Question about Honda Maxus Prosumer MX5223 Pressure Washer
Pressure washer problem
Honda gx340. pump appears to be working fine. motor starts ok and runs at low speed ok. mid rpms it starts to miss here and there. high rpm it starts to miss frequently. after 5-10 mins. at high speed it releases the occasional pop with a flame which disappears instantly. does this about every 20 seconds or so. if I turn down to low speed the engine smooths out somewhat and stops backfiring. it still has substantial cleaning power at low rpm. took the head off, checked valves, seals, piston etc. all appeared to be in great shape. cleaned spark arrestor. spark is strong at plug. checked kill switch, ran with coilwire to killswitch disconnected and engine would start to miss if I pulled gently on coilwire. took cover off to check for grounding out but wire was in perfect condition right back to the coil. coil was fastened securely. put it all back together and it ran exactly the same as before I started troubleshooting. oh ya...little faint puffs of black smoke accompany the misses at high speed. it smells like its running rich. Im not knowledgable with carbs which is why I havent opened that yet. suggestions? MY HONDA GX340 MOTOR ONLY RUNS WHEN CARB IS PRIMED AND THEN SHUTS DOWN AFTER ABOUT 10 SECONDS
  • Samuel Charles Spriggs May 11, 2010
    Before taking the carburetor apart, I'd adjust the air/fuel mixture. There's a screw with a spring at its base on the side of the carburetor -- turn this back and forth until the engine runs smoothly.
    And what's this?: "MY HONDA GX340 MOTOR ONLY RUNS WHEN CARB IS PRIMED AND THEN SHUTS DOWN AFTER ABOUT 10 SECONDS"
  • 1388 Answers
SOURCE: pressure washer stalls
Pressure washers work under very dirty conditions, no wonder they encounter engine problems. Here are a few pointers from a former pressure pump tech. The unloader is a source of engine overloading however this can easily be checked with a pressure guage attached to the gun with a tee fitting having the guage and the normal tip used for the unit. The pressure should never rise over rated pressure. The pressure should drop considrably when trigger is released. The life of the pump and engine can be increased by setting max pressure to 75% of rating. Most engine problems are from following conditions:
Leaking or misadjusted valves; clogged muffer /spark arrester; weak spark coil that is about to fail completely; kill switch/oil sensor wiring and or sensor mal function; gas cap not venting properly causing vacuum in tank and wet or dirty air filter.
All these problems easy to check, fastest repair is to disconnect oil sensor wire to check oil safety system. Then temp replace coil with known good coil. Loosen muffer bolts to check for clogged muffler. Temp run engine without gas cap to check for vacuum. Finally if everything fails, run the engine with carb cleaner spraying directly into the intake. If the engine continues to run with carb cleaner then the problem is fuel delivey and faulty carb. enjoy
Posted on Dec 01, 2008
txkjun
  • 409 Answers
SOURCE: Honda Misses.
Pin point the dead hole and check that injector.
Posted on Dec 24, 2008
  • 10865 Answers
SOURCE: honda powered gx160 model pressure washer wont start
Buy a new plug, drain out all of the old gas and put in new gas, and take a look at the air cleaner. If the air cleaner is dirty replace it. There you now have a good spark, good fuel and good air. The engine should start. If it doesn't get some carberator cleaner spray and some starting fluid spray.
Posted on Apr 12, 2009
  • 6 Answers
SOURCE: honda cbr 600 wont start
hi, each lead has the specific number on it. if you do this correctly then they genrally give you an idea to where the sit in the coils( the way they bend :-) ) also i believe the coils are better off been attached to the frame once you are sure leads are in corect order and possitioned correctly in the coils.i just presumed the coils neaded earthing. make sure battery is pleny charged as a bad battery can just hinder. it is also very easy to flood the bike so just check the plugs again. if they are unusually wet then dry them off and try again . otherwise maybe try cleaning all electics.
hope this somehow helped
gavin barraclough
Posted on Apr 26, 2009
  • 174 Answers
SOURCE: Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Posted on Jul 19, 2009
My Honda gx340 is revving high all the time Can some one tell me y thank you
should be an internal govenor on a plant unit like that
there is a thicker than normal metal rod running off the carby to the motor and that is where you adjust the govenor
cant find good instruction how that governor is adjusted ..if adjusted the wrong way it will rev out may even throw a piston
then check carby idle adjustment
should hunt (rev up and down only slightly )as load changes
you tube
11hp Honda GX340 cold start
https://www.youtube.com/watch?v=i3_v68__X5o
Honda GX340 HGI Partsf21c43c2-def4-46c5-9224-ed46701c0c01.jpghonda-gx340-revving-high-all-time-some-qkhmqzcwln4tohiil4ndbnz4-2-2.jpg
Jun 22, 2016 | Honda Gx340 Gas Engine 11hp Motor Pressure...
What RPMis the max torque
the chart shows figures of 10.7 hp-8.0kw with a torque of 19.5 ft/lbs- 26.4nm at 2500rpms ( max net torque)
the chart shows gx390 is 11.7hp (8.7kw) but the torque is the same as the gx340
you can get these figures from world. honda com or by going google and typing in--torque range of honda gx 340 motor at max rpms
10 hp engines running at 2500 rpms will be good for gensets of 5kw continuous out put as most makes run that size engine
Apr 20, 2016 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Have honda gx340 11hp pressure washer and gas keeps going into oil?
Excessive fuel entering the inlet manifold, carby needle and seat not shutting of fuel flow , remove and clean fit new gaskets and needle and seat if worn.
Jul 02, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Pressure washer rope recoils to quickly when pulling to start
I'm sorry if I'm not quite understanding the question.
Are you saying the rope MAY be too short and so the amount of pull available is also shortened?
Feb 23, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
I have a Honda GX340 power washer and would like to know what types of oil and quantities I need for the engine and pump
The Honda engine will use standard 30W. the pump will use 30W non-detergent.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 09, 2011 | Honda Pressure Washer PSI 3000
Motorturns over hard with pullstarter on my gx340 pressurewasher
You have a nice setup, lots of power. The honda gx340 has a compression release built into the engine so it should be relatively easy to start. With the pressure pump under load however, it will be very hard to pull the rope. With water connected hold spray gun open so water is running out tip and pull rope to start (for easy start, remove tip from gun) . If it still feels very hard to pull rope while holding gun open, most likely problem with lubrication in pump or engine valves are not adjusted correctly preventing compression release. If you suspect problem, go to store where you purchased the unit or any store that sells gx340 and pull the rope to get a feel of what force is required to start engine and compare to yours. Good luck.
Feb 15, 2011 | Honda Pressure Washer PSI 3000
Oil grade and level in pump reservoir? Motor is shutting down, all else seems fine, assume is oil level. North Star with Honda GX340 - pressure washer.
15-40 there will be a fill mark that is easy to see when you remove the cap or it will have a dip stick
Second your oil pressure switch may be bad or have a bad connection
Mar 06, 2010 | Hardware & Accessories
Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
Honda GX340 11 Hp ..Runs fine until it gets hot , Cuts off and
FIRST...check the engine oil level. Some Honda engines have an oil sensor that shuts off the spark if the oil is low. This would also explain it shutting down when it get hot. Check the manual to see how to tell if the oil level is correct. Also, the oil should be brown and transparent, not black. It may need changing. Post again if this doesn't help :-)
Jun 01, 2009 | Honda Pressure Washer PSI 3000
Honda Maxus Prosumer MX5223 Pressure Washer Logo
369 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
