Question about Lexmark Optra E312 Laser Printer
Paper keeps jamming when I print multiple pages. Odd time it also does it when it's only one page. Or the page comes out wrinkled - gets too hot and warps.
    Sergeant:
  • 199 Answers
Your fuser my be damage on one part making the paper to stick to it check fuser thank you
Posted on May 27, 2009
Samsung SCX-4300 paper jam
sir i have samsung scx 3201 printer but paper loading problem so plz solloved my problem
Oct 23, 2012 | Samsung SCX-4300 All-In-One Laser Printer
Printing multiple page pdf on kodak esp c310 AiO
I had exactly the same problem as you! Whenever I printed anything of more than 1 page the paper jammed. I now know why... When you go to File>Print in Adobe reader, the print window displays a load of options. Simply uncheck the 'Print on both sides of paper' box. This worked for me! Hope it works for you!
Eoghan12
Jan 31, 2012 | Office Equipment & Supplies
Dell 5310N printing without jams, but pages are wrinkled in an accordion fashion, horizontally across the page.\r\n User also wants to know if they can use manual feed to do multiple envelopes at a time. ...
To fix mine I had to go in and trace the paper route with the duplex option installed...loosened on of the bolts just a little ... now works fine it was being dragged by the overtightened roller.
Sep 20, 2011 | Dell 5310n Laser Printer
Every page printed has a wrinkle pressed into the paper
Its or moisture issue or wrong pressure between fixing roller and press roller.
Jun 30, 2010 | Office Equipment & Supplies
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
I have printed all odd # pages from a document, but my HP Laserjet 4 won't feed these pages back through to print on the blank side with even # pages. I've tried to keep the front (feeding edge) of papers...
You need to try a thicker paper, Heavier stock to double print the page. Slightly more expensive. Recycled paper typically will not work for this type of function. I had this same problem and found this was the only solution.
Oct 31, 2009 | HP LaserJet 4 plus Printer
After paper jamming in printer paper now wrinkles
there still may be a piece stuck somewhere in the unit. Remove printer cover and check inside to see if there is anything at all still in there
Jul 29, 2009 | HP Officejet 5610 All-In-One InkJet...
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
HP 4700n Paper Late Jam
duplex area related jam in other printers. is problem only occurring in tray 1. If so, there is a problem with the tray. If it's happening from tray 1 and tray 2, replace try replacing transfer belt.
May 27, 2008 | Office Equipment & Supplies
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
Lexmark Optra E312 Laser Printer Logo
144 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
