Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Hotpoint washer dryer leaking water whilst drying
My hotpoint ultimate extra washer dryer leaks water when using the dryer? any ideas?
  • seankyle Nov 20, 2007
    leaking water and drawer not filling up
  • Anonymous Mar 30, 2014
    Control panel flashing
    Problem Solver:
  • 12 Answers
Driers work by running cold water down the back plate of the machine so the hot damp air condence's on to it. It works on the same principle as your bathroom mirror, because its colder than the air around it the moistier in the air condence's on to it. Most machines use a seperate inlet valve from the cold water to do this, they are proned to rub against the back of the drum.Take the top cover off the machine and check the hose's from the cold inlet onto the back of the machine you'll probably find a hole worn in it.
Posted on Jun 15, 2008
It only wash & don't spin? Then it stops and leak water by the door....
LG Washer & Dryer 7 (WD12331AD)
Its is a direct drive front loader with 7kg capacity for washing and 3.5kg capacity for drying.
when new
thats 7 kg with wet clothes and water
and only 3.5 kg wet clothes to dry
the older it gets the less weight it can wash and dry
worn motor or drum overload if it doesnt want to spin at all
leak at the door . replace the door seal ..is a most common fix
extra info
It has 9 preset settings, 400 - 1200 RPM, 5 temperature settings, digital display and delayed start timer.
Sep 20, 2016 | LG Washing Machines
Hi i have a leak under my hotpoint wdl540 the pipes are all clean and dry and the washing machine still works where would the water be coming from?
Could possibly be a little knick in the door seal or from the corner of the dispenser (the drawer in known to leak and the best remedy is to adjust the front feet so the unit is tipping back slightly, this allows gravity to help the flow of water in the drawer ). The valves could be leaking on the inner side if the machine, Really depends on whether it is a flood type leak or just a small puddle/drip. Run the machine pulled out, whilst stood on some newspaper, this should help trace the area of origin. Keep an eye out when it drains that your plumbing isn't blocked and so the drained water comes out of the standpipe instead of flowing away. Keep me posted or repost if you need further advice. All the best.
Oct 18, 2011 | Hotpoint Aquarius WD640 Front Load...
Whirlpool ultimate care extra large, about 10 years old. when the machine is in spin cycle, it throws the circuit breaker. It started with a heavy load, but now it seems to do it all the time. It started...
Water leaking from tub seal into motor possibly? Try doing spin with dry newspaper under the machine and check for leaks. Could also possibly be water heater element loose or breaking down - leaks from drain hose or water pump body into windings? Dry news paper test should highlight where leaks are coming from.
!0 years old is ancient for a machine and you might consider replacement rather than a repair which will only be throwing good money after bad. Do you drive a 10 year old car? if you do, you expect repair bills to mount up! same with washer. I bet it doesn't owe you much!
Jan 03, 2018 | Whirlpool LSW9700P Top Load Washer
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have water leaking from the dispensing tray, only on the pre wash filling..any suggestions I have a hotpoint washer dryer wd64
Check the level of the machine, may be leaning slightly forward allowing water to leak on that one fill cycle. Lift the front a little by using the adjustable feet and see if it stops.
Feb 16, 2010 | Hotpoint Aquarius WD640 Front Load...
Water leaking at rear
It is probably the hose washer or crimp thai is leaking.
I would suggest that you replace the hose to be on the safe side.
Jan 08, 2010 | Hotpoint Aquarius WD63 Front Load...
Hoove HM6316M Dryer not drying
Where was the water leaking from ?
Has it leaked onto the dryer electrical connections ?
You need to check if there is a circuit board behind the fascia panel.
please let me know these answers
good luck
Jan 25, 2009 | Hoover HW6 160M Front Load Washer / Dryer
Major leak after 20mins into wash cycle!
Have a good look at door seal., and see if you can see any hole or tear in rubber.If o/k, then remove rear panel, and watch whilst it is running, and see if you can see any sign of water coming from anywhere.
Make sure the water is not running down the front from the dispenser, which would suggest a blockage in the dispenser drawer.
These are the steps I would take first.
Also make sure the waste outlet is clear
Plz leave rating and any comment you may have.
Thanks..
Jan 21, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Washer Dryer Leak in left corner
watch the drawer closely as it fills, on out side of machine it might be hard to see or else small hole in door seal also hard to find good luck luck close ire
Nov 27, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
188 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
