Question about HP Compaq Presario SR1575CL (PX808AA) PC Desktop
Trying to restore to factory default using f10
Wont respond when f10 is pressed nothing hppens Just want to know if there's anyway to re-link the recovery partition with the F10 key? I know it has something to do with the MBR but how? The recovery partition is still there, if I set the partition as active and restart, the recovery process would boot up, but I want to make the F10 works again. Any idea?
  • cocopepperbe May 28, 2009
    The original os is installed, the recovery partition still exist and working if you set it active. But the question is, how to make pressing the F10 key triggers the recovery process again?
  • daspyda May 11, 2010
    Is the original factory OS installed? Or, had the disc been reformatted previously and a standalone OS installed?
  • HP Master
  • 4,924 Answers
Try to remove the bios battery for a second..it will reset the bios to the factory settings ...it might just work ...
I believe that the problem its one that developed after you changes some settings or after you installed some device that use that key for a different action ...
Posted on May 28, 2009
Aspire one d257-13473 wont factory reset
Windows key > All programs >Acer Empowering Technology>eRecovery management>Restore>Factory(Top of list)..
Or
If computer will not boot.
Tune computer ON
When Acer splash is on screen hold Alt and keep pressing F10...
Select factory from top of list.
You will need a password , the default is "000000" (Six zeros).
Recommend you use the first option if you can...
1. Power on the machine.
2. At the ACER BIOS screen, hold the "Alt" key and press the "F10" key simultaneously to start Acer eRecovery. The window of opportunity is very small, so this may take a few attempts.
3. Once eRecovery has loaded, click "Restore to Factory Default Settings" (the password is six zeros, 0.0.0.0.0.0.).
4. Click "OK" to continue.
5. From here, the eRecovery process will update all the data on the C: drive and restore the factory image (approximately 10 minutes).
6. Once eRecovery has run, press "OK" to reboot unit.
***This will erase all your unsaved data!***
Or
Running System Recovery from Windows
1. Click Start>All Programs>Acer Empowering Technology.
2. Select Acer eRecovery Management.
3. Select Restore (bottom of eRecovery screen).
4. Select Restore system to factory default (the password is six zeros, 0.0.0.0.0.0.).
5. Select Yes then Next, the system will reboot and start the recovery.
Or
1. Reboot, and press F8.
2. Select Repair.
3. Select Reinstall Windows and follow prompts.
Dec 06, 2013 | Acer Aspire One D257-13473 Netbook
Black screen flashing dash top left corner. ....wont reboot after system restore
If its only 3 mnths old should still be under WARRANTY take it back
if its not under warranty
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup usually delete or the F2 key this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Apr 03, 2012 | Computers & Internet
I have emachines model W3650 and want to know how to set back to factory setting.
(1) Go to start menu(2) Click on all programs(3) click on Emachine(4) click on Emachine recovery management(5) Click on restore on the bar across the top(6) click on restore to system factory default
Some emachines can be restored by pressing ALT+F10, but not sure on your model. Give it a try if you can't restore it to factory defaults using Emachine recovery management.
Feb 05, 2012 | E-Machines eMachines Desktop PC
I need help on restoring my compaq armada e500
Hi Welcome to FixYa!
You could try these steps on restoring your laptop into its factory defaults.
1)Turn off your computer if it is on. Wait for the system to shut down completely. Once it is off, press the "Power" button to turn it back on. Press the "F10" button at the top of the keyboard repeatedly as soon as you see the screen turn on. This will let you enter the setup menu.
2)Use the arrow keys to move between the various menu tabs at the top of the screen. Press the "Right" button until the "File" tab is highlighted, then press the "Enter" button to enter this menu. Here you can make changes to the settings of your computer, or in this instance, restore factory default settings.
3)Use the "Up" and "Down" arrow buttons to move to the "Restore Defaults" option, then press enter. You will see a screen asking "Are You Sure You Wish to Restore System Defaults?" Press the "Y" button to continue. The system will begin restoring your default settings. Do not press a button until a screen says "System Defaults Restored."
4)Use the arrow keys to move down to the "Save Changes and Exit" option and press "Enter." The system will save your changes and automatically reboot your computer. You do not need to press "F10" this time as the computer will start Windows normally. You will see the factory settings have been restored once the system loads.
Hope this could help!
  • Jul 07, 2011 | Compaq Armada E500 Notebook
    My husbands ex wife bought my step son a used HP compaq d530 SFF desktop. She set an admin password on it and now she cant remember what it is. Is there anyway to restore it back to the factory settings...
    If you are talking about problem with your password
    You need to prepare:
    1:A blank CD/DVD or USB flash drive
    2.A computer which can link to internet
    3.A program called Windows Password Recovery 6.0
    Get started with this 3 simple steps:
    Website: http://lost-password.net/products/windowspasswordrecoery.html
    Step 1 - Download windows password recovery utility and install it.
    Step 2 -Burn your Windows Password Reset CD:
    To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
    Step 3 - Put in your newly created CD and remove your Windows password.
    hope this helps
    http://majorgeeks.com/download.php?det=5710
    UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
    you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive) also
    Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
    Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
    click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
    Hope this helps
    Hope this helps
    Apr 08, 2011 | Compaq Computers & Internet
    I did an update for my sylvania smartbook and now it wont do anything. i want to restore it back to its original settings.
    During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer
    hope this helps
    Mar 22, 2011 | Computers & Internet
    Gateway GT5028 missing OS
    sounds like you got a virus. Does it give you the option on boot up to restore (maybe press F10 or alt + F10) if it was a factory install then they have probably made a factory restore partition on your hard drive but maybe not. other remedys are to purchase a restore disk for the gateway or reinstall windows XP (you might be able to use the XP restore feature) and download any drivers you need from here http://support.gateway.com/product/default.aspx?tab=1&modelId=2844 I would download the drivers with another computer or get a friend to do it as you probably wont be able to connect to the internet without the drivers installed. I have them if you need, but you can get them from the link.
    Feb 02, 2011 | Gateway GT5028 PC Desktop
    My acer aspire 4315 stuck at boot with white screen, when using external monitor it show acer boot screen and stuck there. I can press F2 for setup but nothing happen.
    http://tim.id.au/laptops/acer/aspire%204715z%204315.pdf
    Above is a link for your Service manual, inside is everything you need to know to troubleshoot and repair your machine, this is the manual that us engineers use to repair these units.
    This could be your HDD, failed. Work through, the troubleshooting procedures.
    Anyway try this below first. Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
    May 14, 2010 | Acer Aspire 4315 Notebook
    Hi there
    if you have your restore cd that came with the computer install it and turn off the computer than restart the computer and the cd will come upo saying welcome to windows restore than it will ask you if you want to restore and say yes and let it do that than when it is done it will reboot the computer
    Feb 17, 2009 | HP Compaq Presario SR1575CL (PX808AA) PC...
    Need to restore acer to factory settings
    just boot from your backup disk. it will guide you to reload the Operating system (factory default).
    FYI, if you haven't delete the recovery partition, you can use alt+f10 to reload. just press alt+f10 during boot.
    Jul 31, 2008 | Acer Aspire 3000 Notebook
    HP Compaq Presario SR1575CL (PX808AA) PC Desktop Logo
    684 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
