Question about Venturer PVS177W Portable DVD Player
DVD Player keeps reading no disk even though there is inserted in the slot
Inserted disk gives the player that there is not a disk in the chamber so it reads "no disk". What do you think the problem can be?
    Sergeant:
    Champion:
  • 255 Answers
Try cleaning the lens, first.
Posted on May 28, 2009
If you keep getting a reading like no disk you might have to use different brand disks!
For example I used memerex and aptivia and it kept saying no disk when I tried other brands like sony or hp disks they worked and make sure your using minus cd disk!
Posted on Aug 07, 2009
Well I had the exact same problem so I decided to remove the entire back off of my Venturer PVS1977G. After removing the back and inspecting the parts, I didn't find anything obviously wrong or or anything out of place I re-assembled it and it read the dvd's!
I have no idea why this worked but it did....I'm happy.
Ed
Posted on Jun 19, 2009
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Toshiba DVD player
Does this happen with all discs? What disc are you inserting that gives this error? DVD?
Feb 05, 2008 | Televison & Video
How do i fix my CD player? when i put a disk in, the readout says "err disk" it works every once in a while, but i have run a lens cleaning disk in the player, and it wouldnt even read that disk.
how long have you been using the player? And has it been giving you this type of problem before now?
I think the fault is from the laser (lens) of your player. The lens is very weak such that it cannot read the data or files on a disc, that's why it should disc error, even though it plays some disc but that doesn't mean its not a lens problem.
You need to look for a way to replace the lens for your player so that it can play all discs perfectly well again.
Good luck.
Sep 25, 2010 | XO Vision XO9013 Car DVD Player
My dvd player keep on loading but it end up no
from direct experience, the problem is that the disk does not start spinning by itself - it will if you have the top off and give it a spin to start it ... I don't know what the ultimate solution is though.
Jul 04, 2010 | Pioneer DV-400V DVD Player
Player shows '' No Disc'' even when inserted with a disk
When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
See also the following websites on how to clean the lens, use a cleaner disk first:
Gizmo Highway DIY - Clean your CD player lens
Lens Cleaning CDR CD-RW (how?)
DVD Not Working
Mar 04, 2009 | Sony Televison & Video
XV-N40BK/XV-N44SL (NO DISK INSERTED)
Hey WeiesBlitz,
There may be a number of reasons why you may be encountering this problem, but there are a couple of quick solutions that may always try before seeking repairs on the player.
First, I would suggest making sure that the DVD's being used have been cleaned and are dust-free. Imperfections or impurities of any kind on the surface of a CD or DVD may prevent the laser in your player from being able to read, or even recognize the media inserted. You should be able to clean the DVD by using a soft and dry, lint-free (typically microfiber) cloth. Remember to try using gentle, outward strokes that run from the inner ring of the disc directly to the outer edge.
Second, you can always try cleaning the lens of the player itself using a commercial cleaning kit. Many retailers (including your local Best Buy™ store) may sell kits that clean lenses when inserted into your player like a normal DVD. Please keep in mind that not all DVD players are designed to function with these cleaning kits, and that you should always refer to your owner's manual for any possible warnings against the use of such products.
Should these suggestions fail resolve the problem, you may wish to try using other DVD's from your film library in the player. If other discs function normally, the non-functioning disc may be damaged. If using other discs results in the same error message, the player may be in need of physical repairs.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 06, 2008 | JVC XV-N40BK DVD Player
DVD player shows "no disk" messege even though there is a disk in the player
Either a disk problem, or a player problem. If you get the "no disk" message when using other disks(try originals if you were trying burnt), that aren't scratched, then it's possible that the lens needs cleaning. open the player, locate the lens, and gently brush off any accumulated dust. If you see none, then it will take a more serious repair, possibly to the motor assembly, or the lens mechanism. Good luck
May 03, 2006 | Akai DVDP5851 DVD Player
Venturer PVS177W Portable DVD Player Logo
870 people viewed this question
Top Venturer Televison & Video Experts
john milligan
Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
