Question about Samsung SyncMaster 720N Monitor
The brightness menu screen is stuck on!
I have left it off for some time and nothing! it has random moments where it will start flicking through the menu screen and then stop. any kind of solution would be amazing pelase! the syncMaster 720n is locked with the brightness on...have you found a solution?
    Sergeant:
    Champion:
  • 225 Answers
Please try to turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu from your screen. regards
Posted on May 28, 2009
My solution for this problem was to just unscrew the 4 leg screws and the 2 in the botton. Then with a card, such as a creditcard or a swipe card of some sorts just carefully take off the black (or in my case silver) front plate and just take out the circuit board that controls the buttons. Then carefully put back on the frontplate, put the screws back in, and it'll work. The only problem you create is that you don't have a power button anymore, but you can obviously solve that with taking out the power plug.
Posted on Oct 03, 2010
I had the same problem. looking at the solutions and saw the hair dryer solution. Having had a air compressor close by, I opened the monitor, took out the console button pcb.
Then using compressed air on each of the buttons from all possible angles.
Reassembled everything, and voila... all working perfectly again.
Posted on May 14, 2011
  • jay FixYa Jul 18, 2014
    the compressed air one in #3 gave me an idea. I simply got right up next to the "+" button (the one that seemed to be stuck) and then just took in a deep breath and blew as hard as I could. Instantly fixed it.
Won't stop cycling through brightness settings
sounds like it might need a cleaning. are the buttons hard to push or are any of them giving you a different feeling then the rest?
Aug 13, 2017 | Samsung SyncMaster 2233SW Monitor
My monitor's brightness menu stays always popped up
check the button which get stuck up, clean it with electronic contact cleaner.you will need to remove the back cover to access the button panel.
Oct 15, 2012 | Philips 170S6FS 17" LCD Monitor
The brightness adjustment bar appears on the screen all the time
Press the menu button on monitor select the brightness press the menuside button increases or decreases.after select exit oress the exit button on monitor.
Jul 13, 2009 | Compaq CV 7500 17" CRT Monitor
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Brightness quit working
Unfortunately, it soulds like the monitor may be going bad. You may have to use the manufacturer warranty if its still valid.
Thanks
Nov 14, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Random turn off
just soldering your color ic or your RGB ic
Jun 20, 2008 | Sony FD Trinitron WEGA KD-34XBR2 34" TV
Monitor menu screen appears on screen
Try a hard reset: Unplug from power source, disconnect from PC and wait for 10 minutes. Reconnect everything and see if the issue is resolved.
If not, then you either have a loose contact on the menu button or failing circuitry. I'd recommend calling Sharp tech support in this case..
Jun 14, 2008 | Sharp LL-193AB 19" LCD Monitor
My 50SBX70B flicks than lost the power
Symptom: NO HOR SYNC
Cause: DEFECTIVE I008
Symptom: No Horizontal Sync. When PinP is called up, main picture may lock up for a 8 moment, then it goes back out of sync.
Cause: I008 defective (Sync Switch)
Jan 15, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Samsung SyncMaster 720N Monitor Logo
5,215 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
