Question about ASUS Eee PC 2G Surf Notebook
1996 ford e350 van obd1 code 172
Vehicle starts and idle ok. hesitate when attempt to rev. almost like it is buckling
  • 344 Answers
Fuel mixture too rich, air filter may need replacing.
Posted on May 27, 2009
Where is the diagnostic connector located on a 1993 Ford E350 van
Under the hood, it is red or black triangle, but you need a special to took to scan at that connector. This is a OBD1 system (AKA EEC IV), Not OBD2
May 22, 2016 | Ford Cars & Trucks
Ford e350 van idle relearn after MAF replacement
Whenever you try to reset your vehicle's computer after any
repairs, disconnect the battery negative pole first and positive pole last. Wait 20 mins and reconnect your negative pole first and then the positive.
You may have to drive your car for at least 10 miles or more to see if it worked.
Oct 31, 2013 | Ford E350 Cars & Trucks
Computer code po452 94 ford econoline
Google an OBD Codes you get & read up
PO 452- Evap System Pressure Sensor Low Input
The issue I see is you have an OBD1 vehicle up to 1996
so PO Codes weren't around
Use the internet to check it out
Jun 17, 2013 | Vehicle Parts & Accessories
Code obd1
It is OBD2 and you need to scan the system for fault codes as the first step in solving the problems.
May 21, 2013 | 1996 Mitsubishi 3000GT
2000 ford e350 CNG van p1131
Check the help link provided below:----
Ford runs lean and idles rough?
http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
Thanks.
Nov 26, 2012 | 2001 Ford Econoline
I have a 1996 ford 350 van it has a 5.8 engine in it, My problem is when I start it ,It fires right up after a few cranks but if its in park it will idle high and then stall out or if it been running for a...
Take it to AutoZone for a free diagnostic scan. Your local Ford dealer will charge you $100+ for the same scan.
It sounds like the idle control valve and/or the mass air flow sensor. The scan will accurately pinpoint the problem.
Jun 01, 2012 | 2002 Ford E350
1996 e350 got engine check light p1742 code
Call your local dealer with your vin # ,, there is a recall for that specific code.
96-5-16 • MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATION - CODE P1742 STORED IN MEMORY - NO DRIVEABILITY CONCERNS PRESENT - VEHICLES WITH E4OD TRANSMISSION BUILT THROUGH 10/15/95 • LAMP - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATION - CODE P1742 STORED IN MEMORY - NO DRIVEABILITY CONCERNS PRESENT - VEHICLES WITH E4OD TRANSMISSION BUILT THROUGH 10/15/95
MARCH 1996 PCM - MIL ON/DTC P1742 Set
Jul 29, 2010 | 2002 Ford E350
1996 Ford Taurus power hesitation
If you disconnected the Mass air flow sensor the car should have die out at idle. Check fuel pump pressure at the fuel rail should be 30 psi at idle. Low fuel pressure will cause your po 171, 172, problems which could cause the other to problems. You might be needing a fuel pump and filter.
Jun 24, 2009 | 1996 Ford Taurus
2002 E-250 5.4l hesitation during accelleration
Sounds like you could have a bad coil or boots. When I do tuneups on fords I always use motorcraft plugs, and replace the boots that hook to the coils, also buy some dielectric grease to put small dab inside the boot where it slides on the plug. You will probably also need 8mm socket, 7mm socket, and a wobble spark plug socket, or swivel to reach some of them. I usually try to blow air around the intake to clean any dirt off. Then I do 1 plug at a time, and while the plug is out i crank it over or start it a second to blow anymore debris out. Fords are bad about getting misfires on back cylinders. If you take it to a shop beware book time is about 3.5 hours. Could be worse I just got through last week tearing apart a 6.0 powerstroke in 2006 E350 (No access there)
Jan 10, 2009 | 2002 Ford E250
ASUS Eee PC 2G Surf Notebook Logo
213 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
