Question about Troy-Bilt Pony Garden Tiller
Pony only runs with chocke 98% closed
My Pony has a 5 hp Briggs Model series 130200 to 131299 (Year 1982). Unit sat for many years with fuel in tank - cleaned tank and a friend says he soaked the carburator in solvent (do not know what solvent or how). Replaced the diaphragm - engine will run with choke about 98% closed. it is impossible to start without spraying starter fluid into the air intake and cannot control speed (runs full out). Can it be that the carb. is not completely cleaned or could there be other problems. Thank you - Paul
    President:
  • 1,489 Answers
Most likely the carburetor jet is still clogged after sitting for years with fuel in it. Putting injector/carb cleaner in the fuel tank may help, but if not, the jet needs to be soaked some more -- or replaced.
Follow mixing proportions on the label for injector cleaner.
Posted on May 27, 2009
Starving for fuel runs fine on starting fluid
Make sure gas tank and gas line isn't plugged. Also, make sure the gas itself is good, might have water in it.
Apr 25, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Hi I have a 22 hp briggs in a husqvarna rider. Started running a little rough at season end last year. This year it started, but ran only about 2-3 min, then would not start at all, put in new plugs (old...
This a common problem after they have set up over the winter. Water has probably condensated in your gas tank and now it is in the gas line. The tank should be drained of old gas and the gas line to the carb should be removed from the tank and blown out with compressed air to remove all old gas/ water. Attach the gas line back to the tank and refill the tank with new fuel. This should take care of the problem. To avoid this next time, just fill your gas tank to the top at the end of the season and leave it full through the winter.
Mar 28, 2011 | Briggs & Stratton Briggs Stratton Intek V...
My 5 horsepower pony tiller just shuts off with no warning after about 20-30 minutes of tilling and will not restart again until it cools down to the touch I have changed the spark plug, drained and...
I also was having issues with an old 5 horse Troy Built tiller that would fire when gas was in the tank then stop running. If it's a Briggs and Stratton engine like the one I have it's probably you can remove the muffler to gain access to the side of the carb. Remove the four screws and the cover off the fuel pump diphram and check to make sure that the rubber isn't cracked or degraded. I replaced the one I had and it now runs like a champ.
Mar 23, 2011 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
90 yj only 70k on it sat for 2 years. 4.2 carb, ran one day now hard start, runs for 15 min. then dies. cant restart unless kept in start position. not ign. switch, fuel pump, cap, rotor, wires, plugs, or...
Check the fuel for a presence of water. I'm sure there was a recall notice on the gasket on top of the fuel tank where the sending unit mounts. My YJ sat for a year and had water in the tank from this leaking. Drain and drop the tank, replace the gasket, and reinstall.
Oct 09, 2010 | 1990 Jeep Wrangler
Gas tank leak
The gas tank would go with the engine. Find the engine number (Briggs & Stratton?, Kohler? ) You can order it online from Briggs & Stratton parts, or like Jack's small engine, or your local mower parts supply. Common poblem with these plastic tanks.
Jul 19, 2010 | Troy-Bilt Pony Garden Tiller
26 hp briggs it is firing and full of fresh gas but wont start.
Well you didn't indicate what its mounted on but the basics are: spark and fuel. Pull a spark plug and make sure you get spark. If you do then it must be fuel. You can try a shot of starting fluid (small amont) into the carb, if it runs on that you know you have a fuel problem. Be sure the carb is getting fuel from the tank. Clean the carb. Maybe a carb kit. With today's fuel, you must take care of your fuel system. Use Sta-bil year round. Fuel can go bad in 60 days.
Jul 18, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Will only run until primed fuel is burnt - 2 seconds or so
Dave,
I am having the exact same problem. Did you find a fix?
Don
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
On a 2-cylinder, 25 hp Briggs & Stratton INTEK twin engine (year 2002, Model 44577-0134-E1), there is a ~1.5-inch rubber hose to the top of the right OHV cover coming down from a round plastic piece in...
Ok I haven't worked on this exact model before but Im curious if the engine runs?
It sounds to me like a fuel pump that uses crankcase pulses to pump the fuel. It is very common way to pump fuel but usually the pump portion is in the carb and not the fuel line.
If it were attached to the intake Id say it was a crankcase breather.
May 01, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Troy-Bilt Pony Garden Tiller Logo
401 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
