No where from the specs of this model it does not have Blue Tooth capabilities. From the user manual there is no Blue Tooth capabilities. Pairing code would be for Blue Tooth.
You could use a 802.11N WI FI ethernet device and connect the TV to it but no blue tooth .
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device. Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
try this, turn on the blue tooth of your headset and then go to the Bluetooth settings of your phone, search for the headset, once paired for sure that it will ask for a code just enter 0000, that is the default pass code for that.
blue tooth will not pair with my new blackberry 8320. keeps asking for a pin. i dont recall setting one up and dont have the manual anymore to remember the basic one it came with.
I notice your message is from June 2008. Answer is easy. Activate your ericsson blue tooth feature. Remove facia of Tevion. On back panel is a button 'Pair'. Hold for a few seconds and the red security light will flash rapidly. Send activate message from phone to connext to radio. Enter code when requested 0000. Replace facia panel. Should be working now.
Pairing: Press and hold until you see a solid blue light (approximately 8 sec) then release.
Search with your blue tooth phone for a bluetooth device and if finds samsung wep-150.
enter pass key or pin: 0000
