Question about Toshiba Televison & Video
Picture on tv set rolls
The picture just rolls and rolls. it will stop for a while and then it starts up again. there is no vertical hold information, like on the "old" sets, and there are no longer repair shops in the area. what else do you suggest i do? this tv is about 5 yrs old.
  • barbararober May 11, 2010
    I have A MAGNAVOX 51MP6200D/37 HDTV the picture rolls and won't stop
  • 431 Answers
Hi I am Vortash the set vertical sync circuit has a fault on it possibly the frame transistor has gone low or a feed resistor or capacitor has changed value .. if it is the old style Cathode tube set then it is probably the frame capacitors there are two they go leaky and cause this problem .. you did not say a set model so this is about all I can advise yo ,, but sooner or later frame collapse is imminent and you will be left with just a white line across the middle .. the set needs a service engineer to sort this out soon ... Regards Vortash
Posted on May 28, 2009
Picture is rolling
In the old days there was a control at the back of every tv labelled "vertical hold" that needed adjustment when the picture rolled. As tv sets became better that control was at first moved inside the cabinet and then finally deleted.
The vertical hold controlled the amount of synchronising signal (that is extracted from the signal received from the antenna) reached the frame oscillator. Today's electronics are so stable the vertical and horizontal synchronisation is automatic so while sometimes a rolling picture can be caused by a bad signal it almost invariably caused by an internal electronic fault needing the attention of an engineer.
Oct 19, 2017 | Televison & Video
Sometimes the picture rolls for 30 minutes to one hour and then the picture is perfect. A few times when we turn it on, the picture is okay and then after a few hours, the rolling picture starts. Where is...
The rolling is a bad filter capacitor on the signal board in the set---Any Mitsubishi dealer can look the model up and see known faults including this one---some of the sets when cold---vertical jitter in picture or just menu---If the menu is stable you have a tiny bad cap= weak caps when cold act up and when get hot regain capacitance and start to work.
Aug 28, 2012 | Mitsubishi WS-55807 TV
The horizontal hold
If model number correct (the one posted here) set does not have a horizontal (rolls left to right) or a vertical (rolls top to bottom) control.
Verify model and brand so I may offer some suggestions
Mar 22, 2012 | Mitsubishi VS-5075 50" Rear Projection...
Where is the vertical hold button
This set has no vertical hold control---is picture rolling left right or up down?
Mar 10, 2012 | Hitachi 57F500 57" Rear Projection...
The picture on my TS-4573 rear projection tv has started to roll vertically at a fast rate. How can I make this stop. On old tv's there was a vertical hold adjustment on the back that you could play with...
this fault is caused by defective electrolytic capacitors in the vertical deflection circuits, they need to be changed out, do this before it causes more problems, there are no adjustments for this anymore.
Jan 30, 2010 | Televison & Video
Toshiba 40H80 Rear Projection TV Picture Rolling/Scrolling
problem is bad hyper module or can have tech repair it with capacitors
Feb 05, 2009 | Toshiba 40H80 40" Rear Projection...
DVD picture rolls vertically
Somehow the TV setting on the DVD player was set to PALS so we changed it to the proper setting.
Dec 15, 2008 | Digix HT1056A DVD
Video tapes played through VCR experience vertical 'rolling'
unfortunatly no. the vert hold is set by black bars at the top/bottom of the video signal (outside of the viewable area). it sounds like your VCR or tape is damaged.
Dec 04, 2008 | Sony KDF-42WE655 Television
Picture keeps rolling
do you have cable to the set or are you on rabbit ears if on ears adjust antenna for the strongest signal.
Mar 27, 2008 | Sony KV-32S16 32" TV
Tv roll
Are you sure the roll isnt Vertical? as if it is then all you need to do is adjust the VERTICAL HOLD PRESET POT which should be located on the PCB somewhere, its very unusual for TV.S to roll horizontally as then the picture just goes out of sync. and you would not see a picture at all. When you find the pot turn it ( with a small screw driver) slowly until the rolling stops, if it does not stop then you have a faulty component in the vert. sync. circuitry.
Feb 04, 2008 | Televison & Video
Televison & Video Logo
175 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
