Question about Zanussi FLA1001W Front Load Washer
Replacing bearings I need to replace the bearings on my zanussi, could anyone let me know how to do this or point me towards any manuals that will explain how to perform this task, thanks.
  • 1 more comment
  • toga38 Oct 25, 2007
    Thanks for the help, I think I will take your advice and buy another.
  • Anonymous Mar 24, 2008
    We have Zanussi washing machine FLS 873 C. It is old about 10 years. It works very noisy, and my conclusion is that we have to change the drum bearings. I read your web side, and I need a help how to change drum on the washing machine.
    We have Zanussi washing machine FLS 873 C. It is old about 10 years. It works very noisy, and my conclusion is that we have to change the drum bearings. I read your web side, and I need a help how to change drum on the washing machine. I did not work nothing yet.
Hi I found these, I have the same problem but I am taking the easy way out, BIN IT!!!
answer 1:
With your zanussis once you have removed the back half of the pannel and the top pannel. you will have to then detach the motor wire plug. then the heater wires and also the there is a sensoer on the side of the drum that also has a wiring connection. Also detactch the earth wires Then here come the tricky part. if you look on the top of the drum you have a rubber pipe connected to it comming from the washer draw detach that its easy. Then you have to dicconect the door seal from the front of the machine by the door (do not dissconect from the seal from the drum as you dont have to . Then disconnect the the drain hose. once this is all done you have to disconnect the legs, from the drum side. these are easily done as the pegs come out easily if you push in the pips from one side you can either knock them out with a hammer but it is best to pull em out with either some long bent nose pliers or gripping em in such a way with a monkey ranch
Best way og getting the drum out is once you have done all that is to turn the machine onto its back and lifting the casing off leaving the drum
To replace the bearings you need to split the plastic drum that you are talking about. It is held together by lots of 8mm headed screws. Some are hard to get access to but you can get them out. You will need to take the springs off take care to support the weight of the drum and lower it on to the dampers. Now carefully lie the machine on it's front mark and unplug all the wires cut the tie that holds the wires to the outer drum unbolt the 2 bolts that hold the motor to the back of the drum unclip all the hoses that attach to the rear of the plastic drum. The damper pins need to be removed form the drum using one hand feel for a push-in clip at the back of the pin push it in and pull the hexed end of the pin out with both pins out the drum will lift out turn it upside down to expose the inner drum get help, have them hold the outer drum while you pull thr inner drum out you should now see the inner bearing get a bucket sit the outer drum on it and drift out the bearings
Yes, the drum shaft needs to be pushed through the bearings. assuming you have already removed the drum pulley, pick the whole assembly up and 'drop' it, pulley shaft down, onto a protective piece of wood. A few drops from various heights usually is enough to push the drum and shaft through. If you do need to resort to wacking it with a hammer, ensure a piece of wood is protecting the shaft and that the pulley bolt is fitted to protect the thread. Unless of course you are changing the drum shaft/spider anyway in which case damage is not so much of a problem.
     I've just tried to replace the front bearing on a Zanussi (admittedly a different model FLA1001w but a similar construction) My advice is don't bother. The notion of removing the rear half of the drum is pure fiction. All the screw bolts securing the two halves together have their heads on the front half of the drum and virtually all are impossible to get to with normal hands and tools. They are also very tight (rightly so). I elected to remove the whole drum. This sounds daunting but it does allow clear access for the rest of the job. All pipes and wires etc have to be disconnected. Remove the concrete counter balance, pulley wheel etc. Undo the plastic ring clip retaining the rubber door seal, and remove the seal from around the rim. Next I lowered the whole m/c onto its front but making sure that the door could not shut and trap the seal. In this position it is probably easier to remove the springs and the shock mounts. The plastic pins holding the shocks to the rear of the drum have a hidden locking mechanism which you only find out about after breaking one! Again the locking portion is on the front side of the drum assembly and is not clearly visible or accessible. You have to depress the locking tab to allow the pin to be extracted. The springs also have to be released; this is also not as easy as it would appear. Line up a few band-aids before attempting. Then when everything is disconnected it should be possible to lift the whole drum out. It would be easier with two people. If no-one else is around make sure you have a couple more band-aids and a can of lager waiting. Once the drum is out you can then begin to remove the countless bolts holding the two halves together. I then discovered that you really need to remove the motor as well to get the two halves apart. Having got the two halves apart it should then be a simple matter of removing the inner drum complete with spider. NOt so. It really is a tight fit in the rear bearing. Despite much effort, hammering, coaxing etc the shaft would not come out and in the end I gave up and bought a new machine. Maybe you will be luckier than me. I wish you every success and hope you can gain from my abortive attempts.
