the printer? Please help
Go the Lexmark website and search on support for their telephone number. I've always had a experience with their support team even if the printer is out of warranty.
Apr 05, 2012 | Lexmark E232 Laser Printer
My Lexmark T640 does not seem to recognize paper "tray 2". I want to print legal, but it only prints from tray 1. How can I get the printer to recognize and use tray 2 so I can print legal AND letter?
2 things
1st make sure the paper guides are set correctly on the trays for legal make sure it's exactly on legal or it put the tray into universal mode. (To clarfiy the guides in the back which allow you to put legal in the tray.)
2nd Go into menu and then to paper menu and adjust/ confirm the settings for tray 1 and 2. Based on your question tray 1 is letter and tray 2 is legal, so make sure both of the tray size and type are set correct.
Oct 21, 2010 | Lexmark T640 Laser Printer
Model Lexmark C532N - Has two paper trays - the top tray holds the regular 8.5 x 11 paper the bottom tray holds the legal 8.5 x 14 - It was set up to automatically choose the correct size paper. Now we...
was this printer removed or installed while it was powered on? if it was the control board in the lower tray will need to be replaced this can and often does short the board. does the tray show up in the paper menus?
Aug 05, 2010 | Lexmark C532n Color Laser Printer
Want to print on legal size paper from Tray 1 (top) as default
print menu - config and verify paper is being sensed correctly. If paper size in tray is not set correctly printer will ask where to print from
Feb 12, 2009 | Lexmark T640 Laser Printer
Printer Trays
I have the same problem. Tray 2 shows "!" and doesn not print. PLEASE HELP!
Jul 02, 2008 | Lexmark T632 Laser Printer
Lexmark E232 - Tray-1 Paper Problem
Have the same problem after 1,500 pages! This was Lexmark's solution (and it worked)...
Take the paperfeed tray out and you will see a red lever , press it
downwards and you will see the paperfeed rollers coming down , you need to
pull the rubber tyres off those rollers and place them inside out over
them and then try printing any document. Check the paper weight and
the paper type you need to use 20 pounds regular paper and try runnning a
can of compressed air inside the machine.
If rubber tyres on the paper feed rollers are totally worned out you
need to replace the feed rollers.
Oct 31, 2007 | Lexmark E232 Laser Printer
Problem with my LEXMARK E232
set both trays to correct paper type and  size on printer, also look at settings in print driver on pc (printers and faxs /  right click on lexmark driver and properties check all settings.
Oct 25, 2007 | Lexmark E232 Laser Printer
Lexmark E232 printer problems in 8.5 x 14 page
Software issue for the printer. Uninstall driver and reinstall. If this does not solve it, it may be time for a new printer. Lexmark printers do not have a long service life.
Jun 23, 2007 | Lexmark E232 Laser Printer
Lexmark E232 Laser Printer Logo
160 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