     I have just done a bearing change on my FJ1093.It requires you
to take the rear of the machine off and work towards splitting the tub in half.Take the drive belt off and the drive wheel. Unplug and remove wires (Element plugs,sensor plug and earth wires.)Remove weight from top of rear tub.Undo rubber fitting at top right hand side of rear tub. Now you have to remove all the bolts around the joint in the centre of the tubs.This is a bit awkward to get into so use a ratchet spanner and a socket set where you can. There are two bolts on the rear tub securing the motor as well.There is two shock absorber units at base that need the plastic pins removing. Once all the bolts are undone the tubs should split, but be aware of two springs at the top that need lifting up out of there locations.Also be careful of the heating element at the bottom of the tub when splitting.In hindsight though you could remove the heating element before you try to split as this saves any risk of damage.The rear tub should come off together with the drum. Once this is removed support the motor and the front tub as you don`t want all the weight to go on the front rubber seal.
Now you have you access to the inner bearing and drum bearing seal once push off the drum and spider support.You can then replace these and also the outer bearing and rebuild is reverse of dismantling.
I hope this helps you and there may be an easier method , but this is the way I did it. Hope these instructions help.
Posted on Oct 25, 2007
Model no.zwf1432 w
If you don't have it, try this on line
Apr 13, 2015 | Zanussi Washing Machines
Zanussi TC7114W Tumble Dryer manual
Just click here for the direct download from PDF : TUMBLE DRYER TC 7114 W TC 7114 S
No websites or forwarding, that is just the manual from factory support website.
Vote the solution if this is what you are looking for
Sep 22, 2008 | Zanussi TC7114W Electric Dryer
Zanussi FLE1216w Repair Manual
Hi, my zanussi fle1216w is skipping the fabric softener stage of the cycle. I've cleaned the dispensing drawer and the surrounding areas, even put on a boil wash in case somethihg was gunge up or visits the Zanussi Owners Manual.
Mar 22, 2012 | Washing Machines
I want to change the light bulb in the oven, can you help me.
I will assume that the ZDQ695 bulb replacement procedure is the same as that for the ZDQ695A. The ZDQ695 uses a 25 W appliance light bulb (300 C). Unplug the appliance before starting. Open the oven and remove the racks for space to work. Insert a flat blade screwdriver between the side of the oven and the glass cover above the bulb. With your hand support the cover and pry it away from the wall of the oven until it releases. Push the top of the cover towards the oven wall and use your fingers to pry the bottom of the cover away from the housing. Then remove the cover. Unscrew the old bulb (counterclockwise) and then remove the bulb. Then screw in the new bulb. Replace the glass cover (position the flange so that it is pointing to the back of the oven) by pushing it into the hole to cover the bulb assembly. Replace the shelves and close the oven door before plugging the oven back in.
Zanussi manuals are available here: . Enter the model number in the search box. Alternatively, the manual for the ZDQ695 is available here: . Click on the Get This Manual button.
I hope this helps.
Jul 24, 2011 | Zanussi ZDQ695 Electric Double Oven
Heavy mechanical knocking on final spin yet drum rotates freely when turned by hand and at low end drum speeds. Doesn't point towards the bearings. I have noticed that drum appears to be rotating slightly...
The knocking is the drum running out of balance due to the drum shaft being worn or corroded, or a worn bearing, a bearing can fail even though it may not sound noisy
Either way it is assoiated with the drum and entails a complete strip down, trust me on this, I do know what I am talking about.
Dec 03, 2010 | Zanussi FC1200W Front Load Washer
How do I replace the bearings on my IZ12 washing machine please?
how old is it? still under warranty? if so, contact the point of purchase, or the manufacturer. if not, it's a hell of a job, and you may be better off replacing the machine! i don't know how old it is, but newer machines are (depending on manufacturer) more reliable, and less expensive for the value. your choice!
good luck!
Apr 17, 2010 | Zanussi IZ12 Front Load Washer
The belt has snapped. Does anyone know how to
If there is no removeable rear panel then it can be done from the top, it is not easy, but I have done it in the past.
If you tilt the washer towards you, it gives more room to get your hands and arms in to fit the belt.
Otherwise it means removing the rear half of the cabinet.
Hope this helps.
Jan 25, 2010 | Zanussi F1245W Front Load Washer
Noisey drum, can bearings be replaced on zanussi zwf 1421 w
Yes they can. Search for a service manual for instructions, on the net. Parts are not usually exspensive, Repairmen are. I did mine in less than an hour.
Nov 09, 2009 | Zanussi F1045W Front Load Washer
Peugeot Boxer Front Wheel Bearing Replacement
No need to go to all that trouble with ordering several bearings.
As there are different weights of Boxers, there are different bearings to suit. If your boxer is registered in the UK its a simple matter of giving the supplier the registration number (Original) and they will supply the correct part for that vehicle.
Apr 27, 2009 | 2005 Peugeot 405
Zanussi FLA1001W Front Load Washer Logo
1,080 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
